Old Jul 26, 2011, 06:24 PM
JOHN SCALE BOAT is offline
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
New Product
Robot ESC works great in Scale boat with mixing
Bought this ESC and tried it in my boat and it works great! Look at the specs. 6 to 24 volts 12 amps max per channel. Built in selectable lipo on or off. Selectable duel channel operation work as either independent or mixed with another. I selected mixed throttle with rudder. As you move the rudder the inside motor slows and then reverses linearly with rudder stick movement. I use the aileron stick to control the rudders. Could not be happier.... and made in the USA.
http://www.robotmarketplace.com/prod...ER2X12-RC.html
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Jul 26, 2011, 09:38 PM
ZZ56 is online now
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
I also have this in a boat under construction and though i haven't had open water trials, nothing but good things to say. It's virtually silent, I cannot hear any motor whine as they throttle up.
Also, when you are stationary in mixed mode, swinging the rudder fires up the engines in opposite directions. If my bathtub were circular, i could tell you how that works out.
ZZ56 is online now Find More Posts by ZZ56
Old Jul 28, 2011, 01:41 AM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
And they are small and light. I used one in my 1:48 PCF Swift build. My only complaint was when we used it in a bigger, faster, boat. At speed I wish the mixing would be exponentially less as the rudders are better. But for tugs and slower boats they are handy.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Jul 28, 2011, 07:48 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Thanks, lots of goodies there.
Here's a good-looking motor for direct driving a big 4" or so prop:
http://www.robotmarketplace.com/prod...-217-2000.html
It has an 8mm shaft, which will require some effort to adapt- most model boats couplers max out at about 6mm.
And another, a little slower:
http://www.robotmarketplace.com/prod...-204-1021.html
patmat2350 is offline Find More Posts by patmat2350
Old Jul 28, 2011, 08:00 AM
tghsmith is online now
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
they have a very good selection of switches that plug into your receiver to handle higher volt/amp loads plus dual functions...
tghsmith is online now Find More Posts by tghsmith
Sold NEW IN BOX GREAT PLANES Elctro Streak Fiberglass ARF kit with esc, motor folding prop mechengineer03 Aircraft - Electric - Airplanes (FS/W) 1 Jul 23, 2011 06:48 PM
Discussion What brushless airplane esc works well in a boat ? mortonj69 Racing Boats - Electric 1 Jun 03, 2011 06:59 AM
Discussion CHDK- Taking Off\Landing with close Lenss- It Works Great!! guyg Aerial Photography 7 Apr 01, 2011 10:40 AM
Discussion Now with data: Hobbyking SS 25A esc works great it was my fault for not testing first handyfella Power Systems 40 Mar 26, 2011 09:29 AM
Crow mixing on flying wings: works great! surfimp Slope 20 Mar 25, 2005 06:03 PM
