Old Jun 25, 2012, 11:37 AM
Plainfield, IN
Joined Sep 2004
I pulled the trigger an mine is on its way!
Lou
TK421 is offline Find More Posts by TK421
Old Jul 07, 2012, 07:55 AM
London, UK
Joined Mar 2010
Im looking to get into 3D, i currently fly The Stryker F27Q, and picked up an E-Flite Carbon Z Yak a couple of months ago, and comfortable flying scale but nothing 3d . i find it a bit intimidating, and was hoping to pick up a smaller foamy for easy transport in the car etc.
Ive had a look at the RC Factiory Yak 39", and this seems to be the better option for me as i need something which can handle some wind but also not too large. i was under the impression that this would be better than the the 32" for handling wind?
Does my choice seem a good one considering my requirements?
vygec is offline Find More Posts by vygec
Old Jul 07, 2012, 10:53 AM
Plainfield, IN
Joined Sep 2004
I've got 12 or so flights on mine now and I love it! I did have to put a thicker carbon spar in mine though as the wings flexed more than I would have liked. I used a 2x8x600mm carbon bar and now the plane is locked in. It does knife edge spins and flies well beyond what I am capable of.
Go for it!!
Lou
Old Jul 09, 2012, 08:16 AM
London, UK
Joined Mar 2010
Could someone confirm if this is the V2 version of the yak?
http://robotbirds.com/catalog/produc...oducts_id=4726
If its not, whats the difference between this and the v2?
Thanks.
Old Jul 10, 2012, 11:29 AM
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Thanks.
Looks like the V1 to me, plus it says the product was added to the catalogue in 2009.
The V2 is here with a description of the changes http://www.parkaero.com/rc-factory-y...des-1023-p.asp
Mike Smart is offline Find More Posts by Mike Smart
Old Jul 10, 2012, 02:59 PM
London, UK
Joined Mar 2010
thanks, ive spoken with robotbirds and they suggested that the picture/description was out of date and that the stock is definitely v2.
Old Jul 10, 2012, 05:29 PM
Mike Smart's Avatar
Joined Jan 2000
Your'e in luck then, especially as ParkAero are out of stock.
Old Jul 14, 2012, 04:45 PM
London, UK
Joined Mar 2010
sorry, another beginner question from me.
do i need a y servo lead to connect both aileron servos to the rx?
Old Jul 14, 2012, 06:50 PM
Support your LHS b4 its gone.
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
That is one option.
Or, depending on your radio, you can plug one servo into the aileron port and the other into the Aux port and program the radio. Your radio manual will tell you how
_OZ_ is offline Find More Posts by _OZ_
Old Jul 14, 2012, 07:52 PM
London, UK
Joined Mar 2010
Ok,thanks.I have a Dx6i,so i'll take a look at the manual.
Next problem is, ive got to installing the ailerons and the instructions suggest to install the aileron control horn on the edge of the aileron. If you look at my picrure attached you can see that the control horn will have to be placed much further in to for the control rod to fit.
The only other option is to cut the rod to fit the length, but i would have thought this would significantly decrease my throws. (i also have some carbon rod/clevis which can be used in place of the z bend rods )
This is my first build ive taken on, im taking my time, but its testing my patience
Old Jul 14, 2012, 09:59 PM
_OZ_'s Avatar
Joined Aug 2004
Here is a pic of how to install the servos, horns and rod.
The horn must be on the edge of the aileron hinge with the hole that the control rod will be in centered directly over the hinge line (crease).
For the control rod, use a Z bend on one end and leave the other end straight.
Use adjustable connector for the straight end of the control rod like Du-bro mini E/Z Connectors.
Once everything is installed, bind up you radio to your receiver and get all of your servos centered up. Then center you surfaces and then you can tighten up the E/Z connects.
Old Jul 18, 2012, 04:57 AM
London, UK
Joined Mar 2010
thanks.
If i am only flying from heavy grass areas and nowhere to take off from, would it make more sense to keep the landing gear off?
would it do more harm than good ?
Old Jul 18, 2012, 05:36 AM
_OZ_'s Avatar
Joined Aug 2004
You can leave them off. Belly landing should not damage it.
Old Jul 21, 2012, 06:02 AM
London, UK
Joined Mar 2010
Final bit of advice i hope
The manual suggests COG 0.5mm behind the tab at the wing root. what does this mean, i cant see any tab.
to test the cog, do i turn the plane upside down and does the battery go on top or bottom of plane?
a picture of where the battery should sit would be very helpful. (im dying to take the plane out, weather is perfect!)
Old Jul 21, 2012, 03:14 PM
_OZ_'s Avatar
Joined Aug 2004
I put the battery on the bottom, measure G with the plane upright and have marked where mine is. The little white pointy bit is the tab they are talking about.
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 558 Yesterday 11:14 AM
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 320 Yesterday 01:25 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 990 Apr 19, 2013 10:38 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
Wanted RC-Factory Yak 54 or Yak 55 Hammer Aircraft - Electric - Airplanes (FS/W) 3 Jul 09, 2010 11:12 PM
