Old Oct 04, 2011, 11:38 PM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
This i have been waiting for any photos or info on the new RcFactory 31" EPP Edge 540 yet ?
Kris... is offline Find More Posts by Kris...
Old Oct 08, 2011, 09:28 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Any more info on the Edge ?
Old Oct 08, 2011, 09:38 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Joined Dec 2008
A little something here....
http://www.rcgroups.com/forums/showthread.php?t=1517861
Dan5.0 is offline Find More Posts by Dan5.0
Reply With Quote  (Disabled)
Old Jan 24, 2012, 06:58 PM
daedalusrobert is offline
Find More Posts by daedalusrobert
daedalusrobert's Avatar
United States, GA, Valdosta
Joined Jan 2009
Ordered and subscribed! Great customer service at Twisted Hobbys!
daedalusrobert is offline Find More Posts by daedalusrobert
Old Jan 24, 2012, 08:01 PM
cbriggs11 is offline
Find More Posts by cbriggs11
Team Twisted!
cbriggs11's Avatar
United States, SC, Greenville
Joined Nov 2009
Awesome. Ull love it. Pm me if u have any questions. I'll be glad to help
cbriggs11 is offline Find More Posts by cbriggs11
Old Jan 24, 2012, 09:52 PM
Joined Jan 2009
Thanks...will do! I've built several depron kits but this will be my first EPP. Anyone tried the Motrofly motors on this plane?
Last edited by daedalusrobert; Jan 27, 2012 at 11:42 AM. Reason: Bad grammar and more questions!
Old Feb 13, 2012, 05:21 PM
3D*Flyer is offline
Find More Posts by 3D*Flyer
3D*Flyer's Avatar
USA, CO, Longmont
Joined May 2010
I have a Scorpion S-2215-18 off a 38" DW Foamie what do you think about putting that in the TH 39" RCF YAK-55?
S-2215-18 Specifications
Stator Diameter 22.0 mm (0.866 in)
Stator Thickness 15.0 mm (0.591 in)
No. of Stator Arms 12
Magnet Poles 14
Motor Wind 18 Turn Delta
Motor Wire 6-Strand 0.21mm
Motor Kv 1131 RPM / Volt
No-Load Current (Io/10V) 0.68 Amps
Motor Resistance (Rm) 0.097 Ohms
Max Continuous Current 20 Amps
Max Continuous Power 210 Watts
Weight 61.9 Grams (2.18oz)
Outside Diameter 27.9 mm (1.097 in)
Shaft Diameter 2.97 mm (0.117 in)
Body Length 31.95 mm (1.285 in)
Overall Shaft Length 50.3 mm (1.982 in)
Max Lipo Cell 3s
Motor Timing 5deg
Drive Frequency 8kHz
3D*Flyer is offline Find More Posts by 3D*Flyer
Old Feb 13, 2012, 07:52 PM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
That motor looks perfect for an APC 10x4.7 SF:
http://www.scorpionsystem.com/files/i405_data_chart.htm
With 200 watts, you should have a lot of fun with the Yak-55!
7rider is offline Find More Posts by 7rider
Old Feb 16, 2012, 10:28 AM
3D*Flyer is offline
3D*Flyer's Avatar
USA, CO, Longmont
Joined May 2010
That is what I was thinking also, just wanted a second opinion! I need to order one up! What is the best flying TH 39" airframe? Is the Yak-55 the best choice?
Old Feb 16, 2012, 10:40 AM
7rider is offline
7rider's Avatar
Joined Dec 2007
I fly the SU-29 and someone else at the local field has the Yak-55. Both fly great. The SU-29 might be a little easier to knife edge since it has more side area than the Yak-55. Both the Yak-55 and the SU-29 have a round cowl and mount which I think looks pretty cool, but they can be a PITA to deal with. If I had to buy a new RC-Factory 39" right now, I would look at the RS-352 or the Flash D because of their more conventional motor mounts.
Old Feb 16, 2012, 11:43 AM
3D*Flyer is offline
3D*Flyer's Avatar
USA, CO, Longmont
Joined May 2010
Thanks!
I have been looking at the RS-352 (I just need one or two if each), I will probably order a RS-352. The Thunderbolt printing is really nice!
Old Apr 28, 2012, 11:36 PM
Joined Jan 2009
Just finished my Yak 55 this afternoon and made a couple of test flights. She flew great on the recommended motor and I liked the APC 10 x 3.8 better than the 4.7. Tried the 800 mAh batteries just for kicks...awesome verticals and hover pull out but as you can imagine not nearly enough flight time! Love this plane! Crack Yak needed a break anyway...
Old Jun 12, 2012, 08:03 AM
TK421 is offline
Find More Posts by TK421
Plainfield, IN
Joined Sep 2004
Did anyone ever try that Scorpion motor in the Yak?
Lou
TK421 is offline Find More Posts by TK421
Old Jun 15, 2012, 08:59 AM
TK421 is offline
Plainfield, IN
Joined Sep 2004
How crucial is it to use metal gear servos on this plane? I have 3 brand new Futaba s3114 servos and an Hitec HS-65HB on hand. I would use the 65HB on rudder and the others for other control surfaces. Anyone have any insight?
Lou
Old Jun 15, 2012, 12:47 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Metal is not necessary and is overkill in my opinion.
_OZ_ is offline Find More Posts by _OZ_
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 09:06 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
Wanted RC-Factory Yak 54 or Yak 55 Hammer Aircraft - Electric - Airplanes (FS/W) 3 Jul 09, 2010 11:12 PM
