Old Oct 17, 2011, 10:31 AM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Tim ... Question... Currently I am running the recommended Torque setup on my other EF plane in the same size category. I am running the xoar 15x8 prop and now skylipos 40C packs. Should I go with the 15x6 prop instead or is it all based on my preference of the feel I am looking for ... Just curious.. I wasn't too excited with 15x8 on the 40c packs.
livinma1 is offline Find More Posts by livinma1
Old Oct 17, 2011, 11:21 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Hey Mark,
I would start with a Xoar 15x6, and fly it.. If the plane dos'nt pull hard enough, then prop up to a 15x7, and make sure to check your numbers..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Oct 17, 2011, 11:30 AM
SpartanExec is offline
Find More Posts by SpartanExec
Extreme Flight Minion
SpartanExec's Avatar
United States, OR, Happy Valley
Joined Nov 2010
Originally Posted by _OZ_ View Post
Are either of the ailerons warped? I recovered one of my planes and had a trim issue. Looking at the plane from the back I could see that one aileron was warped while the other was straight. To fix it you can just tweek the aileron to make it straight and then re-shrink the covering. I have had to do this with factory produced planes before as well.
Also, I think people tend to jump to the thrust angle or wing incidence as the cause of problems way to quickly. Things like warped surfaces, CG and linkage geometry have fixed many of my problems.
Everything is perfectly straight....I had it on my level table and each wing and aileron is perfectly straight, the elevator is straight, rudder is fine, fuse is straight, the motor does not look like it has as much right thrust as other models I measured it at just under 2 degrees, seems like it should have 2.5 or 3 at least. I strung the plane up and measured the incidence relation of the tail and wing together but I measured off of the canopy sill, which I found out this morning when I remeasured wasn't perfectly level.
Regardless of the issue, it still flew very well and I am more than happy with it, with a new model, there are always little things to work out and adjust as the collective Extreme Flight mind find the perfect setups
SpartanExec is offline Find More Posts by SpartanExec
Old Oct 17, 2011, 11:32 AM
Joined Nov 2010
Originally Posted by Tim Semeraro View Post
Spartan,
Congrats!! The 15x6 is more for the high c rated packs(40c+).. I also run 30c 6s and I've found a 15x7 pjn works perfect! 1400W @ 60amp..
The 15x8 is a bit to much pitch for 30c and will Boost your numbers into the danger zone..
I'll have a few video clips up later, and you can see mine is just as fast as my Edge..
BTW.. Mine flew perfect right out of the box! No trim needed!!!
Thanks for the advice Tim, just got one ordered
Old Oct 17, 2011, 12:34 PM
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
Yeah when I was finishing mine and putting on the cowl, I noticed it had quite a bit of right thrust added in...at the time I thought too much! After flying it yesterday though, it literally needed 1 click of aileron and that was it. That was a first for me
CRFan1 is offline Find More Posts by CRFan1
Old Oct 17, 2011, 12:43 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Hey Mark,
Thanks Pal.. I think I already have 15x7 @ home.. Will have to order a 15x6.. I may have one on my 58 inch extra.. Let me check first before I go order.
Thanks Pal..
I need to fly some of my EF stuff this week man.... itching to.
Old Oct 18, 2011, 11:50 AM
Joined Oct 2008
My Friend Dennis came threw with some stills from Sunday, unfortunately conditions were way to wind, and I wasn't able to capture any decent video
Old Oct 18, 2011, 12:31 PM
cje0114 is offline
Find More Posts by cje0114
cje0114's Avatar
Carteret, NJ
Joined Feb 2006
What wind?
cje0114 is offline Find More Posts by cje0114
Old Oct 18, 2011, 12:52 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
The Torque will get warm with 15x8 on 6s 40C in this weather. In the summer, it will get a bit hot.
The Motrolfly 4315 runs a bitter cooler though and is 39g lighter.
Vien
vienquach is offline Find More Posts by vienquach
Old Oct 18, 2011, 02:15 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Vien
Hey Vien,
What batteries and ESC are you flying on your Motrolfly setup?
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Oct 18, 2011, 02:17 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Performance on Grass Fields
For those flying off of grass fields...
Any issues?
I'm contemplating going up to 2.5" wheels.
JC
Old Oct 18, 2011, 02:48 PM
Joined Oct 2008
Any issues?
JC
Not needed.. I run wheel pants(Edge&Extra), and have never had a problem, Even in thick grass!
Old Oct 18, 2011, 02:58 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Same here.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Oct 18, 2011, 04:30 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Yeah... wheels are no problem. I've flown my 48" EXP's off grass with no problem.
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Oct 18, 2011, 05:00 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Hey Vien,
JC
I had the Motrolfly 4315-500 on the SC 57.
ICE 75, Xoar 15x8, Gens ACE 6s-2200 25C. Pretty light, but the 6s-2500 might work better.
Vien
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
