Old Oct 17, 2011, 04:48 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Spartan,
Congrats!! The 15x6 is more for the high c rated packs(40c+).. I also run 30c 6s and I've found a 15x7 pjn works perfect! 1400W @ 60amp..
The 15x8 is a bit to much pitch for 30c and will Boost your numbers into the danger zone..
I'll have a few video clips up later, and you can see mine is just as fast as my Edge..
BTW.. Mine flew perfect right out of the box! No trim needed!!!
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Oct 17, 2011, 04:53 AM
Joined Oct 2008
Spartan,
Here's a short clip Nick put up.. Thanks NSG!
raw footage of Tim's EF Extra, part 2 of 2 (1 min 30 sec)
Old Oct 17, 2011, 05:22 AM
mp.stumpy is offline
Find More Posts by mp.stumpy
mp.stumpy's Avatar
Germany
Joined Dec 2010
Fiala Wood Prop
He Guys,
you really should check out the Fiala propellers from czech republic.
Flown Xoar 15x8 and Vox 15x7 on my 60 Edge. Switched to Fiala 15x8 and itīs just awesome.
Blade shape is different from the usual wood prop. Main benefit i discovered is you almost got now stall at the prop blades, e.g. when hovering. I feels like you got more "grip" in the air.
Even went up to a 16x. size prop on an axi 4120/20 - really good.
In my opinion the best prop for 3D.
Greetings from Germany.
Marcel
mp.stumpy is offline Find More Posts by mp.stumpy
Old Oct 17, 2011, 05:50 AM
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
Originally Posted by Tim Semeraro View Post
Spartan,
Stupid question but what is a "pjn"? I am running the 15x6 APCe on my kids and it was only pulling around 54 amps and 1200 watts peak. I have some room...... Would a xoar 15x7 work. I assume xoar makes electric props?
CRFan1 is offline Find More Posts by CRFan1
Old Oct 17, 2011, 06:38 AM
daedalusrobert is offline
Find More Posts by daedalusrobert
daedalusrobert's Avatar
United States, GA, Valdosta
Joined Jan 2009
PJN is the designation XOAR uses for their electric series of beechwood props...I've had very good performance from them. Will break if you have a prop stike and more expensive than the APC E props.
http://www.xoarintl.com/props/model-airplane/PJN.html
daedalusrobert is offline Find More Posts by daedalusrobert
Old Oct 17, 2011, 07:27 AM
Joined Oct 2008
Yes, PJN is the Xoar designation for there Electric prop..
Obviously there not going to be as strong as Plastic props, as far as wood goes there very durable, and look sweeeeet!!!
Old Oct 17, 2011, 07:40 AM
cje0114 is offline
Find More Posts by cje0114
cje0114's Avatar
Carteret, NJ
Joined Feb 2006
Great plane Tim. I kind of want one after seeing yours yesterday. It was amazing that it handled that wind as well as it did! If it was that impressive in 25-30mph gusts, I can only imagine how sweet it will be in dead air..
cje0114 is offline Find More Posts by cje0114
Old Oct 17, 2011, 07:48 AM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Originally Posted by SpartanExec View Post
just needs a little more right thrust and maybe a little incidence adjustment on one of the wings (not sure if it's thrust or incidence, it needed a lot of right aileron trim to fly level)
Are either of the ailerons warped? I recovered one of my planes and had a trim issue. Looking at the plane from the back I could see that one aileron was warped while the other was straight. To fix it you can just tweek the aileron to make it straight and then re-shrink the covering. I have had to do this with factory produced planes before as well.
Also, I think people tend to jump to the thrust angle or wing incidence as the cause of problems way to quickly. Things like warped surfaces, CG and linkage geometry have fixed many of my problems.
_OZ_ is offline Find More Posts by _OZ_
Old Oct 17, 2011, 08:19 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Spartan,
Tim, where are you getting the Xoar 15x7 PJN's? All I can find are 15x6 and 15x8. My motor does 1400 watts on a 15x7 APC, and supposedly Xoar's load a little less than APC's, so I ordered a 15x8 Xoar. We'll see.
cwojcik is offline Find More Posts by cwojcik
Old Oct 17, 2011, 08:24 AM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
http://www.abellhobby.com/XOAR-15X8-...-p/pjn1508.htm
Check the link above. Abellhobby has the best price on all the Xoar props. I purchased several 15", 16", and 19" props last week. They are about 15% to 30% cheaper than other sites.
Vien
vienquach is offline Find More Posts by vienquach
Old Oct 17, 2011, 08:27 AM
CRFan1 is offline
Northwest Indiana
Joined Feb 2011
Thanks! I am fairly new to the electric scene so I am learning. Gonna try one I think.
Next question is where can you get one, lol...searches are not turning up a lot....
Old Oct 17, 2011, 08:30 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Thanks Vien, if I need more props I'll order from them (I found a coupon for Tower though so I got them there).
Unfortunately I still don't see the 15x7 at Abell.
Old Oct 17, 2011, 08:39 AM
CRFan1 is offline
Northwest Indiana
Joined Feb 2011
They have 15x7 falcon props at ADC...are those worth a try?
Old Oct 17, 2011, 10:17 AM
EXTREME FLIGHT is offline
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
I've had great success with the Falcon props.
EXTREME FLIGHT is offline Find More Posts by EXTREME FLIGHT
Old Oct 17, 2011, 10:30 AM
CRFan1 is offline
Northwest Indiana
Joined Feb 2011
Cool thanks! I may give them a try!
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2631 Aug 04, 2016 12:00 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
