Old Feb 10, 2013, 02:30 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Originally Posted by ecaa3d View Post
Go for it....I'm thinking old V1, everyone else running the v2 around here is still using the 15x6. I don't know why.
I use 16x8 Carbon Cam on 5s Hacker setup. I wouldn't trade it.
Originally Posted by bryansifsof44 View Post
I use the 4315-480 with a 16x8 on 6s and wouldn't have it any other way.
15x6 or 15x7 xoar are the correct props for the 4016t/500 V1(always check your amp draw)
The new 4016/t500MKII can swing from a 15x7 up to a 16x8zoar. 16x8 apc is not Recommended due to its higher amp draw.
I personally run a 15x7 xoar with a V1 in the extra, and a 16x8 xoar (64" MXS) with the MKII. If I was running the v2 motor in the 60" extra, I would probably run a 15x8-15x9.
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Feb 10, 2013, 02:42 PM
Slats! is offline
Find More Posts by Slats!
Joined Jan 2009
I just picked up a new V2 so I now have a V1 and V2. Just wondering
-Are you running the 16x8 on 6s with the V2?
-with the 16x8 would be better in the extra or edge i have. I need one to crash before getting the MXS haha.
Thinking bigger prop on the Edge for 3d.
Originally Posted by Ducati Mechanic View Post
15x6 up to 15x8 xoar are the correct props for the 4016t/500 V1
I personally run a 15x8 xoar with a V1 the extra, and a 16x8 xoar with my 64" MXS. If I was running the v2 motor in the 60" extra, I would probably run a 15x8-15x9.
Slats! is offline Find More Posts by Slats!
Old Feb 10, 2013, 02:45 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
That's what I thought. For the Extra I most likely will be using a 16x8 PJN but will try the 15x10 PJN.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Feb 10, 2013, 02:46 PM
Joined Oct 2008
I made some corrections to my top number you guys are too fast for me
Yes 16 x 8 xoar on 6s with the v2 mkII, but not a apc, and 15x7 xoar on 6s v1 motor. You should only go up to 15x8 xoar with the v1 if your amp, and watt draw allow it.
Old Feb 10, 2013, 02:57 PM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
what about 15x8 aeronaut on v1?
rimaarts is offline Find More Posts by rimaarts
Old Feb 10, 2013, 10:39 PM
Joined Oct 2008
Probably to much prop on 6s. Cf Props Draw notoriously high amperage, Due to the fact that they don't flex much, But I wouldn't know until I put it on a wattmeter.
Most of us stick with xoar, because of the softer amp draw. Be careful not to overtax that motor! I never went over 15x7 xoar with my v1 motors.
Ideally you want around 1450 Watt at around 60amp on 6s with the V1. On 5s your amperage will be closer to 70amp, and usually around 1200watt.
The hacker is a great motor on 5s. I had one in my edge. It's KV is a bit higher so it really go's! I bet that setup works nicely!
Old Feb 11, 2013, 12:05 AM
m0dest is offline
Find More Posts by m0dest
aka ECAA3D
m0dest's Avatar
United States, WA, Olympia
Joined Apr 2012
It does. It's Steve McQueen proof too.
m0dest is offline Find More Posts by m0dest
Old Feb 11, 2013, 10:28 AM
Joined Oct 2008
Nice!
Old Feb 14, 2013, 12:48 PM
nofreee is online now
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
When anybody has a free moment, would you mind taking some measurements of the tail for me? Trying to see if I can stuff one of these into my car.
Total height of the tail including the landing gear and the elevator width would be great.
Thanks!
nofreee is online now Find More Posts by nofreee
Old Feb 14, 2013, 01:28 PM
frankjp is offline
Find More Posts by frankjp
2.3 D Hack Bradenton FL
frankjp's Avatar
Joined Dec 2010
Thanks!
14 1/8th" High and 24" wide
frankjp is offline Find More Posts by frankjp
Old Feb 14, 2013, 01:39 PM
nofreee's Avatar
Joined Jan 2012
Greatly appreciated!
Old Feb 14, 2013, 07:28 PM
Gonzo 1971 is offline
Find More Posts by Gonzo 1971
This is BAT country!
Gonzo 1971's Avatar
United States, MI, Ovid
Joined Nov 2003
Mine fits in the backseat of my G6 with no problem. Just for reference.
Gonzo 1971 is offline Find More Posts by Gonzo 1971
Old Feb 14, 2013, 09:51 PM
ryyoungs is offline
Find More Posts by ryyoungs
Thumbs in training
ryyoungs's Avatar
United States, OR, Damascus
Joined Feb 2012
Originally Posted by ryyoungs View Post
I have a JR ds3421 servo on the elevator of 60" extra that will jitter when I hold it steady at any given point, but doesn't do it all the time and not always at the same position. This is on the bench and not under load. I never noticed it before, I've only had the plane for 2 months with 15 flights on it, and am wondering if this is normal and once under load it will be fine?
I just heard from Horizon Hobby today and they were not able to find anything wrong with the servo. I guess there was a recall on some DX8 gimbals, but mine wasn't one of them. He said depending on the receiver I'm using sometimes when you set the frame rate to 22ms it can cause this issue. Needless to say my issue isn't solved. The rep from Horizon Hobby said he's going to send back the servo and after I have it installed to call him and see if we can't trouble shoot it over the phone.
Even thou my issue hasn't been solved yet I am happy with the service from Horizon Hobby up to this point.
ryyoungs is offline Find More Posts by ryyoungs
Old Feb 14, 2013, 11:22 PM
m0dest is offline
aka ECAA3D
m0dest's Avatar
Joined Apr 2012
You can try an RF filter ring. Sucks that they aren't replacing it though.
Old Feb 14, 2013, 11:36 PM
ryyoungs is offline
Thumbs in training
ryyoungs's Avatar
Joined Feb 2012
Thanks for the suggestion. I'll wait to see what kind of troubleshooting they run me through before I go trying things on my own. I'm hopeful in the end I will have a working servo.
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
