If it was a pot in your transmitter, you would have the same problem on the same channel with other servos, especially if you had the same expo settings. A lot of expo can mask problems with the pot in the transmitter.
What kind of transmitter do you have? On a DX8 and DX18 there is a monitor function. Set up a new plane without expo, go the monitor page in the user interface, and move the sticks in a single direction. Watch to see if you get jumps. If not, it's not your transmitter pots. If you do, it still might not be your pots...it could be that a connector is not secure inside the transmitter. |
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
I still love to throw down qwith the big Extra though. In fact, I just completely restored the entire plane and she's ready for another year of hard abuse. Check it out. |
Latest blog entry: Extreme Aviation Has A New Home
I got too confident with it last year at the end of the summer, doing dbl waterfalls about 15-20 feet off the ground and smacked it good. I had to repair the fuse, rebuild the motor box (replacing the cowl and prop), replacing one of the wings and the canopy. When I remaidened her, she was one click on the radio and flew like nothing had happened. I flew it with another good 3D brand yesterday, but forgot just how great this airframe flys! Lovin it, thank you Extreme Flight!
Latest blog entry: This season's 3D line up...
Joined Aug 2012
Did everyone install the switch that comes attached to the Airboss esc? The wire is a little short, where do i have to mount the esc to ensure that i can also install the switch? Also there were no screws for attaching the switch, or did i just miss em?
Sorry for so many questions ![]() Thanks in advance |
I really did not need to see this withy as tight as money is. Now I gotta have a red one too. That thing sure looks clean.
![]() Quote:
If you look on the inside of the fuselage sides, the switch holes are already cut out. You just have to cut the covering back. Quote:
Check photo............ |
If you have an older Airboss, it may not be delivering 6 volts to the servos. I would suggest you check the voltage and if it's not 6v then install a seperate BEC that is. Quote:
All the Airboss made the last couple of years are set up to run the servos on 6 volts. You get better speed and more torque, and the servos seem to last longer too, because they are not stalling, blowing back and burning out. That and the plane performs like it is supposed to.
If you have an older Airboss, a good 6 volt BEC is a good investment. Castle makes a really good one for about $25, and Motrolfly makes one for about $15 that comes pre-wired with a deans, so you just plug it in between your ESC deans and your battery deans. |
| Thread Tools | |
| Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video | hercdriver7777 | 3D Flying | 2072 | May 17, 2013 08:30 PM |
| Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video | FlopGun | 3D Flying | 249 | Apr 16, 2012 10:46 AM |
| Help! D-60 build thread | Chronic DS'er | Dynamic Soaring | 3 | Jun 23, 2011 10:04 PM |
| Sold Extreme Flight 58" Extra Ready To Fly (GA) | traderdave2 | Aircraft - Electric - Airplanes (FS/W) | 11 | Apr 26, 2011 05:33 PM |
| Video EXTREME FLIGHT RC EXTRA 300EXP in Action! | EXTREME FLIGHT | Electric Plane Talk | 1 | Jun 10, 2009 08:45 PM |
