Old Jan 26, 2013, 12:53 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by Doc Austin View Post
Looks great! Nice and shiny.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jan 26, 2013, 12:56 PM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by Manta1 View Post
the blue is really growing on me.like the red sfgs,dont like the red nose cone lol.I dont know what other color Id use tho.
I was planning to get a Great Planes spun aluminum spinner for it but never got around to it. It's like $30 by the time you get the adapter nut, so I have kinda been putting it off.
Doc Austin is offline Find More Posts by Doc Austin
Old Jan 26, 2013, 01:58 PM
Ahmd is offline
Find More Posts by Ahmd
Joined Aug 2012
Originally Posted by ecaa3d View Post
The rubber tube you cut in half then cut tubing down one side. Spread this apart and wrap around fairings. Glue in place.
To install fairings I install landing gear, mount the fairings then mark the spot on the LG where the fairing sit flush with the fuse.
Remove fairings, THen use 5 minute epoxy or another good adhesive, apply it above the mark sort of liberally but not to where it will drip too much, install fairings and tape in place. Turn the fuse over and let gravity do its thing.
Thank you, i've got it now
Ahmd is offline Find More Posts by Ahmd
Old Jan 30, 2013, 08:44 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Lots of people love the red, but that blue scheme has been one of my favorites on any plane. The fact that it's scale makes it even better. I miss the one that I sold. Maybe I'll have to get a 91 now!
DaaBears is offline Find More Posts by DaaBears
Old Jan 30, 2013, 10:06 AM
gabrielisrael is offline
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
I fly the red/blk/white scheme and really love it, but I am thinking the blue/red/white scheme might give you better overall orientation in the sky because of the red underwings vs the black.
gabrielisrael is offline Find More Posts by gabrielisrael
Old Jan 30, 2013, 01:03 PM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
It definitely pops in the sky. The contrast is great.
Old Jan 30, 2013, 10:14 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Subscribed... just got my invoice receipt form EF and hope she ships tomorrow. Gear out of my Edge (RIP) will be going in this one. Went with RBW... and hope to get it a big brother (91") this summer. Any mods recommended?
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Jan 30, 2013, 11:26 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Glad to see you getting one of these. Mine has been really awesome.
First, don't hinge the elevator too tight. I've got 65 degrees of travel and for my flying style I use every bit of it.
Depending on your batteries you might want to pick up a dubro tailwheel with aluminum hub. I'm running 6s 3850 65C packs and came out a bit nose heavy, and the tailwheel makes a big difference in the CG.
One other thing.... if you are using the standard tailwheel, don't trim off the extra wire on the tailwheel wire that the wheel itself spins on. If you do need to go to the Dubro wheel it is wider, and then you need all of that axle that's there to get the wheel and wheel collar on.
If you are using Hi Tec HS5245MG servos you almost have to reprogram the servos or the dead bands can be set anywhere from 1 to 16. The lower the number, the better. At 1 the servos center really solid, but at 16 they are awful. Even up around 5 or 6 you'll be chasing your trims all day.
That and check my blog reports for great set up photos.
Old Jan 30, 2013, 11:44 PM
Joined Oct 2011
Thanks for the heads up on the wheel, Doc. The HS-7245s from the edge will be going in the Extra running on 8.2V regulated and dead bands are already set to 1. Would strongly recommend them as they are quite a bit faster side by side with the 5245s and noticeably stronger in high speed rolls. Pricy but IMO, well worth it. I will be running 6s 3000-3300 (500-535grams) so I hope that there will be no issue with balance.
Old Jan 30, 2013, 11:55 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
good info. I was getting 720 degree per second rolls on the 5245s, but that was WOT with a 15x6. I thought that was pretty fast. Verified with slow motion video playback. Do you think a 15x8 would result in blowback?
Old Jan 31, 2013, 12:08 AM
Joined Oct 2011
I honestly don't know... but I do know you will have less of a chance of blowback with the 7245 running HV. With a 16x8 on the edge, I didn't notice any straight and level WOT... but thought I was getting some in a high speed dive.
Old Jan 31, 2013, 12:09 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
The plane is designed for 3300s, so you should be dead on, even without the dubro tailwheel.
Old Jan 31, 2013, 12:12 AM
Joined Oct 2011
Sweet, how does the extra do with the extra batt weight for low and slow... compared to the Edge and MXS?
Old Jan 31, 2013, 05:32 AM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
The extra handles the weight really well. It tracks a bit better and snaps harder but it does feel it a bit more than the others low and slow imo.
Old Jan 31, 2013, 10:05 AM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
I have 6S 4000 batteries and my Extra does great in low slow 3D.
jlloyd1995 is offline Find More Posts by jlloyd1995
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
