Old Jul 27, 2011, 01:47 PM
RickC2009 is offline
Find More Posts by RickC2009
RickC2009's Avatar
USA, NY, Brookhaven
Joined Mar 2003
Nice thread.
rickc
RickC2009 is offline Find More Posts by RickC2009
Old Jul 27, 2011, 02:35 PM
Trigger happy is offline
Find More Posts by Trigger happy
Do or die....
Trigger happy's Avatar
Sverige, Stockholms Län, Österåker
Joined Jun 2011
Originally Posted by jetinteriorguy View Post
I can fit four 60" size planes in my VW sport wagon. I made some tie downs from 2" Hook velcro by punching a half inch hole in the middle and then splitting it lengthwise from one end to to hole in the middle. Then I just put the hole around the leg of the lg and stick the solid side of the velcro to the carpetlike stuff in the back of my car and criss cross the split side and stick it to the floor. This locks the planes in place and they don't roll around when I'm driving. I don't know if this is a very good description but next time I load them up I'll take a pic and post it. And I'll also post the dimensions of the velcro.
I think im just an tad missunderstod. I have no issue to load My 60" edge and i really love it but aspire to bigger bird also, as an compliment and My practical load length is....78" so now, like 5 mins ago i ordered the 78" extra. But My wishes would be an spanking new EXP 78".
Any way...
Trigger happy is offline Find More Posts by Trigger happy
Old Jul 27, 2011, 04:04 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Originally Posted by RickC2009 View Post
Nice thread.
rickc
Thanks this going to be one awesome plane!
Any way...
I understood.. Ive been eye the 78" Extra also, But then I think? Well If I'm going 78" I might as well get a 88" Edge On Hacker 12s..
For know I can fit two 60" planes, three 48" planes and all my Gear in the Audi Avant..
I know One 88" and one 60" will fit..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Jul 27, 2011, 06:53 PM
Trill is offline
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
Anticipation
Tim,
Thanks for building this thread and keeping us posted on the 60" Extra EXP happenings. Any word on when we can order the 60" Extra EXP?
Trill is offline Find More Posts by Trill
Old Jul 27, 2011, 08:33 PM
Joined Oct 2008
Originally Posted by Trill View Post
Tim,
Thanks! It's my pleasure!
There's no official date, but it sounds like they will be available within the next two months..
Speeking of pleasure.. I just flew 6 packs threw my blue 48" Extra EXP.. No wind!, no bugs!, 70deg!, and perfect sky's!! It doesn't get any better than that..
Old Jul 27, 2011, 08:34 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Saweeeeet.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jul 27, 2011, 09:06 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Torque motors are as nice as they get! There fully serviceable unlike cheaper throw away motors. In This section, I'll be showing how to replace the bearings,and shaft in the 4016T/500 motor.. These are very tough Motors, but unfortunately I hit the LVC one day, and ended up smacking one of mine on the cement runway. Resulting in a very light noise when spinning it by hand..Fortunately Extreme flight has bearing, and shaft kits in stock. Mine didn't need a new shaft, but I decided to replace it while I was in there.
The 4016T is easily serviced for $25.00 in parts, and a little effort..
Tools:
Extreme flight shaft kit
Extreme Flight Bearing Kit
Heat Gun
2mm Allen wrench
screw driver's
4x.70 tap
bearing grease
red&Blue lock tight
small punch, small tack hammer
Soft piece of wood(Popsicle stick)
Padded surface
I like to Repair a unit like this by using heat,and cold to my advantage. When disassembling the motor, you should flash heat the 2mm set screws in order to loosen the lock tight(WARNING! When I talk about adding heat, its moderate,DON'T OVER HEAT PARTS). Also when we install the new parts, I place the new bearings, and shaft in the freezer for app 30min(this will make the metal contract). Just before assembly, heat the motor case(heating case will expand the metal) apply grease, and then install the cold bearings. By using this method the parts should slide together with little effort. After assembly, Set these parts aside and let them reach room temp, before proceeding
Great post. I got a couple to replace after tonight's flying!
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jul 27, 2011, 09:34 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Enjoy the great weather and the great flying! There was little to no wind here in the Nashville, TN today. However, the temperature was 95 with high humidity and a heat index over 100.
Old Jul 27, 2011, 09:48 PM
Joined Oct 2008
Thanks! Glad I could help!
Old Jul 27, 2011, 11:23 PM
Doc Austin is offline
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Thanks to Extreme Flight's EXP's, my flying has never looked better!
I was thinking the exact same thing.
Doc Austin is offline Find More Posts by Doc Austin
Old Jul 27, 2011, 11:49 PM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
Spektrum makes me look better!!!
powerlines is offline Find More Posts by powerlines
Old Jul 28, 2011, 02:21 AM
SpartanExec is offline
Find More Posts by SpartanExec
Extreme Flight Minion
SpartanExec's Avatar
United States, OR, Happy Valley
Joined Nov 2010
DX8 Brah!
SpartanExec is offline Find More Posts by SpartanExec
Old Jul 28, 2011, 09:44 AM
mxcop is offline
Find More Posts by mxcop
TEAM EXTREME / HORIZON HOBBY
mxcop's Avatar
United States, NJ, Tuckerton
Joined Oct 2006
The new line of 60" EXP's are amazing, and the Extra is the best flying plane in that size range I've flown!! Can't wait for it to be here in the states, Chris did his homework with these planes. Tim, you're so close, only a state away, it would be cool if we could get together and fly some time again.
Lee
mxcop is offline Find More Posts by mxcop
Old Jul 28, 2011, 10:30 AM
P-51C is offline
Find More Posts by P-51C
Reserved Parking
P-51C's Avatar
Joined Jun 2004
I would like the second scheme to be the red/black/yellow like on the 48" edge.
Or r/b/y scheme but with orange/metallic dark purple/white instead.
P-51C is offline Find More Posts by P-51C
Old Jul 28, 2011, 10:54 AM
Trill is offline
Trill's Avatar
Joined Oct 2008
+1 Yes, the red, black, and yellow scheme would look great on the 60" Extra EXP!
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2593 Feb 07, 2016 11:38 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 11:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 11:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 06:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 09:45 PM
