Old Nov 02, 2012, 07:25 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Originally Posted by ecaa3d View Post
Had a lucky servo failure today.
Did a pop top and the elevator stuck in down position. Started doing repeated waterfalls, I gave a bit of throttle to keep it going until I got close to the Scotch Broom and she laid right on her back, came out with hardly a scratch, nothing a bit of wax won't fix.
Looking for a new better, stronger, quicker replacement than the 5245.
The Savox are working good in the 48 Edge, only 9-10 flights so far though.
Great save!
High voltage:
Hitec 7245 - fast, bulleproof, strong.
Futaba S9070 - so far they have been bulletproof, insane power (probably a bit more than the 7245), slightly better centering/resolution than the 7245.
JR 3711 - I haven't run them but they look really nice. My friend reports the same type of performance as the S9070's...great power and centering but not quite as quick as the Hitecs. I think I will try them in the 60" Laser.
6V:
Airtronics 94820: bulletproof, plenty of power, great centering and resolution, slow.
cwojcik is offline Find More Posts by cwojcik
Old Nov 02, 2012, 08:50 AM
racerboy65 is offline
Find More Posts by racerboy65
United States, WI, Fond du Lac
Joined Sep 2011
Hello all, man trying to figure out which plane to buy next is difficult these days so many good ones to choose from. Looking at either a 59 slick or a EF60 extra or edge. I have been doing some reading and still am searching for the difference between the EF edge and extra. Many thanks for any help
racerboy65 is offline Find More Posts by racerboy65
Old Nov 02, 2012, 09:07 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
There are a lot of good options out there for sure!
The Edge and Extra are different but both are capable of great precision and great 3D. The Extra feels a little bit more "immediate" in its control reactions...it responds very quickly and precisely. It can be a bit surprising when you fist fly it until you realize that the plane is not hard to fly and has no bad habits at all. It's very capable of every 3D maneuver and has zero wing rock in harrier. The Edge is different. It feels more sedate and gentle, and gives you a little bit more time to think and react. It's one of the easiest planes to 3D out there. If you go to low rates and step up the speed a little bit it will hang with the best of them in precision flight as well.
The 59" Slick is also a great plane and similar in control feel to the Extra. However, I find that the longer tail moment of the Extra makes for cleaner snaps and tracking is a little bit better. Most of the 59" Slicks that I flew were underpowered though so it's difficult to make a good judgement for certain. I do know that I love my Extra and would recommend it to anybody.
Old Nov 02, 2012, 10:25 AM
VR Eyedoc is online now
Find More Posts by VR Eyedoc
Hardcore EP 3D Flyer
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
Originally Posted by cwojcik View Post
Great save!
High voltage:
6V:
I am also inerested in Futaba S9070, but the dimensions are different from that of Hitec 5245/7245. how did you modify the servo bays?
VR Eyedoc is online now Find More Posts by VR Eyedoc
Old Nov 02, 2012, 10:49 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
You need to enlarge the holes a little bit. The servo is a bit wider and longer but it is shorter. I used an X-acto with a few sharp blades and a bit of patience. There are some pictures in the MXS build thread: http://www.rcgroups.com/forums/showthread.php?t=1738825
Old Nov 02, 2012, 11:12 AM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
I own the Extra but was able to fly the Edge about ten times. The Edge is actually better at certain tumbles than the extra, and it was a little easier with some 3D but not much. The Extra is more aggressive in high speed precision. The Extra is my preference, but they're both great airplanes.
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Nov 02, 2012, 01:13 PM
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
thx! it doesn't look very hard. I will give it a try.
Old Nov 02, 2012, 02:58 PM
m0dest is offline
Find More Posts by m0dest
aka ECAA3D
m0dest's Avatar
United States, WA, Olympia
Joined Apr 2012
Great save!
High voltage:
6V:
Thanks Cody!!
I plan on going HV shortly. Looks like it's going to be 7245s all around.
The 5245s worked great. The Extra being my first real balsa plane they've held up pretty good. I played around with with end points, happened on my 2nd flight after adjustment so who knows. I don't think I set the servos too far out but I may have...then again it may have just worn out.
Trying to save a bit of coinage for a 30%. Got a 48" Edge and I throw the 60" around just as low as the 48" so I'm leaning towards a larger aircraft.
m0dest is offline Find More Posts by m0dest
Old Nov 02, 2012, 03:30 PM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Thanks Cody!!
No problem! If you are on a budget and want a bigger plane, the 78" Extra flies better than most 50cc planes on the market.
Old Nov 02, 2012, 03:47 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
This really depends on your flying style and skill. They extra tracks better than the edge and snaps more cleanly, but it is noticeably more difficult to pull of certain 3d with. The edge is like a 3d trainer, very smooth, slow, and rock solid in harrier. If you are a very experienced pilot, you can't go wrong with either one, but the extra will probably be more of a broad spectrum aircraft than the edge would. I'm intermediate and I owned both the edge and the extra and hands down I preferred the edge! The same goes for the slicks, the 59 flies more like an extra, the others 3d much better. My 51" and 71" slicks are two of my all time favorites, but the 59 I wasn't a fan of at all... Just my personal opinion being a hardcore 3d intermediate pilot!
DaaBears is offline Find More Posts by DaaBears
Old Nov 02, 2012, 06:43 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I have the Extra, and the Edge, and the MXS. I don't regret buying the Extra first. Great plane. As is the MXS. I haven't flown the Edge yet.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Nov 02, 2012, 07:01 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I think you'll find the Edge to be easier and more floaty than the other two.
Doc Austin is online now Find More Posts by Doc Austin
Old Nov 02, 2012, 07:17 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
That is what I heard and expect.
Old Nov 03, 2012, 08:55 AM
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
I put a Turnigy Sk3 5045 450KV motor on my EF Extra 300. with Xoar 16X8 on 6S, it only draws 52 amp, around 1200W. There is a review saying the actual kv of the motor is probably lower than 450. and the motor is rated as 7s on HK website.
Has anybody tried 7S setup with this motor? I have some matching 4S and 3S lipo sitting around. I think I am gonna upgrade my ESC first then give it a try.it's so tempting! may have to downprop to 15X8 though.
Old Nov 03, 2012, 11:35 AM
long leng is offline
Find More Posts by long leng
zürich
Joined Jun 2008
the extra is just so much better than the edge, imho.
set it up light and she is as high-alpha as you want.
long leng is offline Find More Posts by long leng
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2631 Aug 04, 2016 12:00 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
