Old Oct 26, 2012, 09:23 AM
Doc Austin is online now
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by LoneWolfRC View Post
IThe MKII motor is worth the wait, but then you might miss out on the airframe since you probably want the combo deal.
When you order the airframe, tell them you wnat the combo, and when the power system comes in you'll get it at the combo price. Just call Curtis and he'll take care of you.
Doc Austin is online now Find More Posts by Doc Austin
Old Oct 26, 2012, 09:56 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
That is what I guessed, but I figured it was for EF to say. Thanks for the clarification.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Oct 26, 2012, 05:59 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
My 60" Extra has taken a real beating. If you have seen any of our later videos you'll see that I cut her no slack. I just went completely through the entire airplane checking everything, tightening the covering and scrubbing her clean. If I get a new set of SFGs she'de look like a brand new plane.
I have not had a chance to fly this plane recently, so I am really looking forward to flying it hard again soom.
Old Oct 26, 2012, 06:23 PM
danielph is offline
Find More Posts by danielph
TEAM EXTREME!
danielph's Avatar
High Prairie, WA
Joined Nov 2007
She looks great Doc! I cut mine no slack either and it takes everything that I throw at it with stride!
danielph is offline Find More Posts by danielph
Old Oct 26, 2012, 08:44 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
They is tough, smacked mine good into the ground last week attempting harrier turn around way too close to the ground and stalled three pointer into the deck.
Broke the prop, cracked a wheel pant and pulled bottom rudder hinge out of the wood.
20 minutes and she is back and flying sweet as ever.
I much prefer my extra to my 60" edge for straight lines and general 3D. The edge is still my most unloved and hucked of the two, but its really showing its age.
I use my edge these days when club visitors want to see what a violent 3D plane can do.
bigroger is offline Find More Posts by bigroger
Old Oct 26, 2012, 08:48 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Looks pretty new DA.
Old Oct 26, 2012, 10:02 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Amazing, isn't it? This plane spent most of late spring and summer flying a prototype Torque 4015/500 motor. I had to fly it hard every time out to try to break the motor so this plane has been pretty thoroughly thrashed.
I am so pleased with how it cleaned up it that I am going to order a new set of SFGs and wheel pants for it. Then it will look absolutely brand new. I thought I would lose interest in this plane when the 60" MXS came out, but I guess I am a little weird for Extras.
The right SFG gets it the worst because I like to slow roll on take off and drag it a little on the ground. Once or twice I've held it there a little too long and scraped off some wood so that one is looking pretty ratty. I've recovered the tip a few times but now it's getting to be visibly shorter than the left one and might be getting to where it effects the flying. Worse still is the vinyl decal for the SFGs are about $8 apiece!
Pardonnez-moi and Excusez-moi if you have seen this before, but here's our last 60" Extra EXP video..........
Old Oct 26, 2012, 11:00 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Did you go 16x8 on the motor all summer?
Old Oct 27, 2012, 10:30 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Oh, no. I ran the APC with a few times but I had to be careful with it. I've since switched to Xoar 16/8 and it rips on that. We did a lot of different things with props and motors this summer and the Torque 4016/500 Mk II with a Xoar 16/8 was the best and most reliable performer.
Old Oct 28, 2012, 07:46 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
I've got about 80 flights on mine swinging a xoar 16x8 pjn.. The MKII has taken everything I've thrown at, and more! V1 was great, but the 4016T/500 MKII is amazing, and so far it's bullet prof with the Xoar 16x8.. I wouldn't run a APC 16" the amp draw is much higher, than the identical xoar.
If you can't get a xoar, I would probably run a APC 16x7, but always check your numbers with a watt metter to conferm!
We had the most gorgeous day at the club! 5mph wind, sunny and 70deg..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Oct 28, 2012, 12:01 PM
HELLFIRE989 is offline
Find More Posts by HELLFIRE989
Smokin out the pits!!!
HELLFIRE989's Avatar
Kelowna, BC, Canada
Joined Dec 2008
These xoar props you guys are running, are they the standard series or the electric version?
HELLFIRE989 is offline Find More Posts by HELLFIRE989
Old Oct 28, 2012, 12:03 PM
Joined Oct 2008
Pjn (electric)
Old Oct 28, 2012, 12:46 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
This is my fav; http://www.espritmodel.com/xoar-prop...hite-pjmw.aspx
Coming soon of course.
Buzzed is offline Find More Posts by Buzzed
Old Oct 28, 2012, 01:11 PM
Joined Oct 2008
Very cool! I needed a hs35 for a indoor plane, so I just ordered it from them and I grabbed a white pjn for my 48" laser..
Old Oct 28, 2012, 01:52 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
That is called the calm before the storm. The entire week we were below 5mph wind and 75+ down here in GA. Of course I have yet to find my run to field just for a quick afternoon session.
livinma1 is offline Find More Posts by livinma1
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2593 Feb 07, 2016 11:38 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 11:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 11:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 06:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 09:45 PM
