Old Sep 26, 2012, 11:12 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Originally Posted by magoo308 View Post
already gearing up to buy this plane.
just want to ask you all.
for 3D flying MODE 1 or MODE 2 are better.
Im flying MODE 1 and find it quite difficult to do fast continous roll.
any thoughts?
Thanx
Mode 2 is more like a full scale plane with roll and pitch being on the same stick.
hone1er is offline Find More Posts by hone1er
Old Sep 27, 2012, 12:52 AM
baumerm is offline
Find More Posts by baumerm
baumerm's Avatar
USA, OR, Carlton
Joined Aug 2009
Originally Posted by LoneWolfRC View Post
I don't know but I heard it is easier to do a rolling harrier in mode 1.
I fly mode 1 (because I learned to fly RC in Europe) and I think it makes rolling slightly easier. For harrier rolls I just end up moving my rudder/elevator stick in a circular/oval fashion. For fast rolls there might not be that much difference because I'd use mostly top rudder and little elevator.
I think continuous rolls are more difficult than they look in either mode.
Martin
baumerm is offline Find More Posts by baumerm
Old Sep 27, 2012, 11:09 AM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
thanks for the info i will try it later today and see what i get
I believe lower, but I haven't had the problem myself, just read about it after a friend built a target mig and had the problem with his motor--but he switched motors before we could experiment.
The programming manual can be found here: airboss programming manual...of course, take the prop off while programming.
Just try restoring to factory defaults first.
kremecheze is offline Find More Posts by kremecheze
Old Sep 27, 2012, 06:13 PM
livinma1 is online now
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Kareem send it my way. I will get her working well for you.
livinma1 is online now Find More Posts by livinma1
Old Sep 27, 2012, 06:18 PM
kremecheze's Avatar
Joined Jun 2007
ha i'm sure you would love that...this ones staying in my hanger for a long time, knew she was a keeper after the first flight..she's big enough to take to the field, small enough and light enough to take to the park and easy to store...keeper!
Old Sep 28, 2012, 05:00 PM
Lappster is offline
Find More Posts by Lappster
HuckMeister
Joined Sep 2004
I know there has been talk about props but I'm too lazy to look back
what are you doing on 6s with the torque setup? I started with a 15x6 and it wasnt great, just tried a 16x8 paintstick and it was an incredible difference but loaded the packs a bit much. Any thoughts of a 16x7 falcon or 15x8ish?
thanks in advance
t
Lappster is offline Find More Posts by Lappster
Old Sep 28, 2012, 05:13 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I'm running a 16/8 on mine but I am considering trying a 16/7 just because I don't need so much power and would like to take a little less out of the battery each flight.
Doc Austin is online now Find More Posts by Doc Austin
Old Sep 28, 2012, 09:47 PM
Lappster is offline
HuckMeister
Joined Sep 2004
ok am i losing it or was there not just a 16x7 on their website about suppertime!!! I went to order some and they are not there now.
Thanks Doc, I thought thats what you were running. I went 6.5min on 3300's tonite, just charging them back up to see where I was at. Flew them pretty hard, they were about +20 when I landed, motor was warm but not hot. It is a POS woodie I had, power point or something but better than nothing. You running the falcon or the xoar?
t
Old Sep 28, 2012, 11:47 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I've been running the Zoar, but I've also got a Falcon to try out.
My 60" MXS has a production 4016/500 MK II, and it's bad ass ballistic. These new 4016s rock.
Old Oct 01, 2012, 07:27 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
had some fun with the extra today, it was really hot and for some reason I just didn't feel locked in like I usually do with this airframe, but still one of my favs
60" Extreme Flight Extra (6 min 54 sec)
3drcparts is offline Find More Posts by 3drcparts
Old Oct 05, 2012, 12:46 PM
DonEmmel is online now
Find More Posts by DonEmmel
Joined Sep 2008
What is the best prop size and pitch to use on this plane when learning to hover?
DonEmmel is online now Find More Posts by DonEmmel
Old Oct 05, 2012, 12:56 PM
fmidgett is offline
Find More Posts by fmidgett
fmidgett's Avatar
Durham NC
Joined Jul 2004
Experts may give you specific advise but i wanted to share that in general the larger the prop the easier to hover. The larger 'disc" has a greater gyroscopic effect which helps you hover more easily. It will also make tumbles slower for the same reason. On my 48" planes I found them much easier to hover on 13x7 3s versus 12x6 4s.
fmidgett is offline Find More Posts by fmidgett
Site Sponsor
Old Oct 05, 2012, 01:33 PM
cwojcik is online now
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Fred is right...I think a 16x7 or 16x6 would be a good choice on the V2 motor.
cwojcik is online now Find More Posts by cwojcik
Old Oct 05, 2012, 02:05 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
https://vimeo.com/50572552
Looks pretty locked in to me.
Old Oct 05, 2012, 02:49 PM
long leng is offline
Find More Posts by long leng
zürich
Joined Jun 2008
biggest prop i flew the extra was a 17,5 x 8.
best for tight maneuvers, best for torquerolling. very easy to hover apart the fact that the extra wanted to roll strongly. needed almost full aileron to hold against
in relation to your question: a very bad prop to LEARN to hover.
16x7 xoar is a lovely prop for the extra. very good for constant middle speed, makes all rotations feel soft, very controlable feeling overall.
downside is....its a break for flying fast and big.....and also, it wants to torque.
15x7 is my favorite allround prop.
very clean feeling. hovers clean and easy.
i just want to mention, its not that the bigger the prop is the easier it gets.
then again....i would never recomend the extra60 to learn to hover.
addiction x for example is a zillion times easier.
long leng is offline Find More Posts by long leng
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
