Old May 07, 2012, 03:45 AM
Royster is offline
Find More Posts by Royster
Fly Big, Fly Hard!
Royster's Avatar
Brisbane, Australia
Joined Jan 2007
Originally Posted by _OZ_ View Post
I've done that before. They are standardized parts. So, it will work fine.
OK cool
I will add the new wings when I get spare time in the workshop (yeah right)
Royster is offline Find More Posts by Royster
Old May 07, 2012, 07:15 AM
evalith8 is offline
Find More Posts by evalith8
Let the hating begin
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
I had to send mt esc to castle for repair or maybe replacement.Me & a friend were flying at an airshow last weekend & in the middle of a knife edge circle the motor quit.I got it down & disconnected the battery,hooked it back up & the servos stopped working as well.Bypassed the bec the rx worked.The esc wouldnt arm,motor wouldnt work & bec is fried.Castle has it now & I hope to get it back soon(ice lite 100)Ive only had the extra for about 3 weeks so I robbed the esc & bec from my 60 edge so I could fly it.Id say between the 2 I like the extra a bit more.Rolls faster & feels a bit more crisp compared to the edge.
evalith8 is offline Find More Posts by evalith8
Old May 07, 2012, 09:48 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by janole View Post
Keep flying it, it takes a while to dial in a new airframe, I'm up to 16 flights on mine and starting to love it,
I find KE spins to be ridiculously easy on this, way easier than the slick to lock in, pop tops not as good, blenders are good, but no where near as violent and cool as on my 51" slick, KE easy peasy, parachutes are fantastic, way better than the slick, harriers are about even, hovers go to the slick.
I'm really loving the power this one has and once I get 100+ flights I sure I will have it lock in, that is about what it takes me to get truly comfortable on a new airframe
Thanks for the feedback. What servos are you using?
try the 16x8
On what motor? I have the recommended torque motor.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old May 07, 2012, 09:54 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Do not use the 16x8 with the torque.
15x7 and 15x8 should give you what you need. 15x6 sounds a bit weak.
DaaBears is offline Find More Posts by DaaBears
Old May 07, 2012, 10:04 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Originally Posted by evalith8 View Post
I had to send mt esc to castle for repair or maybe replacement.Me & a friend were flying at an airshow last weekend & in the middle of a knife edge circle the motor quit.I got it down & disconnected the battery,hooked it back up & the servos stopped working as well.Bypassed the bec the rx worked.The esc wouldn't arm,motor wouldn't work & bec is fried.Castle has it now & I hope to get it back soon(ice lite 100)Ive only had the extra for about 3 weeks so I robbed the esc & bec from my 60 edge so I could fly it.Id say between the 2 I like the extra a bit more.Rolls faster & feels a bit more crisp compared to the edge.
That sucks! I just received my HV80 back from warranty service, and they also have my thunder bird9 esc(failed BEC).. every time i send them a warranty part it takes at least 2-3months to receive it back..I don't wait for them to turn it around. I replace it, and sell the repaired, or replaced one. when it finally comes back.
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old May 07, 2012, 10:23 AM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
That sucks!!!!!I thought I would get it this week.I guess its time to start blowing the phone up
Old May 07, 2012, 10:46 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
HS5245
Motrolfly 4315-480
3drcparts is offline Find More Posts by 3drcparts
Old May 07, 2012, 12:01 PM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
If you don't want/can't get the Torque, the Motrolfly 4315 is awesome in this airframe. I'm running mine on 4s 4000 with a 15x7 (79 amps 1155 watts). It was 80 degrees yesterday and my motor was coming down at 90-95 degrees after 5-6 minutes of hard flying.
6L6Amp is offline Find More Posts by 6L6Amp
Old May 07, 2012, 12:07 PM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
so under 1200 watts is enough on a 60 exp with a 4S setup?
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old May 07, 2012, 12:10 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
4315-480 on 6s and 16x8, 1535 watts at 72 amps doesn't just have unlimited vertical, it will continue to accelerate vertically until you can not see it, comes down cool and is super efficient
Old May 07, 2012, 12:14 PM
6L6Amp is offline
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
The power to weight ratio is around 2:1. It's a rocket.
Old May 07, 2012, 12:18 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
1200 should be more than enough, I'm rarely at full throttle
Old May 07, 2012, 12:26 PM
Epoxy & CA Investor
Joined May 2010
ok, good to know. I'm planning to use 4000 4s Gens with Motrofly 4315 with the new 60 MXS. I know it's meant for 6S, but I don't want to get into yet another set of batteries.
Old May 07, 2012, 12:29 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
just make sure you get the correct kv
daedalusrobert is offline
Find More Posts by daedalusrobert
daedalusrobert's Avatar
United States, GA, Valdosta
Joined Jan 2009
Buy 2S packs...you can run them in series with your 4S packs to make 6S or run them in series to make 4S packs...much more flexible this way if you have planes that run 4S.
daedalusrobert is offline Find More Posts by daedalusrobert
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2593 Feb 07, 2016 11:38 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 11:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 11:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 06:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 09:45 PM
