Old Apr 27, 2012, 11:25 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Doc - are you just posting the URL or the whole embed code?
As a test, I just snagged the embed code and pasted it below.
<iframe src="http://player.vimeo.com/video/41128284" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
Edit - that didn't work so trying the URL only.
Extra EXP 60__Test 002 (4 min 5 sec)
Edit 2 - that doesn't work either. I suspect that RCG has made a code change and are no longer auto converting the vimeo URL's to an embedded video player.
JC Spohr is offline Find More Posts by JC Spohr
Old Apr 27, 2012, 11:35 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Older videos still show up as a video window. I think the problem is Vimeo. They changed their uploader and format and everything. This happened before and it corrected itself, but this time it has been going on for a few days.
Doc Austin is offline Find More Posts by Doc Austin
Old Apr 27, 2012, 07:09 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Maiden went well, I got 5 5 minute flights with a 15x8 xoar prop on motrolfly 4315, only put back 1300-1400 back in my packs.
It's a bit early to say I love it as I'm more comfortable with my 51" slick, but what I did love was, KE, KE spins, elevators and harriers, what I didn't quite feel comfortable with was walls and hovering. Elevator authority is insane, need to dial it back a bit until I get used to it. It had a tendency to roll out or pitch left when doing a wall, might have been my thumbs, but I noticed it repeatedly and it bugged me. It also was hard to get to lock into a hover, I'm going to try a 16x8 next time. It was also a bit windy, but overall it was a blast and super easy to land
3drcparts is offline Find More Posts by 3drcparts
Old Apr 27, 2012, 07:44 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Woo Hoo!
My Torque 4016T-500 and Airboss Elite 80A arrived today.
Big shout out and MEGA thanks to Melissa at Extreme Flight RC. She was running the show while the boys played at SEFF.
I called Wednesday morning because Tuesday night (late night) Chris H. PM'ed me that the ESC's were back in stock along with the motor. It's Friday now, so in 2 days from call to receipt, I have my power system.
I also got my servos today. Four Hyperion DS16FMD's plus a programmer.
Batteries have an ETA of Monday so, I plan to maiden it in a week (next Saturday).
Thanks again to the team at Extreme Flight RC for producing such great aircraft and providing "Extreme" customer service!
JC
ps - Now that I think about, I suspect Melissa is always running the show.
Old Apr 27, 2012, 07:47 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
Woo Hoo!
JC
right there with you, ordered the motor wed. around 11am and it was on my doorstep thursday morning....along with my motolfly motor lol
shadow102 is offline Find More Posts by shadow102
Old Apr 27, 2012, 09:05 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Congrats. I still haven't put my Airboss ESC in my plane. What is the proper power up procedure vis. a vis. the switch, especially if you use an external ESC (not that an external ESC is necessary). Can you have the switch on when you connect the battery?
Does the switch control only the internal BEC and throttle signal reception from the receiver? If so, using an external ESC may be bad, especially if the ESC requires the switch to be off when the battery is connected.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Apr 27, 2012, 09:22 PM
shadow102's Avatar
Joined Mar 2011
I think the switch on my 45A airboss completely interrupts any power from entering the ESC because i get no motor response when i plug in the battery and then the whole system arms when i throw the switch.
However alot of people are against switched because they are weak point and the cause of many in flight failures if they go bad.
Old Apr 27, 2012, 10:40 PM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
I'm one of those people. A single switch just seems so vulnerable to me. I have an external BEC hooked up directly to the battery, straight to the RX and it's working great.
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Apr 27, 2012, 11:13 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Could you cut the switch, and solder the wires?
Old Apr 27, 2012, 11:35 PM
jlloyd1995's Avatar
Joined Oct 2010
Yes. That works great.
Old Apr 28, 2012, 12:38 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
OK, straight out of the land of Bizzarro, now Vimeo links are working again.
These videos were from when I was only getting 35 degrees of elevator movement. Now I am getting 65 degrees and I am much, much more comfortable and confident with the plane. We are hoping to snag some new video next week, but for now these are not too bad........
Extra EXP 60__Test 001 (4 min 13 sec)
Old Apr 28, 2012, 02:51 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Here's a quick picture of the spacers I used for my motrofly motor.
I have the fiberglass mount with 25mm M4 screws and 1/2" aluminum spacers with washers to spread the load on the mount.
DaaBears is offline Find More Posts by DaaBears
Old Apr 28, 2012, 02:58 PM
shadow102's Avatar
Joined Mar 2011
check the operation before you solder them together, most esc switches i know of are open = on
Old Apr 28, 2012, 04:06 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I'm not sure I will do it, but you bring up a good point. Thanks.
Old Apr 28, 2012, 10:57 PM
jlloyd1995's Avatar
Joined Oct 2010
I'm pretty sure the Airboss is on if the wires are soldered but no harm in checking.
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2631 Aug 04, 2016 12:00 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
