Old Apr 21, 2012, 09:06 PM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
Originally Posted by frugalme View Post
Exactly. Otherwise the airflow slows (stagnates) as it expands after entering the cowl. Go to the airport and check out the engine baffling on the Cessnas, etc. Exit area needs to be twice the inlet area for good flow.
And it is without cutting holes (except for the vent on the bottom of course). But than again, electronics don't send off nearly as much heat as gas engines.
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Apr 21, 2012, 10:57 PM
Dennis Everett is online now
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
Flew the maiden today , went off without a hitch , as i thought , each flight i moved the battery back , i think its pretty close now , inverted dives just a tiny bit , longest flight was 6.5 minutes took 3200 of a 4000 pack , good speed and power , knife edges are crazy easy , flat spins pretty good once i got the cg better , i left the covering on the firewall as suggested except i opened one hole up to feed the speed control wire through , i tried the flap/elevator mix with 50 % flap , didnt impress me , might up the % tomorrow and see what it does ....
Dennis Everett is online now Find More Posts by Dennis Everett
Old Apr 21, 2012, 11:05 PM
jlloyd1995's Avatar
Joined Oct 2010
You must use lots of throttle. After 8 minutes I was putting back about 3000 so I bumped it down to 7.
Old Apr 21, 2012, 11:16 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Are you using the SFGs? I will maiden tomorrow if the weather holds out. Thanks, and congrats on your maiden, Dennis
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Apr 22, 2012, 09:16 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Maiden went well. I'm still learning the plane, but so far, so good. I had the COG at the mid point of the manual's recommendation. I think I will want to move it back some, or play with the expo settings. I was able to pull some inverted flat spins, KE spins, knife edges, one smooth, flat, level roll, one almost but not quite perfect loop, harriers, and many more unpolished moves.
All in all, I like the plane. It is not as easy to fly as my 48" 3DHS super vyper, but they are different designs, I am really getting used to the 3DHS SV, and I used a heavier than recommended battery in the extra. I am sure that I'll be loving this plane after I run some more batteries through her and get her balanced and expod to my liking. I certainly don't regret buying this plane, and if I could do it over again, I'd still buy it.
Great plane, lots of fun. I'll post a video if anybody is interested in an ametuer.
Old Apr 22, 2012, 10:08 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Cool, A video would be great
3drcparts is offline Find More Posts by 3drcparts
Old Apr 22, 2012, 10:12 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by janole View Post
Cool video would be great
I'm still uploading the video, but here it is:
http://www.youtube.com/watch?v=jtZA80qcspM
It should take about 4 more hours maximum to complete the upload. (DSL feels like a 9600 baud modem when you're uploading a video).
Old Apr 23, 2012, 07:20 AM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
Well I remaidened my extra 300 this weekend it was freakin sweet! i swapped out the Extreme flight motor for a Motrofly. not because i did not like the motor, but I have this motor in my 60 Edge so I wanted them to both feel about the same when flying. I was having a problem holding a knife edge. not sure if I am going too slow or not enough rudder, or if it is just something I need to work harder on,
bigmoebbq is offline Find More Posts by bigmoebbq
Old Apr 23, 2012, 08:34 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
If you mean that you are losing altitude in KE, remember that altitude in KE is controlled by throttle not rudder.
Add throttle to control KE ascent or descent.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Apr 23, 2012, 08:42 AM
bigmoebbq's Avatar
Joined Mar 2008
yes altitude was the issue. It kept dropping on my much faster then I had hoped.
Old Apr 23, 2012, 08:47 AM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Some thoughts to help you...
Set your angle of attack with rudder and then use throttle to control the altitude.
High speed passes use lower AOA, slow KE requires higher AOA.
SFG's make a difference.
Sunny blue skies are deluxe!
JC
Old Apr 23, 2012, 10:10 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
nice maiden, looking good,
My extra is due today and the rest of the parts needed in the next few days, can't wait
Old Apr 23, 2012, 10:20 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Living off these posts for now as mine is scheduled for delivery tomorrow. Per the "significant other," I can open the box to inspect for damage but no assembling until after the birthday cause I've already got one, two many toys that I'm not playing with.
chopper62 is offline Find More Posts by chopper62
Old Apr 23, 2012, 10:38 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks. I actually think it was better than I felt at the time. When I flew, I had a cold, was on cold medicine, and wasn't in the best frame of mind. So considering, it went really well.
Old Apr 23, 2012, 11:55 AM
kellyzo6 is offline
Find More Posts by kellyzo6
kellyzo6's Avatar
United States, VA, Berryville
Joined May 2010
Your in the same boat as I. Wife got mine last week and have to wait untill the end of May for my birthday.
kellyzo6 is offline Find More Posts by kellyzo6
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2631 Aug 04, 2016 12:00 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
