Old Apr 20, 2012, 05:25 PM
_OZ_ is online now
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Based on:
4016T-500, 280 gr, 80 amp burst (20 sec), 6mm
I would say:
Scorpion S-4020-14, 297 Grams, 80 Amps
Hacker A40-14S V2 14-Pole - 530 kv 207gr, 70A
OR
Hacker A40-14L V2 14-Pole - 355kv - max 70A, 272gr, 70A
_OZ_ is online now Find More Posts by _OZ_
Old Apr 20, 2012, 06:07 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Elevator to spoileron mix
Page 27 of the manual talks about this mix. Anybody ever try it? Got videos of it?
Another neat set-up is to try to mix the ailerons to act as spoilerons which move in conjunction with your elevator. This mix commands both ailerons to rais as the elevator raises. I typically use this mix at 100% and put it on a switch so I can turn it on when needed and inhibit it when not needed. Some folks feel this type of mix is somehow taboo. To them I say "open your mind"! Anything that enhances flight characteristics or allows me to perform maneuvers that are otherwise not possible I am totally game to try! This mix allows the most straight down dropping elevators you will ever encounter, insane walls that gain no altitude where the tail of the aircraft is basically thrown under the fuselage and the tightest KE spins I've ever seen.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Apr 20, 2012, 06:51 PM
nsg is offline
nsg
Find More Posts by nsg
nsg
Yardley, PA
Joined Sep 2006
I have that mix on all my EF planes. I rarely use it (the plane flies too weird), but the elevators do look good.
Maidened my EF Extra today, and liked that (I do realize the latter is not a very original statement).
Hyperion HP-Z4020-16 (virtually the same as the recommended Torque), Castle ICE75 Light, 5s4000mah, 16x8 Xoar Hyperion DS16FMD all around.
nsg is offline Find More Posts by nsg
Old Apr 20, 2012, 06:56 PM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Tried it once - plane was scary as hell I guess for the better pilots no biggie...but for the guys well below them - an EF on spoilerons is funky to say the least...
Space Bat is offline Find More Posts by Space Bat
Old Apr 20, 2012, 07:03 PM
nsg is offline
nsg
nsg
Yardley, PA
Joined Sep 2006
scary is right, esp. on full throws.
Old Apr 20, 2012, 08:03 PM
GetSome! is offline
Find More Posts by GetSome!
GetSome!'s Avatar
United States, CA, Roseville
Joined Jan 2011
I tried it on another plane that had some wing rock..fixed it. Then I forgot to turn it off and got into a low KE...toothpicks!!!
GetSome! is offline Find More Posts by GetSome!
Old Apr 20, 2012, 08:27 PM
Arctic is offline
Find More Posts by Arctic
United States, KY, Louisville
Joined Mar 2006
N6145k, I mounted the aileron linkages on the underside, and rudder linkage on the back side of the servo arm, and I am getting max deflection with zero binding.
Arctic is offline Find More Posts by Arctic
Old Apr 20, 2012, 08:50 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Originally Posted by _OZ_ View Post
Based on:
I would say:
OR
Thanks Oz.
chopper62 is offline Find More Posts by chopper62
Old Apr 20, 2012, 09:30 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks artic on your feedback...
regarding the mix, I just tried it in phoenix...I think I'll practice in the sim before doing it on a real plane.
Old Apr 20, 2012, 11:04 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
I put the washer on the outside of the ball link , it is possible if the ball were to come off the link for the screw head to fit past the link , with the washer it cant come off .
The exceed proton speed control is made by hobby wing , same as the turnigy plush and many others , its bullet proof , ive toasted many a castle speed control but never a hobby wing .
Does anyone open up any of the monocoted holes in the firewall to let more air in to cool stuff ?
Mines done , maiden tomorrow , i have the elevator/flap mix set , ill let ya know how it goes , with the 4 in cg , i had to move the 4 s 4000 WAY foreward , almost needs a pull pull setup with this motor , im guessing ill move the cg a bunch ...
Dennis Everett is offline Find More Posts by Dennis Everett
Old Apr 20, 2012, 11:19 PM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
Rather than making more air holes, make baffling too direct the air over the ESC. That's what I did anyway.
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Apr 21, 2012, 08:20 AM
evalith8 is offline
Find More Posts by evalith8
Let the hating begin
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
My first Extra (rip) didnt have the ultracote firewall nor does my 60 Edge.The Extra I just built did have it,I cut holes in it just like the others.My 59 Slick & 70 EF Extra has the holes so thats how Im rollin.
evalith8 is offline Find More Posts by evalith8
Old Apr 21, 2012, 11:03 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Someone asked about the 60" Extra and cutting the Ultracote on the FW a few months ago.
The answer from Extreme Flight was leave it as is. It is designed that way and does direct more air over the ESC if mounted as suggested.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Apr 21, 2012, 01:41 PM
frugalme is offline
Find More Posts by frugalme
Joined Nov 2007
Exactly. Otherwise the airflow slows (stagnates) as it expands after entering the cowl. Go to the airport and check out the engine baffling on the Cessnas, etc. Exit area needs to be twice the inlet area for good flow.
frugalme is offline Find More Posts by frugalme
Old Apr 21, 2012, 06:20 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks to the folks at Extreme Flight
I had a problem last week with an ESC. Sent it in on Monday. In spite of Curtis and Chris being very busy--this is a small business, after all, with SEEF and a big sale recently completed--they were able to get the ESC back to me in time for my maiden tomorrow. (To be honest, I was hoping to maiden today, but the weather is pretty crappy...lots of rain, cold, and wind, and it wasn't going to happen anyway.)
In any event, thanks to Extreme Flight, Chris, and Curtis for the excellent customer service and for standing behind your product. Six days is outstanding, considering how far we live apart.
I wish you continued success.
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
