Old Apr 19, 2012, 06:37 AM
fierce is offline
Find More Posts by fierce
fierce's Avatar
LI NY
Joined Sep 2008
Originally Posted by EXTREME FLIGHT View Post
I still fly the 65mg in most of my 48" EXPs and am not limited in any way by them.
I'm sure you upgraded to the new ESC which has 6V. For me it was cheaper(because I have to pay for my equipment) to just upgrade the servo.
You guys upgraded the Airboss BEC after I had already bought the package.
Originally Posted by Manta1 View Post
same here.
85mg in the back tho on me msx.
Exactly, the HS-65 Elevator servo was changed to the hs-85.
fierce is offline Find More Posts by fierce
Old Apr 19, 2012, 02:18 PM
Letec12 is offline
Find More Posts by Letec12
Model Aerobatic Team Holíč
Letec12's Avatar
Slovakia
Joined Feb 2009
Finally I decided to setup the AXI 4120/18 vs. 16x8 "APC 5S 2650mAh as I wrote. We'll see how it will be a 3D ... Then I'll experience here.
Letec12 is offline Find More Posts by Letec12
Old Apr 19, 2012, 07:53 PM
TBone08 is offline
Find More Posts by TBone08
AirSurfer
TBone08's Avatar
United States, VA, Arlington
Joined Sep 2011
Is there a way to check if the ESC is defected, other than transmiter/receiver operation ?
I had a fairly soft crash, nothing crazy, but no esc or motor seem to work... and I want to make sure if I need to order and what...
TBone08 is offline Find More Posts by TBone08
Old Apr 19, 2012, 08:12 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
How do the washers go for the control rods?
Dumb question, but how do the washers go for the control rods?
Bolt, washer, swivel on control arm, control horn, washer, nut?
or
Bolt, washer, swivel on control arm, washer, control horn, nut?
I am guessing the first. Just trying to figure out the best way so the nut doesn't walk off over several flights.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Apr 20, 2012, 10:57 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
If I use a 100Amp ESC (http://www.hobbypartz.com/07e36-proton-100a-opto.html)
- what should I expect to see changing, regarding things like flight characteristics or battery flight time ?
Old Apr 20, 2012, 11:15 AM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
or
I'm too lazy too go look at mine but the best thing is to put the washers on the softest parts. Also, look at the manual.
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Apr 20, 2012, 11:29 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
The specifications look good, as far as ESC specifications go. However, one thing I noticed about all ESC makers is they give marketing specifications, not engineering specifications.
For example, they specify the max current and max voltage, but don't specify the on resistance of the FETs they're using, or its maximum switching frequency.
The max current of an ESC can be increased two ways--first by using better FETs (better in this case means faster switching and lower on resistance). The second is by reducing the thermal resistance, i.e., by using better heat sinking.
A faster switching FET will transition on to off and off to on faster than a slower switching FET. Even if you don't operate the FETs at their maximum frequencies, faster FETs are better. Transitioning on to off faster reduces the amount of power that is wasted as heat, because in a switching power FET, most of the heat builds up during that short duration switching time, and not during full ON or full OFF condition.
For most power FETs, if they were always on or always off, they would run cooler. This is why, for an evenly matched motor and ESC, propped to run at the limits of the ESC and motor specifications, the motor will get hotter WOT, but the ESC will get hotter if you're below WOT. In this below WOT case, the FETs are being switched more frequently, as the motor power is reduced by modulating the FETs, and it is during the switching that the FETs get warmer.
A better heat sink on the ESC will transfer heat built up to the air faster, and mask the use of FETs with inferior specifications.
So, if an ESC manufacturer is using cheap FETs, but a good heat sink, the max current could be as good as an ESC that uses very good FETs, and a smaller heat sink.
If the max current marketing specifications vendors put out are to be trusted (and this *if*), I would chose an ESC that is lighter as it probably indicates they used better FETs. I would prefer this second type of ESC, because less energy would be converted to heat in the ESC.
HOWEVER, on a new plane that I valued highly, I would *not* use an ESC I haven't used before, unless several others are reporting sucess on the same plane with the same motor.
Disclaimer: much of the above is based on theory. Actual observations of those in the hobby may differ, and I would be interested in reading those if they do differ.
Old Apr 20, 2012, 11:31 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks.
The pdf manual has a photograph, and I zoomed in as far as I could, but the resolution didn't allow me to see this much detail.
I ended up doing my first listed option. That being said, the plastic that encases the brass swivels is probably softer than the control horn or servo arm.
I'll check after every flight for the first half dozen flights and see if I detect any nuts walking off the bolts.
Old Apr 20, 2012, 11:41 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
N6145k,
thanks for the detailed answer. much appreciated !
Old Apr 20, 2012, 11:47 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I don't remember, but I believe the the 60" Extra came with aircraft nuts for the ball links. If not, I get those from Micro fastners, which has had an add for decades in Model Aviation.
I used those on all my planes with slightly longer Dubro 12mm X 2 allen bolts, and with a second regular hex nut on the outside and with the two nuts turned into each other. Then I put a drop of thick Ca on the exposed threads. That ain't never coming apart.
Doc Austin is offline Find More Posts by Doc Austin
Old Apr 20, 2012, 12:41 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
TBone, no problem, you're welcome. I also updated what I wrote, because, on this particular plane, I would not switch to using a brand new less expensive ESC unless I had used it in less valued planes previously, or others have already used the ESC in question. But that is a personal risk tolerance question that will vary from individual to individual.
Old Apr 20, 2012, 12:52 PM
jlloyd1995's Avatar
Joined Oct 2010
Thanks.
No problem. I just looked at mine. I have washers on both sides of the servo arm but not on the ball. Actually, on my elevator and rudder linkages I also have a washer on the ball but if you only have two, I'd put them on the arm.
Old Apr 20, 2012, 02:58 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I also just noticed that on mine, if I put the rod over the aileron servo arm (on the side of the servo arm opposite of the servo), it binds when pulling the control surface toward the servo.
I could get a full throw if I put the rod under the servo arm.
Any thoughts on this?
Old Apr 20, 2012, 03:16 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
I noticed that as well but I checked it and was getting 35 degrees of throw before it started to bind so I didn't worry about it
shadow102 is offline Find More Posts by shadow102
Old Apr 20, 2012, 04:07 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
I've an opportunity to purchase either a Scorpion Motor or a Hacker Motor for the 60" Extra at a substantial discount. The recommended motor is the Torque 4016/500. What is/are comparable Scorpion/Hacker motor(s) to the Torque. Thanks.
chopper62 is offline Find More Posts by chopper62
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
