![]() I have 4 of the 3S 3000mah Turnigy Nanotech for my DW BAFoamie - those should work in series just with a slight shorter time correct? (2 to get 6s 3000mAh) Does anybody has experience with those Nanotech lipos? - so far I am charging mine still at 1C - just to make them last a little longer... I've heard different opinions about them. |
--Tom K. |
Latest blog entry: New Stuff!
Tom, I was thinking of going with a 15 x 7 prop. Would that be to small? I heard that was a good prop for that motor. |
Latest blog entry: My Charging Case!
Well i bit the bullet today. Extreme is fairly local for me so I wend by and picked this plane up. I am pretty excited about it. I have a Castle ice 75 for it. I am thinking I will try the Motro fly motor this go around. Is it a direct fit or do I need to buy some standoffs? I am going to use the recommended servos. Just looking for a tower coupon or something..lol
So Motro fly 4315-480 ? Castle 75 ice ( external bec or straight?) Hitec 5245's x4 or should I use a better rudder servo. I have also had a ton of issues on my edge with the tail wheel working correctly. So I switched the one on my 60" edge to a Sullivan setup. I am hopeful it will work better. I have soem sky lipo 30c 3300mah that I have been using but I may order some nano's or gen aces soon. Mine are a little older so I need to refresh. |
The motor is good to about 80 amps. I have mine dialed back to 65amps as the power is more than enough and it runs cool. Unrestricted (not dialed back) the 16x8 pulls 83 amps static, and with the use of the Eagle Tree data collector in flight the 16x8 pulls 68 amps. Here is the link to the power systems thread with all the data: http://www.rcgroups.com/forums/showt...533887&page=22 We had to purchase some nylon standoffs from Lowes and shaved them down to 10mm. The screws install directly into the installed blind nuts, so the standoffs are the only modification. Quote:
I hope this helped! --Tom K. |
The plane is designed around the torque 4016T/500 Motor.. As much as I do like Motrolfly products(run one in my 78" Extra), I truly feel it's important to stick with manufactures recommendations, in order to get the best performance from your Extreme Flight EXP series planes..
I have this stock setup in my 60 inch edge, But after seeing a buddies fly on the motro fly setup . I was sold. Insane pullout power. I thought I would try it and the ESc I already had. I was debating on the 78 electric plane but I really like this 60 inch size. |
| Thread Tools | |
| Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video | hercdriver7777 | 3D Flying | 2080 | Jun 04, 2013 06:15 AM |
| Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video | FlopGun | 3D Flying | 249 | Apr 16, 2012 10:46 AM |
| Help! D-60 build thread | Chronic DS'er | Dynamic Soaring | 3 | Jun 23, 2011 10:04 PM |
| Sold Extreme Flight 58" Extra Ready To Fly (GA) | traderdave2 | Aircraft - Electric - Airplanes (FS/W) | 11 | Apr 26, 2011 05:33 PM |
| Video EXTREME FLIGHT RC EXTRA 300EXP in Action! | EXTREME FLIGHT | Electric Plane Talk | 1 | Jun 10, 2009 08:45 PM |
