Old Dec 23, 2011, 08:57 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
When will this plane be back in stock?
H.D. is offline Find More Posts by H.D.
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
New Years-ish. ETA's are on the front page of EF's website.
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Dec 23, 2011, 09:04 PM
H.D. is offline
H.D.'s Avatar
Joined Aug 2011
Thanks Tom.
That will give me a little time to save my pennies.
Old Dec 24, 2011, 01:53 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Originally Posted by H.D. View Post
Thanks Tom.
wow
keithy4129 is offline Find More Posts by keithy4129
Old Dec 24, 2011, 01:59 PM
H.D. is offline
H.D.'s Avatar
Joined Aug 2011
Originally Posted by keithy4129 View Post
wow
Go big or go home!
Old Dec 24, 2011, 04:55 PM
Joined Aug 2010
Go big or go home!
agreed
Old Dec 24, 2011, 06:23 PM
TBone08 is offline
Find More Posts by TBone08
AirSurfer
TBone08's Avatar
United States, VA, Arlington
Joined Sep 2011
what's the EF Extra 300 EXP ARF - airleon low rate degrees ? (the manual speaks of %, not degrees for thhe Air..)
"Aileron: Low rate-15-20%; 40-45% Exponential"
TBone08 is offline Find More Posts by TBone08
Old Dec 24, 2011, 10:28 PM
Doc Austin is offline
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Just In Time For Christmas...
Doc Austin is offline Find More Posts by Doc Austin
Old Dec 25, 2011, 12:00 AM
mxcop is offline
Find More Posts by mxcop
TEAM EXTREME / HORIZON HOBBY
mxcop's Avatar
United States, NJ, Tuckerton
Joined Oct 2006
It should be 15 to 20 degrees, looks like mistake in the manual. That's a good starting point, just adjust from there until you get the roll rate you prefer.
Lee
mxcop is offline Find More Posts by mxcop
Old Dec 25, 2011, 10:35 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
Lee, in your opinion, for my maiden flight (not knowing what to expect, coming from aerobatic foamies) I thought of putting a 65 Expo...
sounds about right (or too much) ?!
Old Dec 25, 2011, 11:03 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
I'm at 35% on low rates. At 65% it is going to feel pretty dead...
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Dec 25, 2011, 11:25 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
JC, for yor rud & ail, or elevato too ?
Old Dec 25, 2011, 12:36 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
If you're unsure about the plane, just to be safe, set the throws to the low end of the recommended range on the low rates for elevator(8 degrees) and ailerons(15 degrees), I don't really think you need to add more expo, if you do I wouldn't go above than 10% more because it will start to effect the way the feel of the plane should be. Remember, the recommended low rate settings will allow the plane to feel very smooth and precise so I don't think you'll have much trouble, where you can get in trouble is on the high rates, just get it up and trimmed out on the low rates and then experiment with the high rates a few mistakes high until you get your settings adjusted to your preference. Honestly I think you'll be fine if you set it up exactly as the manual recommends, it shouldn't take long to get comfortable with it, then just fine tune the throws and expo to your comfort zone.
Lee
Old Dec 25, 2011, 12:51 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Oooops.....Nevermind. I see that Lee has already covered it.
Old Dec 25, 2011, 01:18 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
Thanks Lee, good to know !
in that case, for the maiden, I will use the low rates:
ELE 8 degrees, expo 20 (or 5 more)
RUD 20 degrees, expo 50 to 55 (or 5 more)
AIL 15 degrees, expo 45 (or 5 more)
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2593 Feb 07, 2016 11:38 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 11:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 11:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 06:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 09:45 PM
