Old Dec 18, 2011, 10:50 AM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
10ga will not fit in the 35A contact. It will fit in the 45A.
_OZ_ is offline Find More Posts by _OZ_
Old Dec 18, 2011, 11:05 AM
Aeroplayin is offline
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Thanks.
Aeroplayin is offline Find More Posts by Aeroplayin
Old Dec 18, 2011, 11:20 AM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
That's interesting. I didn't know those plugs had the aptitude for this kind of application. They are easy to pull apart and that's definitely a plus.
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Dec 18, 2011, 11:39 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I've always used Castle 5.5mm bullets on my 8S setups, but I also used an OPTO ESC with a 1100mAh A123 Rx battery, which added 3.4 oz. I then went to Deans for the 3S and 4S planes with a separate BEC so that the second battery was not needed. I've never really been a big Deans fan and have had two issues that are making me look at other options again. All my 6V BECs now have Deans but the wiring with powerpoles seems like an easy way to add BECs to the circuitry.
Old Dec 18, 2011, 11:43 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Power poles are the way to go! The best part is, no more fighting to pull them apart. I can remove my canopy, and disconnect the pack with one hand while still safely holding a TX.
Plus if you run two packs (larger planes), there's no need for a Y-harness. The red a black connectors are the same, and plug into one another..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Dec 19, 2011, 10:43 AM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Is that the 78" in that picture Tim? If so, is the pull-pull rudder the only option for rudder control or can you put a servo and pushrod in the tail for both the elevator and rudder?
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Dec 19, 2011, 10:45 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
been running power poles for about 4 years.NEVER had a failure.Ran up to 120 amps in my 89 slick.love them.aint going back
Manta1 is offline Find More Posts by Manta1
Old Dec 19, 2011, 12:35 PM
Joined Oct 2008
--Tom K.
Yes that's my 78". No you can't mount the rudder servo in the back. It has a split elevator with two servos.
Old Dec 19, 2011, 12:40 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Okay thanks.
--Tom K.
Old Dec 19, 2011, 06:51 PM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Tom, Pull systems are a snap once you have set up one or two. You adjust them maybe after 5 flights (after the cables stretch out a little) and then it's set for almost the life of the plane. If you get one, we can set it up.
Doc Austin is offline Find More Posts by Doc Austin
Old Dec 19, 2011, 09:06 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Thanks Austin. It's pretty great having a Team Extreme member pretty much down the road. We had a problem building our first EXP, and at 10p.m. he invited us over to his house to resolve the issue and get in the air the next day... Thanks again Austin!
--Tom K.
Old Dec 19, 2011, 11:02 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Ok, finally, I am getting my 60" Extra EXP from Jim Wednesday. It's been a tough month so I am ready for a new challenge.
Old Dec 20, 2011, 09:08 AM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
SWEET! We'll fly it Thursday! I'll bring the camera
--Tom K.
Old Dec 20, 2011, 09:19 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I think I can get it ready, but you know how slowly I work. I just have to seal the controls, mount the ESC and do the control linkages. I put in all the velcro, mounted the receiver, heat shrunk wrapped all the extensions, ran the antenna tubes, ground the flat spot on the tailwheel wire, glued the tailwheel tire on, etc, before I gave it to Jim. I did as much as I could, so there's not much left.
I've been salivating over this for a long time, but everything worked against me getting it back from Jim. Let's just hope tomorow works out.
Old Dec 20, 2011, 09:22 AM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Yeah man, you're going to love this plane. My friend gives me stick time on his about every time he comes out (I have my own rate switch with my setup) and it's almost like a mix of the Edge's stability and 3D insaneness with the MXS's rock solid precision and tumbling capability and the Extra's looks. It's a pretty bad plane!
--Tom K.
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
