Hi
The best is to look at Scorpion catalog Every motor is indicated with Stator size (example S3014 means stator 30mm x 14mm stack height) Turns Wires (strands number and diameter) Kv Weight Slots, poles .. Max current Max Power For predicting you have free Scorpion Calc to play with Voltage Prop ... You get rpm, amps, thrust, pitch speed Then you have a complete design reference to make your own kit on any stator lams Louis |
http://www.rcgroups.com/forums/showthread.php?t=240993 Vriendelijke groeten Ron• diy motor tips • Drive Calculator • • diy motor group • Cumulus MFC • |
USA, PA, Telford
Joined Apr 2004
Yes formuli exist. It takes many calculations to determine windings. Testing and revising is the most reliable and will be necessary anyway to verify the formuli results.
The number of turns determine speed, use the biggest gauge (lowest resistance) wire to fill the slot, as full as your winding machines will allow. Only resort to double wind if your gauge is too thick to wind properly. Comm fusing becomes more difficult too. Hand winding is a last resort for production quantities. |
As Ken wrote.
Kv x #winds = constant, Kv x Kt = 1 (in SI units, not in Burmese/Nigerian units). Now do a quick and dirty 10 (or 20) wind with thin wire. Determine Kv_10 using drill press / generator method. Number of winds needed to get desired Kv can now be calculated: #winds_desired = Kv_10 / Kv_desired x 10 (20). Manual V's turn calculator, most recent version in one of the last posts: http://www.rcgroups.com/forums/showthread.php?t=1062406 Motor forumulas, sticky in this subforum http://www.rcgroups.com/forums/showthread.php?t=587549 Prettig weekend Ron• diy motor tips • Drive Calculator • • diy motor group • Cumulus MFC • |
USA, ME, Ellsworth
Joined May 2008
This link is directly to the download for the zip file with TC5:
Turn Calculator 5 - http://www.rcgroups.com/forums/showa...5&d=1278349768 And Manuel just put a file with a new simple turn calculator there too: Simple Turn Calculator - http://www.rcgroups.com/forums/showa...5&d=1311639725 Wonderful stuff, I couldn't imagine not having those to get you close on the first wind. I find working in the SI units to be a little vapid, I suppose it is OK for those that have trouble with numbers or remembering details and don't mind taking orders from the French or other people as to what numbers to use. None of our languages are perfect, why should any one of the prevailing math systems be considered to be? Jack |
| Thread Tools | |
| Help! Permanent magnet DC/Brushless formulae | dogshome | Electric Motor Design and Construction | 15 | Jun 07, 2007 04:07 PM |
| Help! Magnet winding wire... | Zimbo | Electric Motor Design and Construction | 27 | Aug 29, 2006 08:44 PM |
| Question 10 magnet pole winding question | CrashingDutchman | Power Systems | 4 | Dec 27, 2005 11:26 AM |
| Wanted Need some size 25 magnet wire for winding a BP21 motor. | himeros | Aircraft - Electric - Miscellaneous (FS/W) | 0 | Nov 29, 2005 11:24 PM |
| Question GBCDROM Winding/magnet suggestions please. | Clive Henry Jones | Power Systems | 12 | Oct 25, 2004 03:23 AM |
