Old Jul 25, 2011, 10:24 AM
Masterpiece is offline
Find More Posts by Masterpiece
Hervey Bay, Sunny Qld, Australia
Joined Jun 2001
Removal of covering film heat activated glue from solid surfaces?
Hi,
I have a Omega 2.5m sailplane (composite D box / built up wing) that I have removed the covering film from the inner wing panel. Now I have a distinct mark where the covering film's heat activated glue was.
What is the best solvent / method to remove this glue so that I can re-apply new film?
I was thinking methylated spirits or eucalyptus oil (followed by metho).
Masterpiece is offline Find More Posts by Masterpiece
Old Jul 27, 2011, 02:52 AM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
I've seen a few youtube clips of people using strong clear packing tape to remove the residue. just apply it to residue, push it on to the patch, and rip off, seems to work in the clips at least!
Don't whatever you do us eucalyptus oil to remove it, you'll never get anything to stick to it ever again! If you MUST use a solvent, I have in the last used lacquer thinner to good effect, but I'd try the tape trick first.
Curare is offline Find More Posts by Curare
Old Jul 27, 2011, 03:56 AM
Joined Jun 2001
Thanks for that Curare,
I just tried methylated spirits and it seems to work after a few rubs.
Old Sep 15, 2011, 08:36 PM
pval3 is offline
Find More Posts by pval3
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
there is also a product from topflite that use to work pretty well
pval3 is offline Find More Posts by pval3
Old Sep 15, 2011, 08:37 PM
pval3 is offline
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
coverite use to have another product that was a thinner for their balsarite product that also might work too
Old Sep 17, 2011, 07:00 AM
Joined Jun 2001
I'll have to have a look for "a product" from Topflite
Old Sep 18, 2011, 09:27 PM
zbytekfr is offline
Find More Posts by zbytekfr
The Lone Sloper
USA, NY, Orchard Park
Joined Apr 2007
I have used the packaging tape method on balsa surfaces. Apply the tape then use your covering iron over that to warm both and the adhesive will bind better to the tape. If the surface under the covering is painted like my Omega HLG , DO NOT use solvent, it will dissolve the paint.
What you could use is Bestine and only Bestine on a painted surface.
Hopes this helps.
Frank
zbytekfr is offline Find More Posts by zbytekfr
Old Sep 19, 2011, 09:33 AM
Joined Jun 2001
Hopes this helps.
Frank
Thanks for that. I have since removed the adhesive with methylated spirits and it worked a treat.
I'll have to remember the packing tape trick for balsa surfaces though. Adhesive on balsa is a PITA
New Product New heat-shrink covering film for RC airplane,good quality.only cost $1.24/m Yunxiang Chen The Builders Workshop 15 Mar 02, 2012 09:44 AM
Sold **"New Stuff"** Laminating Film Covering Mr. Combat Certain Aircraft - Sailplanes (FS/W) 28 Jul 05, 2011 01:07 PM
Discussion Covering curved surfaces with film F.Littleton The Builders Workshop 6 Jun 12, 2008 12:25 PM
heat activated covering adhesive EZ RIDER The Builders Workshop 2 Dec 22, 2003 09:26 PM
Monokote Glue,How to remove glue from top covering? speedo Electric Plane Talk 4 Apr 11, 2002 09:27 AM
