Old Jul 25, 2011, 07:40 AM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Build Log
If you have A123/LiFe receiver packs, you WANT this mAh consumption tracker
STATUS: LCDs now shipped (12-Nov-2011).
STATUS: In production, awaiting LCD delivery from China.
Dispatch from China is anticipated on Nov 12, arrival by Nov 20. PCBs will already be populated on LCD arrival so SCC1 deliveries will commence almost immediately.
A sophisticated device that measures the battery capacity being drained from your receiver packs (or small park flyer power pack) and provides detailed data on the state of the power.
Perfect for A123/LiFe packs which cannot be reliably measured using the normal voltage sense alarm systems.
Download the user-manual and check out the features that it offers in detail.
  • Programmable battery size in 50mAh blocks
  • Manual reset/initialise (as with a normal car odometer)
  • Empty battery alarm (not really very loud, but it's still there)
  • Maximum of 10A sense ability
  • 1mAh consumption resolution
  • Data display:
    • Top line - Battery capacity remaining
    • Bottom line:
    • Runtime since last reset
    • Current battery voltage (V)
    • Peak current (mA)
    • Lowest averaged battery voltage (V)
    • Consumed mAh
  • Voltage range: 4.0~8.5V (2S lipo maximum)
  • Current range: 0~9,999mA (5A average max recommended)
  • Battery size: 50~12,800mAh
  • Weight: 10~12g ( ~0.4oz )
  • Size: 38 x 25 x 7mm size (1.5 x 1 x 0.25")
  • Leads: Two pairs of 20AWG bare silicon fly leads
  • Protection: Rubberised clear heatshrink
Inflexo is offline Find More Posts by Inflexo
Old Jul 25, 2011, 07:53 AM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
Surely you mean to say it'll tell you how much charge was consumed from the pack.
The newer Castle Creations ICE ESC's have a logging capability that records much of this info:
* Battery Voltage
* Battery Ripple
* Battery Current
* Controller Temperature
* Controller Input Throttle
* Controller Motor Power Output
* Motor RPM
But sadly, no record of mAh (charge) used. http://www.castlecreations.com/produ...oenix_ice.html
I don't have any of these controllers so a little $40 device like you describe would be handy.
SteveM732 is offline Find More Posts by SteveM732
Old Jul 25, 2011, 08:24 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
This unit is more for receiver packs (NiMH/LiFe/A123/2S-lipo) on glow/glider systems, as opposed to electric power with ESCs. Maybe I can come up with a better title in the morning for the whole system to clarify its intended application.
Anyhow, attached is a preliminary spin of the board.
Old Jul 25, 2011, 08:36 AM
SteveM732's Avatar
Joined Feb 2008
It is morning
I see, makes more sense in a fuel powered plane. In this forum I always assume electric powered unless otherwise specified. Still, I could see potential in smaller electric FF or R/C. Any idea what the max current would be?
Old Jul 25, 2011, 08:47 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Ah, we're just about to switch over to Tuesday morning here in Australia... in T-15 minutes
I know what you mean about the electric-powered assumption, I do it a lot myself too, though less so these days since I've moved mostly over to DLG's.
Max current is able to be chosen based on the sense resistor, right now I'm going for 5A but moving to 10A isn't a problem. I only need to try keep the max voltage drop across the sense to below ~50mV (keeps the power dissipation/wastage down to a minimum).
I am looking at a similar device for full electric planes but there's a few technical hurdles I have to overcome first.
Paul.
Old Jul 25, 2011, 10:28 AM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
Good idea for a project; perfect for people flying A123 receiver packs. Good luck with it.
(I will probably pass for myself though at the $40 price point. I am notoriously cheap, however.)
teookie is offline Find More Posts by teookie
Old Jul 25, 2011, 10:43 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Pricing is always a difficult thing to get "right". Unfortunately for us sitting outside of the countries where the bulk of the components are manufactured, we get a nice setback compared to being on the inside ( really, a lot of the stuff you see at HobbyKing, even if I bought 1000 units of every part, I'd still not get below their retail price, it's enough to make you cry - so instead you have to be two steps ahead and try other aspects to sell )
I'm waiting for the LCD panels to arrive before I commit the PCB for prototyping, the main reason is that it'll be a chip-on-glass LCD and has a fixed length flexible flat (FPC/FFC) ribbon and I really do NOT want to miscalculate the size of the PCB and the respective positioning of the connector.
Paul.
Old Jul 25, 2011, 12:40 PM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
I use A123's for receiver packs, so am very interested in this.
GordonTarling is offline Find More Posts by GordonTarling
Old Jul 25, 2011, 02:58 PM
SteveM732's Avatar
Joined Feb 2008
I don't think $40 is unreasonable for a specialty product of high quality made in small quantities.
Old Jul 25, 2011, 07:30 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Good morning all
Will be working on the project a bit more today, trying to work out where I'm going to put another couple of parts (I don't want to put them on the other side of the board, because that's where the display will be resting, best I keep it flat)
Old Jul 26, 2011, 08:15 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Typical isn't it... when I need to get a bunch of parts and PPal is the only way to pick them up guess who doesn't have any $ in PayPal... will wait another week before getting desperate.
Old Jul 26, 2011, 08:33 PM
Ed Franz is offline
Find More Posts by Ed Franz
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
I would be interested in one of these. Sounds like a great idea!
Ed
Ed Franz is offline Find More Posts by Ed Franz
Old Jul 26, 2011, 08:41 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Trying to decide at the moment which way I should go for detecting peak currents. Two options on the table;
1) Resettable peak-detector with a low-pass filter on the input stage
2) Calculate from firmware, measuring peak current based on the pulsecount per unit of time from the charge integrator.
The first option is nice in that it's something which looks after itself and actually doesn't really need a reset on it, however it'll be prone to pick up transient spikes 20A+ without suitable filtering on the input stage. Also being made of 2~3 opamps it'll have it's own set of calibration issues.
The second option will only however detect peaks up to the maximum permitted by the 50mV range of the integrator, so if I go with a 5A range then 5A is where it'll peak, even if the actual draw was 8A.
Aaah, the joys of design
Old Jul 26, 2011, 09:35 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Interesting project
I think you should go for the 10A sensor if not higher. With multiple digital servos it is very easy to exceed 5A.
Keeping in mind that your primary market is monitoring Rx packs, if you use a 10A sensor then a simple peak detector that clips at 10A is probably adequate if it makes the device significantly smaller/simpler/cheaper.
If you have a 10A sensor
kgfly is offline Find More Posts by kgfly
Old Jul 26, 2011, 10:26 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
10A isn't a problem in so far as getting a suitable part for it... the downside of going with a higher peak though is that you lose your bottom end sense range resolution, however, realistically we're aiming for worst case of 10% tolerance (eg, 1000mAh +/-100mAh), though I'm hoping we'll end up more like 2.5~5%. While the math would indicate we'll end up in the higher quality resolution I won't state it absolutely until the first prototypes are finished and tested
Paul.
New Product FrLCD V3 open source tarts DIY Electronics 222 Apr 08, 2014 11:01 AM
For Sale Hyperion LDU Power System Data Logger (with optional phase tach and temp sensor) Tom Frank Aircraft - Electric - Power Systems (FS/W) 4 Aug 16, 2011 05:13 PM
Sold Thunder Power 1010/210 updated combo with data cord litespeed Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jul 27, 2011 05:10 AM
Sold Eagle Tree MicroPower E-Logger With Power Panel LCD Display For Sale!! Super D Aircraft - Electric - Power Systems (FS/W) 1 May 03, 2011 04:00 PM
Help! How to reduce voltage for onboard power display Blade Crasher DIY Electronics 9 Aug 31, 2009 12:32 AM
