Old Jul 25, 2011, 06:15 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Build Log
Riva Corsaro, Classic Italian Wood
Ok, Its not quite a build log........
I'm not known for the details and finishing a boat after I get it running so this my solution
But I do need to put running gear in her, Its a much better build quality than the standard E-Bay fare, proper ply frames and epoxy coated interior.
The Running gear install will be a little way off as ..... well you know ....funds.
Got it in the front door and my wife's reaction was a little surprising, she started cleaning it to make it sparkle and said it could be on display.... inside the house
I am quite chuffed......
Cheers
Nick
nick_75au is offline Find More Posts by nick_75au
Old Jul 25, 2011, 07:22 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Cheers
Nick
She said???? WHAT... (do you want to swap wife)
Nice boat, but what about the PLEASURE making it yourself...
It really looks good, hurry up get it running.
Sharky1dk is offline Find More Posts by Sharky1dk
Old Jul 25, 2011, 09:32 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Can you imagine what the full size Riva Corsaro did to women!!
Kmot is offline Find More Posts by Kmot
Old Jul 25, 2011, 09:38 AM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
uuuuh she wants to put that inside the house too????
Old Jul 26, 2011, 01:34 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Does she have a sister?
MILLERTIME is offline Find More Posts by MILLERTIME
Old Jul 26, 2011, 02:17 AM
nick_75au's Avatar
Joined Mar 2007
As a matter of fact she has 2, both spoken for Sorry
Nick
Old Jul 26, 2011, 04:05 AM
nick_75au's Avatar
Joined Mar 2007
Turnigy L3020B-600 Brushless Motor 800w.. $17.59
Hobbyking SS Boat Series 125A ESC $29.77
Digital BB/Coreless Mini Servo .. $6.77
I'm going to order this gear to power her, based on 6 cell Li-po for power.
I have a 3 blade 50 mm prop and am expecting about 30 amps at full throttle
Nick
Old Jul 26, 2011, 01:26 PM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Hi Nick.
Beautiful boat. Where did you get it? As you know, I like fitting these type of boats out with power.
As for the Hobbyking SS series of ESC, if you haven't ordered it yet then I would advise you not to.
Over the last couple of months I've seen more than a few of them fail at our club & read about more on the forums.
Everything from just not working straight out of the box, to failing on the first run, to not accepting programming, to burning up on initial plug in.
A club member gave me one to try & fix that won't accept program or run. I've tried everything & can't get it to work.
Just last Saturday a guy turned up at the club with a brand new Genisis Cat & the ESC caught fire before he even got it to the water. Total meltdown.
Just trying to help.
Paul.
785boats is online now Find More Posts by 785boats
Old Jul 27, 2011, 01:40 AM
nick_75au's Avatar
Joined Mar 2007
Hi Paul,
The Boat comes from John Darke
I will take on board that info on the ESC, lucky I need to save a bit more to pull the trigger on the stuff, knowing HK they will be out of stock when I'm ready
Nick
Old Jul 27, 2011, 05:49 AM
nick_75au's Avatar
Joined Mar 2007
Lump of Brass
I turned a lump of brass into a skeg tonight.
Nick
Old Jul 27, 2011, 08:52 AM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Beautiful work on the skeg! (and a sweet boat)
RGinCanada is offline Find More Posts by RGinCanada
Old Aug 17, 2011, 04:03 AM
nick_75au's Avatar
Joined Mar 2007
Well I pulled the trigger (at my wife's insistence, what a woman ) on the motive power,
I changed the motor to a 480Kv,
Turnigy L3040A-480G Brushless Motor
13000 RPM would have been a little too much I think.
I splashed out on the 80 AMP HV ESC, This ESC may end up as a pair in the Kingfisher as well
Nick
Old Nov 11, 2011, 10:36 PM
nick_75au's Avatar
Joined Mar 2007
Haven't been into my boat much with the turmoil of job hunting etc, but I did make it to the Triple S day and threw the Corsero in the water for an Amp test, 55 mm prop on 22.6 volts only draws 20 amps, I thought it would be closer to 35 amps. The torque may be a problem with the big prop, I could feel it trying to turn the boat over.
I couldn't run it as I accidentally plugged the receiver battery in backwards and fried the rudder servo, never blown a servo like this before so it appears digital servos are susceptible to clumsy fingers
Nick
Old Dec 10, 2011, 09:12 PM
nick_75au's Avatar
Joined Mar 2007
I have run the Corsero twice now and am having a problem, the spray sticks to the hull and soaks the cockpit and makes its way into the hatch, after 10- -20 minutes running the motor is half deep in water Does anyone have any info on wether spray rails or chines were fitted to these boats, Oh an I definitely need a smaller prop, anything over half throttle and the boat is very unladylike in her behaviour
Nick
Old Dec 11, 2011, 04:49 AM
AlanTadd is offline
Find More Posts by AlanTadd
AlanTadd's Avatar
United Kingdom, Bath and North East Somerset
Joined Nov 2011
Lovely boat!....
First RTR of a Riva I've seen that allows access to fit a rudder tube.
I looked up John Darke, as I hadn't heard of him, and find that he is a Model Boat dealer in Brisbane. Google provided lots of links to "shop search/location sites" but no reference to a website. Do you guys know if there is one for this shop?...
Back to the boat, Is it a "Vietnam" special and how much does it retail for?..
Many Thanks
Alan (UK)
PS My first post..Just finished Revell Cornflower Corvette, currently building Nautical Marines' Dark Bitter and own Caldercraft Milford Star and I'm very keen to get hold of a decent RTR Riva.
AlanTadd is offline Find More Posts by AlanTadd
Discussion best place to buy riva aquarama or dumas chris craft bigdogrod Scale Boats 13 Aug 02, 2014 08:19 AM
For Sale Gas powered classic wood hydro. Racer59 Boats (FS/W) 0 Jul 20, 2011 01:08 AM
Gallery Ansmann Riva Lugano derfnam01 Dock Talk 10 May 14, 2011 09:23 AM
Discussion Imex riva classic speedboat hotrodder Scale Boats 2 Jul 16, 2008 10:27 AM
Sold Classic Corona 120 wood crutch ViperR Aircraft - Electric - Helis (FS/W) 0 Jun 18, 2006 04:01 PM
