In case of a big pack... it only takes long. http://www.hobbyking.com/hobbyking/s...dProduct=10328 Cheers, Rob |
).You must monitor the battery and not leave it while discharging. Use a reasonable current like 10C if you are dealing with 25C batteries and keep a small fan on the battery to keep it cool. I don't let mine get above 90 deg F while discharging to about 3.85 V per cell. Use your watts up meter to measure the current watch the voltage and adjust the load during the discharge process. Never ever go below 3.3 v per cell. Many recommend 3.85 volts per cell for the storage voltage. This is usually the same level as I receive the batterys from the seller so that is what I use. Don't ever walk away from it while you have the load connected to the battery. |
Brad |
So. Cal.
Two very inexpensive and effective 'set it and forget it' options that will bring charged packs into storage range and will not destroy your packs if you forget to disconnect them:
http://www.rcgroups.com/forums/showthread.php?t=1131817 http://www.rcgroups.com/forums/showthread.php?t=1255751 Mark |
Joined May 2011
My ZLIN-XIII I only fly a few times a year.
Keeping the pack at storage, makes that it is still in mind condition: http://www.hobbyking.com/hobbyking/s...idProduct=9505 Purchased almost 2 years ago. Yesterday I did messure the IR with my iCharger (at storage level): 2/2/3 (balancer cables) Main lead has 7mOhm. Outstanding figures for a 3600mAmh 30C pack of almost 2 years old. Of course I notice this also during flight. Much punch! So keeping them at storage... wise!!! |
United States, NY, Hamburg
Joined Aug 2004
now i feel like an idiot. ive been leaving my packs charged for extended periods of time and i have a few that seem a little squishy. what i mean by that is that the battery is still hard as a rock, yes, but if you squeeze it gently the shrink wrap will collapse like 1mm on each side of the battery. was gonna cut the shrink off one of the worst ones and see if it was the cell casing or the shrink wrap causing it. i run TP 2250 45C packs in my furion 450, and i haven't been flying for months now due to a lack of time. now i'm starting back up again and i hate to see my batteries shot because i was stupid and left them charged. can they still be used if they're a little puffed like i described? i'm cycling them as i write this and they still seem to hold a solid charge and capacity. by the way, i'm using a tp820 charger on a 40 amp 12v power supply. i only charge at 1C.
Space Coast
Joined Oct 2000
It's not the shrink wrap.
I think a slight puffiness is getting to be standard with the lower priced lipos after a couple months use. They still work fine at the C-draws I use (5-18C) but definitely a little squishy before and after flying. Some of the older packs would get a little puffy after a flight and then shrink back down but these new/cheapos just stay a little puffed. |
Free State of Lavaca
Joined Nov 2006
I thought I did last time I charged them (err 2005 or 2006) - but it really did not make much difference
. New lipos are on order - might cycle the old ones to see what is left of them before I salvage the plugs and submerge them.-- oh, they were cheep lipos then too. |
| Thread Tools | |
| Poll How fast do you charge your ~600mah lipos? | penderperson | Batteries and Chargers | 7 | Jun 25, 2011 07:04 AM |
| Discussion How loose do you keep your folding prop? | hog2soar | Electric Sailplanes | 4 | May 13, 2011 11:56 PM |
| Where do you keep your LiPos ? | raymcm | Batteries and Chargers | 23 | Jul 08, 2005 07:22 PM |
| What do you keep your Lipos in? | EddieNewYork | Batteries and Chargers | 38 | Sep 01, 2004 07:52 PM |
| Can some one explain the C in charge rate? And what do you charge your He-cell at? | rspiegel | Batteries and Chargers | 10 | Jan 08, 2003 09:50 AM |
