Old Sep 03, 2003, 10:21 PM
VR6 is offline
VR6
Find More Posts by VR6
VR6
VR6 Driver
VR6's Avatar
Joined May 2003
2 charger with 1 power supply..need help
Hi all.....
I have the Radio Shack regulated 10 amp power supply.
Can I connect my Triton & Kokam 402 Li-Po charger at the same time?
I mainly charge my e-tec 1200 2s1p li-po
Are there any certain way to connect the chargers to the power supply...or I can just clip all the alligator clip to the post/terminal?
TIA
VR6 is offline Find More Posts by VR6
Old Sep 04, 2003, 06:38 AM
jimsp is offline
Find More Posts by jimsp
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Re: 2 charger with 1 power supply..need help
TIA
You can just clip the alligator clips to the post/terminal. For a neater solution you could replace the alligator clips with stackable banana plugs like these. Thats what I did with my two chargers and it works fine. If you still want to use them at the field just build a little box that has two sets of banana jacks connected by a cord to one set of the alligator clips that you removed.
jimsp is offline Find More Posts by jimsp
Old Sep 04, 2003, 11:33 AM
VR6 is offline
VR6
VR6
VR6 Driver
VR6's Avatar
Joined May 2003
Thank you for the information....
I'll check out the stackable clip
Got a new 2.5amp wall Power Supply, Need Help! Suntzu Batteries and Chargers 24 Dec 15, 2004 04:51 PM
Question 2 Triton Charger on 1 Power Supply? psycho_klown66 Batteries and Chargers 13 Nov 01, 2004 11:03 PM
Duratrax Intellipeak Deluxe Pulse Charger With Ac Power Supply Turbosun Aircraft - Electric - Airplanes (FS/W) 9 Mar 16, 2003 02:08 PM
Duratrax Intellipeak Deluxe Pulse Charger With Ac Power Supply Turbosun Cars - Cars and Parts (FS/W) 3 Mar 15, 2003 12:00 PM
Duratrax Intellipeak Deluxe Pulse Charger With Ac Power Supply Turbosun Aircraft - Electric - Airplanes (FS/W) 4 Mar 15, 2003 11:58 AM
