Old Jul 23, 2011, 01:38 PM
zetland76 is offline
Find More Posts by zetland76
zetland76's Avatar
Ilkley, UK
Joined Apr 2007
What size fin and rudder do I need?
I have rebuilt the body on an old rudder and elevator only, slope soarer. (I couldn't bear to scrap my first ever built up wing). This trainer wing has quite alot of dihedral.
The problem. It is very sluggish to turn this model and I have to hold over full rudder for quite some time. What is the recommend for fin and rudder shape and size. My immediate thought is to make the rudder wider. Or should I make the fin and rudder taller? Or is it the dihedral on the main wing to blame?
zetland76 is offline Find More Posts by zetland76
Old Jul 23, 2011, 02:17 PM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Sounds like the dihedral: She's trying to stabilize the flight and fighting any rudder input.
domll is offline Find More Posts by domll
Old Jul 23, 2011, 05:09 PM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Post a picture of the beast and we will be able to make an informed recommendation.
Just now my crystal ball doesn't seem to be working
Whiskers is online now Find More Posts by Whiskers
Old Jul 23, 2011, 05:21 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Actually the opposite is true.. More dihedral makes a plane turn better on rudder, that's why rudder only planes almost always have plenty of dihedral and aileron planes don't have much, if any. Dihedral is what makes a plane roll when you add rudder (see fig 7 on attached pdf). As a rule of thumb for rudder only you want about 7 deg of dihedral per panel.
I'd suspect either not enough dihedral or too small a rudder or too short a tail moment, or a combination of all of these factors.. as Whiskers say's a photo would help.
Getting all technical, you can calculate the rudder size/moment arm and dihedral angle required for good rudder control response by using the design parameters in the attached .pdf.. page 6, formula 10 (basically bigger rudder on a moment arm tail and more dihedral = better rudder control authority)
Steve
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jul 24, 2011, 10:33 AM
zetland76's Avatar
Ilkley, UK
Joined Apr 2007
This is a picture of the plane.Name: DSCF0001.jpg
Description: A picture of the plane. Thanks for all the comments so far.
Old Jul 24, 2011, 11:16 AM
Aberdeen
Joined Mar 2006
Looks to have plenty of dihedral. More rudder area seems to be the way to go. I'd keep the shape pretty much as you have it but add a little more height and more width and make the fixed part smaller and the moving part larger. You also need generous deflection.. at least 30 deg each way if not more.
Even with ample rudder area you cant expect a R/E glider to have 'snappy' response to rudder especially when flying slow.. It's normal for there to be a little delay in response.
Old Jul 24, 2011, 04:06 PM
Terry Pieters is offline
Find More Posts by Terry Pieters
Cape Town, South Africa
Joined May 2008
I am inclined to agree, you need more rudder area, possibly start by butt joining with cocktail sticks and tape a piece of 1/8" balsa the same size as your rudder onto the back of the rudder, making sure to leave space for the elevator movement. If that improves the turning you are going in the right direction, easy to change the size of the add on balsa pieces until she behaves correctly. Then you can make yourself a neater vertical and rudder if need be.
Terry Pieters is offline Find More Posts by Terry Pieters
Old Jul 24, 2011, 05:47 PM
Whiskers's Avatar
Joined Feb 2010
For a RE slope glider you need a heap of rudder authority.
You get a bit cross-wind on the slope and the dihedral banks the plane to turn down wind, and the rudder really needs to exert massive force to fight the wing and get the whole thing back on track.
I'd put on a rudder of twice the area, with a forward aerodynamic balance, and give it a 40 degree deflection each way.
On a sloper with a similar problem I added ailerons... That fixed it
Old Jul 25, 2011, 07:47 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
For me, it looks like too little dihedral. RE gliders should have 12 degrees of dihedral per wing: 24 degrees total. That looks closer to 9 degrees per wing. That's the rule of thumb for thermal gliders. I don't know much about slope soarers.
slebetman is offline Find More Posts by slebetman
Old Jul 25, 2011, 08:16 AM
Whiskers's Avatar
Joined Feb 2010
Give something like this a go, with plenty of throw:
Old Jul 25, 2011, 12:12 PM
zetland76's Avatar
Ilkley, UK
Joined Apr 2007
Thanks Whiskers, I'll give it a try.
Just fixing my PSS Spitfire (lost the lead-lined spinner) and Middle Phase (battery got loose) then I'll get back to the RE
Old Jul 25, 2011, 01:37 PM
Aberdeen
Joined Mar 2006
It's hard to say how much dihedral it has from the photo but i agree with you that something in the 9-12 deg range is where ideally it should be at.. I said minumum 7 deg in my last post but i ment to type 9.
Steve
Old Jul 25, 2011, 05:07 PM
Whiskers's Avatar
Joined Feb 2010
Cool!
Let us know how it goes, and if I need to eat a big slice of Humble Pie
Old Aug 07, 2011, 03:11 PM
zetland76's Avatar
Ilkley, UK
Joined Apr 2007
Made the rudder taller with the counter-balance as recommended. Was better but not very much however, I put the quicklink in a hole closer to the rudder giving the rudder much more throw. That did the trick. Not as fast as my aileron models but much faster for the RE model.
Taped a spycam to it and got some reasonable shots on my local slope.
Slope soaring --- Baildon Moor (2 min 37 sec)
Thanks all
MIke
Old Aug 07, 2011, 04:27 PM
Denile is offline
Find More Posts by Denile
M16 CIII/AR15/FN 2000 and PS90
Denile's Avatar
United States, AR, Waldron
Joined Jan 2005
Very nice flying spot. Are those bomb craters that can be seen on the base of the hill.
Denile is offline Find More Posts by Denile
Discussion What size lenses do you use for what style of flying?? dallibab FPV Talk 15 Oct 27, 2011 12:11 PM
Discussion What size prop do I need? Ron Merigold Electric Sailplanes 1 Jun 21, 2011 08:18 PM
Discussion What rudder servo do you all use for your 500 size heli's? ck986 Electric Heli Talk 5 May 31, 2011 12:38 PM
Discussion TopFlite: What size servo do I need? Rydogg420 Beginner Training Area (Fuel) 3 May 21, 2011 08:00 PM
Discussion Why do some Ornithopter need a vertical fin ? khaled_abobakr Ornithopters 13 Apr 05, 2011 05:03 AM
