Old Feb 29, 2012, 05:37 PM
Mendo is offline
Find More Posts by Mendo
Mendo's Avatar
United States, CA, Ukiah
Joined Dec 2011
I have a total of 28 of these servos and have not had one bad one yet. I have run them at 4.2v and 5v as well. I did notice that at 5v they ran a bit warm so now I diode the 5v most bec's put out down to 4.2-4.3 volts and have had great results. Nothing but good to say about these, Ill be buying more!
Mendo is offline Find More Posts by Mendo
Old Mar 09, 2012, 07:55 AM
BatLaw is offline
Find More Posts by BatLaw
BatLaw's Avatar
United Kingdom, Wales, Dinas Powys
Joined Jan 2005
It would be helpful to pull this thread to the top again as I think these servos are pretty good. I've used them in a 19 in. w/s depronised Frog Redwing and as it comes within a number of threads I've put a short build log on my blog. Take a look.
BatLaw is offline Find More Posts by BatLaw
Old Mar 09, 2012, 08:27 AM
axelen is offline
Find More Posts by axelen
OpenGL C/C++ programer
axelen's Avatar
Israel
Joined Dec 2006
Since I got 7 I decided to try and replace one of the servo's motors with a bigger one,
from a cheapo linear HK servo.
new motor's resistance is (as I recall) 2.5ohm less, but the servo
runs at the same speed. torque has increased nicely.
weight went up to 2.2gr
I don't have the camera here, so will post pics later and do a torque test.
axelen is offline Find More Posts by axelen
Old Mar 09, 2012, 08:32 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
too bad theyve been BK for months now. i was lucky to grab a few before the reseller/hoarders scooped up the supply. i cant see too much value in mods that increase weight though. there are several others in the 2g range that cost less and have more torque.
dave1993 is offline Find More Posts by dave1993
Old Mar 09, 2012, 08:58 AM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
Update :
upgraded motor servo torque - checked how much it can push at
the end of the long servo horn (the one with 3 holes at each end)
Orig servo did ~32gr
Upgraded servo did >400gr
I can't check it as my 'heavier' scales only go up to 200gr.. zeroing them with 198gr on them allows you to measure
(not very accurately, but never mind) up to 398gr... and I got "over load" on the scale screen..
Old Mar 09, 2012, 08:59 AM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
The moded servo will be used as a tail servo for 120sized CP heli...
More over, all other cheap linear/non linear servo's are crap. EXEPT the spectrum ones, which are not digital.
so for me all other servos are not usefull, and the spectrums are today at 12$
EDIT :
Orig servo + horn (no screw @ horn) = 1.945gr
Moded servo + horn (no screw @ horn) = 2.225gr
so it's only .3gr more..
Old Mar 09, 2012, 12:41 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
i suppose if you do get 10x more torque for 7% heavier its a good deal. for me weight is an over-riding factor. after getting mine below a gram they compete with expensive and hard to use actuators. not to mention more torque.
Old Mar 09, 2012, 05:18 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Just be careful that the electronics can cope long term. All that torque has to come from somewhere and the somewhere is now a massive increase in current through the new lower resistance motor.
You may find the driver stage now burn out easily.
Just worth being aware of.
Originally Posted by axelen View Post
Update :
jj604 is online now Find More Posts by jj604
Old Mar 09, 2012, 05:27 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
Yes, you are right. This is a point of concern, if I burn out the board (servo amp)
I'll have to replace it with a WK one (an it's potentiometer). Im hoping that
I won't use all that power on the tail, so the servo will not burn out.
Old Mar 09, 2012, 05:31 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
By the way, these are the manufacturer of this servo but unfortunately they do not appear to have any more data about this servo than is on this page.
http://www.pz-servos.com/en/products...etail&P_Id=798
Old Mar 09, 2012, 05:56 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
that is one cool looking servo. looks easy to do too. hmmm.. 0.3grams. now you got me thinking about swapping a few out with my cheapo 6mm pagers just so i can harvest some of the 5230 4mm for tiny planes. anybody know how many ohms for the stock 4mm?
btw bigger motors dont have to draw a lot. i got little 4mm tail motors from toy heli that draw 4x more than some of my 6mm ones.
Old Mar 09, 2012, 06:09 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
Thanks for the info about the manufacturer
Yap Dave, this is quick and easy.
p.s : you need to reverse the polarity of this motor, or you will have to also swap two wires from the potentiometer (and get
a reversed servo, like I did).
just measured the motors :
Orig:
10.4ohm
4mm diam'
8mm can length
0.42gr (with plastic pinion gear)
Repacement :
8.7ohm
4mm diam'
12mm can length
0.735gr (with plastic pinion gear)
These came off some crap "Assan" linear servos.
Old Mar 09, 2012, 06:36 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
thanks. so theres probably little difference in current. i would not worry about the drive transistors too much. smaller motors saturate much earlier than big ones and those drivers are often 4x-8x overdesigned from what i found testing to destruction.
my 6mm are only 0.4 gram more than my 4mm so im going to give that a try. looks like ill have to chop off a bit more than you.
Old Mar 09, 2012, 06:45 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
hmm..
I'm not sure 6mm would fit w/o cutting the main body..
which in turn will make it harder to place the motor at the correct spot.
But then again, if you managed to get this servo down to 1gr, your up
for the job
Also, the end weight delta will be < 0.4gr since you will be taking material out of the body and back cover of the servo, from my weight
tests today I noticed the back cover part I took off is ~0.03-0.04gr. so you prob' end up with +0.35
would be interesting to see the difference in your setup
Old Mar 09, 2012, 08:46 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Dave, not sure that will be true.
Well the big increase in torque has to come from somewhere! The voltage hasn't changed, the gears haven't changed and the speed was observed to stay the same (no change in mechanical advantage) so the current must have increased significantly to increase the force..
I think that's probably the answer. The output stage has FETs that can cope with significantly more current than the original motor. Nice.
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Scratchbuilt Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos JohnM Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 03, 2011 07:40 PM
New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) MegaTesla Scratchbuilt Indoor and Micro Models 10 Jan 31, 2011 12:59 AM
Sold Digital Micro Tail Servo 15.7g Almaz Aircraft - Electric - Helis (FS/W) 1 May 05, 2008 07:11 AM
Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? Wayno-san Scratchbuilt Indoor and Micro Models 7 Nov 26, 2005 11:18 AM
