Old Jan 02, 2012, 08:15 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i find these dont like old batteries. i think they would be awesome if they had good noise rejection in them. i might add a 3.3V regulator.........
nemoskull is offline Find More Posts by nemoskull
Old Jan 03, 2012, 11:56 PM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Originally Posted by DynamicFoamy View Post
The servo driver is @5.45v on the servo side and the 6110e is @5.01v on the servo side. What do you think the diodes would would add in grams?
Very little - maybe 0.25g at most. It's the same modification used for running the AR6400 on 2 cells.
Cheesehead is offline Find More Posts by Cheesehead
Old Feb 10, 2012, 01:30 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
dang it, when are they going to come back in stock? i have an order waiting for them
been checking every day for a few weeks, but nada so far.
derk is offline Find More Posts by derk
Old Feb 10, 2012, 02:43 AM
nemoskull's Avatar
Joined Sep 2009
i got one NIP, how bad do you want some?
Old Feb 10, 2012, 08:10 AM
awood12345 is offline
Find More Posts by awood12345
Epic Win or Epic Fail!
awood12345's Avatar
Kent, England.
Joined Dec 2001
I bought 4 of these 1.7g servos for use on a micro 3d model (Park180, 120mah 2s lipo and HK micro DSM2 Rx) but didn't realise they were for only 1s, damn it. What do I need to drop down the voltage or should I not bother and go for 4x New Power XL-2.0 instead?
As I'm using a beast Li-Po with 3 wires should I just run the power for the servos off the middle wire, its not a neat solution but It'll work as far as I can tell.
awood12345 is offline Find More Posts by awood12345
Old Feb 10, 2012, 09:21 AM
derk is offline
derk's Avatar
Joined Dec 2003
Thanks nemo, but I can wait just a nuisance is all. I need 2 of them at least for my next micro dlg
Old Feb 10, 2012, 10:40 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I'm running them on 2 cells in a scratch built VTO Pogo with the HK micro rcvr with no problems.
flypaper 2 is online now Find More Posts by flypaper 2
Old Feb 10, 2012, 04:58 PM
nemoskull's Avatar
Joined Sep 2009
be aware of binding. i have had a few self destruct (my fault, screwed with the pot signals) and started to melt. if they bind or are stalled too long id imagine the 2S would fry them faster.
just make sure they dont stall or bind.
Old Feb 15, 2012, 02:19 AM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Guys
Has anyone made a y cable or wired two of these servos together for use with dual ailerons?
If so, did it work okay?
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Feb 15, 2012, 05:14 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I'm using them as elevons on a scratchbuilt Vought Cutlass. They're working as well as any other servos. Working great!!.
Old Feb 15, 2012, 07:38 AM
nemoskull's Avatar
Joined Sep 2009
razor: yeah, i used twin servos as ailerons. worked great. cuz they are rotary, just flipped the horn to the other side. no problems.
(p..s i got 16 on order, he he!)
Old Feb 15, 2012, 11:04 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Awesome thanks guys
I might make a y cable, or just extend the leads and wire together so that on servo is in reverse rotation. I can use one as a bell crank, BUT, not sure how well that'd work with such small horns for maximum throw. I could always extend the horn length on either side to fix that, BUT...
Old Feb 15, 2012, 11:08 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
cool, have any threads/pics or vid of that cutlass?
Old Feb 15, 2012, 01:28 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Just took some pics for you. This is a scratchbuilt so I don't have any plans for it. I download 3 views, blow them up to size using a calculator. If its printed out at 6 in. wingspan, I multiply everything by 4 to get a 24 in. span. This is probably old school but I enjoy doing it this way as you can see it form as you draw pencil lines. This one came out to 18 in. Motor is the smallest of the blue wonder series, D1811-2000 Weighs 10 grams if I remember right. Plane WO batt. weighs 1.7 oz, or 48 grams and is made from $ Store foam.
Old Feb 15, 2012, 01:58 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
very nice dude
I build a 1S profile cutlass last winter, flew well indoors.
I should make another perhaps lol
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Scratchbuilt Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos JohnM Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 03, 2011 07:40 PM
New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) MegaTesla Scratchbuilt Indoor and Micro Models 10 Jan 31, 2011 12:59 AM
Sold Digital Micro Tail Servo 15.7g Almaz Aircraft - Electric - Helis (FS/W) 1 May 05, 2008 07:11 AM
Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? Wayno-san Scratchbuilt Indoor and Micro Models 7 Nov 26, 2005 11:18 AM
