I dont know if this will help. Igot 21g on the 50 gram gauge and 21g on the 100 gram guage. I will try one of the inlines from the 4site if I still have one working.
This reading was with 160nano charged several days ago. It was at the z bend in the outermost hole in the aileron arm that comes with the 5320. Up and down gave same reading and ailerons were also working at the same time. JCS As I was rereading this I probably am shorting the pull of these servos. I got the reading at the end of the movement not at a servo stalling point. I will have to devise a stand where I can load the guage at 21g and go from there. |
Bert |
Latest blog entry: Customer Support Forum
I might just try a few voltage-dropping diodes to reduce the voltage to a (regulated) 4.4v. |
The servo driver is @5.45v on the servo side and the 6110e is @5.01v on the servo side. What do you think the diodes would would add in grams?
I have 2o flights on 2 different planes using hk 415 rec and turnigy 6 esc without diodes, using Hyperion 180 2 cells. after normal 3d flight servos are not even warm.
I am going to standardise on 415,s and 5320 servos. The only drawback is you need a 1 cell esc and i havent received mine yet to see how well the 415 works on 1 cell. I tried with 2cell eflyte esc and thought motor was going to explode, thats when i knew I needed 1 cell esc's. JCS |
| Thread Tools | |
| Question Info needed on Nine Eagles Ultra Micro Linear Servos | Razors edge 29 | Indoor and Micro Models | 9 | Jul 13, 2011 10:02 AM |
| Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos | JohnM | Aircraft - Electric - Micro & Indoor Airplanes | 4 | Mar 03, 2011 07:40 PM |
| New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) | MegaTesla | Indoor and Micro Models | 10 | Jan 31, 2011 12:59 AM |
| Sold Digital Micro Tail Servo 15.7g | Almaz | Aircraft - Electric - Helis (FS/W) | 1 | May 05, 2008 07:11 AM |
| Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? | Wayno-san | Indoor and Micro Models | 7 | Nov 26, 2005 11:18 AM |
