Old Aug 27, 2011, 07:53 AM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
Where is a good source for servo extensions for these and the HK 2g 4 Channel DSM2 RX? All these different micro connectors has me scratching my head.
HK part numbers would be great long term but If you know of a US source that would be great as I wouldn't mind paying a bit extra for speedy shipment.
ducatirdr is offline Find More Posts by ducatirdr
Old Aug 27, 2011, 08:30 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
AFAIK HK don't have this extension, only the 2 pin one for batteries.
If Glenn at RC-Connectors doesn't have it it probably isn't available!
Great business to deal with and he is a forum regular.
Have a look in his store.
http://www.rc-connectors.com/
The bits to make your own easily (Pre attached plug on 6"" wire plus socket with solder pins) are here
http://www.rc-connectors.com/index.p...index&cPath=79
jj604 is online now Find More Posts by jj604
Old Aug 28, 2011, 08:23 PM
billyjim is offline
Find More Posts by billyjim
billyjim
Cullman, AL
Joined Jun 2007
Dropping micro parts on the floor
Originally Posted by RealGambler View Post
I never did something like that, no sir, never did....
Well, as a charter member of the Lost-On-The-Floor-Micro-Part (I go back to about 1960 re R/C stuff) I finally figured out how to find the little buggers (or else I read about this from someone else years ago):
1. Turn off all the lights in the shop.
2. Secure a flashlight that projects somewhat of a 'beam.'
3. Get down on the floor on your belly.
4. Slowly scan the floor in a rough 180-degree pattern.
5. It'll surprise you all the flotsam and jetsam that's down there.
6. But sooner or later you'll find the bugger, especially if it's bright metal, or all-white plastic.
This protocol has saved me from ending up a lost alcoholic any number of times in the past 50 years.
Good luck!
Bill
billyjim is offline Find More Posts by billyjim
Old Aug 28, 2011, 09:12 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Bill, that's my technique as well....
However when there is as much cr_p on your floor as there is on mine AND the servo was smoked and cost $3.57 originally there comes a time where time is money.
John
Good luck!
Bill
Old Aug 28, 2011, 10:35 PM
billyjim is offline
billyjim
Cullman, AL
Joined Jun 2007
John
JOHN: Yes, there comes a time when discretion is the better part of valor.
Bill
Old Oct 22, 2011, 11:27 PM
Magickid is offline
Find More Posts by Magickid
Wizard
Magickid's Avatar
Australia, QLD, Brisbane
Joined Jul 2011
Could i run these on 5v? I want some but 4.8v is the minimum for my Rx
Magickid is offline Find More Posts by Magickid
Old Oct 23, 2011, 05:57 AM
richos is offline
Find More Posts by richos
richos's Avatar
United Kingdom, England, Wells
Joined Mar 2008
jj604 if the Futaba micro connector is a molex (1.25mm) Connector, i think i have found a servo extension micro plug and a micro Y-harness connector .
The plug looks the same to me and it says (Futaba micro connector)
What do you think Guys ?
http://www3.towerhobbies.com/cgi-bin...P?I=LXGVD8&P=8
richos is offline Find More Posts by richos
Old Oct 23, 2011, 06:17 AM
ducatirdr's Avatar
Joined Aug 2006
Those should work. Just verify the servo polarity to the RX. The servo manufactures don't seem to follow the same polarity layout. I had to pull the pins on my servo's from their connectors to match the polarity of my HK RX. The Futaba connectors are the standard mini servo connector. Spektrum has non standard connectors. The DSM2 HK micro RX uses these Futaba connectors.
I bought my extensions from Glenn and just finished building the Eflite Cessna 150 with the HK RX and HK servo's.
Old Oct 23, 2011, 01:38 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
These are for the new planes Hobbyking are bringing out. These are like spare parts for them. They will work with the rotary servos.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 23, 2011, 04:48 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
boredom, do you mean you have found them at HK as well? I couldn't see them anywhere. The ones richos found are genuine Futaba at genuine Futaba prices I think.
John
Old Oct 23, 2011, 05:00 PM
Joined Nov 2007
John
I assumed, my bad. HK announced that they will have them within the next couple of days.
Old Oct 23, 2011, 07:18 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Excellent news. Thanks.
Old Oct 24, 2011, 05:48 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Here's another piece of good news. Particularly if you use the Spektrum AR6300 Rx or others with the same connector.
I sent HK a message about the connectors and got a reply.
Anthony, I think it would be really smart to supply your excellent 1.7g and 2.2g servos with both the Molex 1.25mm connectors (current version) AND 1.5mm JST-ZH connectors (AR6300)
Reply The product team are looking into this now.
Old Oct 26, 2011, 11:51 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Not quite extensions, but the male and female connectors with leads:
http://www.hobbyking.com/hobbyking/s...dProduct=19565
http://www.hobbyking.com/hobbyking/s...dProduct=19566
2 warnings:
*Male and female seem to be used in an sense opposite used by many: male metal plug = female plastic housing and vice-versa
*Both seem to be in back order.
flying-llama is offline Find More Posts by flying-llama
Old Oct 26, 2011, 01:41 PM
Joined Mar 2006
BPHobbies has some micro-futaba extensions (I think this is what is wanted, check wire polarity!):
http://www.bphobbies.com/view.asp?id=A0320122
http://www.bphobbies.com/view.asp?id...2&pid=D2038503
http://www.bphobbies.com/view.asp?id...2&pid=D2028502
http://www.bphobbies.com/view.asp?id...2&pid=D2038505
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Scratchbuilt Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos JohnM Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 03, 2011 07:40 PM
New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) MegaTesla Scratchbuilt Indoor and Micro Models 10 Jan 31, 2011 12:59 AM
Sold Digital Micro Tail Servo 15.7g Almaz Aircraft - Electric - Helis (FS/W) 1 May 05, 2008 07:11 AM
Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? Wayno-san Scratchbuilt Indoor and Micro Models 7 Nov 26, 2005 11:18 AM
