Old Aug 11, 2011, 08:07 AM
Tim Cullip is offline
Find More Posts by Tim Cullip
Tim Cullip's Avatar
United States, NC, Pittsboro
Joined Aug 2003
Thanks, that will be useful information for future purchases.
Tim
Originally Posted by jj604 View Post
Just for the record (in order of decreasing size)
1) AR6300 are 1.5mm spacing JST-ZH
2) The HK 1.7 and 2.2g servos are Molex Picoblade 1.25mm spacing. Used on the Micro Futaba and Walkera servos and FlyDream 1g Receiver.
3) AR6400 and HK Super Micro are JST-SH with 1mm spacing
Tim Cullip is offline Find More Posts by Tim Cullip
Old Aug 11, 2011, 05:12 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Tim, the new HK 2g 4 Channel DSM2 receiver also has the Molex 1.25mm connectors so these servos will plug straight in (assuming they have been consistent with the wiring polarity!).
Makes a nice lightweight unit at $9.99 for the Rx and $3.57 for servos.
John
Tim
jj604 is online now Find More Posts by jj604
Old Aug 11, 2011, 05:16 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
1.7 horns compared to the 2.2 horns
boredom.is.me is offline Find More Posts by boredom.is.me
Old Aug 11, 2011, 06:00 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
any body have any info and what there servos draw amp wise??
nemoskull is offline Find More Posts by nemoskull
Old Aug 11, 2011, 07:42 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
This is pretty rough as I was just using a DVM on the 10Amp range to minimize the insertion loss. DVM's aren't very nice for looking at fluctuating currents.
Best estimates with a Hyperion 240mAh 1S:
FlyDream 1g Rx plus 1 servo
Idle = 16mA
Moving with no load 120-140mA (This will be the peak when it starts, should be less when moving)
Fully stalled 280-300 mA
John
Just one sample, done in a hurry - the usual disclaimers about accuracy.
Old Aug 12, 2011, 12:11 AM
nemoskull's Avatar
Joined Sep 2009
well that sucks. i was hoping to run these directly off of a AVR, elimnate some weight.
hang on, the 32 TQFP might handle 400mah.... let me look up the data sheet......
nope, 200mah total, sourced and sunk. well, i am going to try it anyways.
he he.
Old Aug 12, 2011, 02:35 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
You'll save more weight by drilling holes in the casing
MegaTesla is offline Find More Posts by MegaTesla
Old Aug 12, 2011, 12:20 PM
flashkick is offline
Find More Posts by flashkick
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
these look really nice. probably going to pick a bunch up with some of those new dsm2 rxs. just got to wait till somebody confirms that they fit together.
flashkick is offline Find More Posts by flashkick
Old Aug 12, 2011, 11:03 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
I managed to cook one so pulled it apart to have a look at the construction.
(Memo to self - the Red wire connects to the Positive...)
The top gear is removed because (choose one):
1) It gives you a better view
2) It fell on the floor and I couldn't find it
I think the mechanical design is quite good. The properly cut insulator between the Pot and PC board, the clever little tab that acts as a case retainer and a very effective cable anchor and the single long screw which really stiffens up the whole assembly and makes it robust. Gears look very clean and as previously mentioned the servo runs very smoothly and quietly.
Imagine having to assemble these little buggers all day.
Old Aug 13, 2011, 04:24 AM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
Ouch!
I wonder how much the lead and the bottom part of the casing weighs.
With the Blue Arrow servos I always replaced the lead with thin enamelled copper wire and removed the bottom of the casing.
Old Aug 13, 2011, 06:00 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Mega, the lead and lower case together weigh 0.412g. The screw, which you would also leave out if you remove the lower case, is 0.052g.
Originally Posted by MegaTesla View Post
Ouch!
Old Aug 13, 2011, 07:18 AM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
A significant weight saving. Thanks for weighing it.
Old Aug 14, 2011, 02:19 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Both these small servos have identical leads. 4.5"/10.5cm with Molex connectors that fit FlyDream, Futaba micro and Walkera but not the Spektrum AR6300 or 6400.
Some of the threads on using Walkera servos with an AR6300 (mini-JST sockets), including one on fitting a Walkera with separate components (non-Walkera Rx and Gyro), have mentioned 2 ways to fit a Walkera-type plug into the wider spacing AR6300 socket:
1. Push in with some added force (I have not tried).
2. On the Walker plug, widen the 2 outer pin holes a little (widen on the side away from the other wires). The plug will then fit into an AR6300 socket (but watch the wiring order!: pop out 2 of the plug's wires [and "pins"] and swap).
I have successfully tried this using a Walkera ~3.5g servo and a GWS Pico Rx (mini-JST sockets).
flying-llama is offline Find More Posts by flying-llama
Old Aug 14, 2011, 06:11 AM
richos is offline
Find More Posts by richos
richos's Avatar
United Kingdom, England, Wells
Joined Mar 2008
Have a look at this. what do you think Guys !
Is the Kyosho 2.5g servo for the new MINIUM WARBIRD SERIES Spitfire and Zero from the same factory as the HK-282 Ultra-Micro Servo 2.2g . Also is the plug a Molex 1.25 on the kyosho servo.
http://www.kyosho.com/eng/products/r...duct_id=107525
http://www.hobbyking.com/hobbyking/s...g_0_08sec.html
richos is offline Find More Posts by richos
Old Aug 14, 2011, 06:14 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
I never did something like that, no sir, never did....
RealGambler is offline Find More Posts by RealGambler
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Scratchbuilt Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos JohnM Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 03, 2011 07:40 PM
New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) MegaTesla Scratchbuilt Indoor and Micro Models 10 Jan 31, 2011 12:59 AM
Sold Digital Micro Tail Servo 15.7g Almaz Aircraft - Electric - Helis (FS/W) 1 May 05, 2008 07:11 AM
Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? Wayno-san Scratchbuilt Indoor and Micro Models 7 Nov 26, 2005 11:18 AM
