Old Mar 15, 2013, 05:08 PM
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by Bare View Post
Interesting indeed.
But isn't one of the unspoken/glossed over (?) downsides of digitals being that they suck current... merely holding position ?
They do seem to suck current.
That is a trade-off:
digital: can use a lighter servo, but draws more current
analog: will need a heavier servo, but draws less current
In my case, I will be connecting to a 3 axis gyro system, so any servo will start drawing more curren from all the corrections issued by the gyros. The gyro system vendor recommended an external BEC for the servos, etc. so as not to fry the ESC.
LATER:
I dug up some numbers from my testing (using a Watts-Up meter, connected a 5V BEC via a Silicon diode to drop the voltage a little, and pushing the end of the servo arm against a scale):
HKM-282A analog servo ("2.0g"): ran at ~0.19A peak about when the servo gave way at ~130g (using a slightly longer arm than the 2 digital servos below)
HK5320 digital servo ("1.7g"): ran at ~0.28A peak about when the servo gave way at ~250g
HK5330 digital servo ("1.9g"): runs at 0.25 to 0.30A peak when arm tip is pushed to 400 to 425g (servo still not giving way)
some recent 3 to 4g Walkera digital servos: ran at 0.10 to 0.15A peak when arm tip is pushed to >400g (servo still not giving way)
I stopped at about 400g of pushing because that is almost 1 pound for a servo that will go into a plane with AUW= 6 ounces or less (sorry for all the mixed units).
Anyways, these small digital servos eat up some current, but not that much (looks like < 1A for 3 servos, while I expect more than that for the motor), and not all that much more than my analog. The larger, heavier digital servos have the advantage of using less current to exert the same amount of force that I was using.
flying-llama is offline Find More Posts by flying-llama
Last edited by flying-llama; Mar 15, 2013 at 10:12 PM. Reason: Give some measurements
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos JohnM Aircraft - Electric - Micro & Indoor Airplanes 4 Mar 03, 2011 07:40 PM
New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) MegaTesla Indoor and Micro Models 10 Jan 31, 2011 12:59 AM
Sold Digital Micro Tail Servo 15.7g Almaz Aircraft - Electric - Helis (FS/W) 1 May 05, 2008 07:11 AM
Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? Wayno-san Indoor and Micro Models 7 Nov 26, 2005 11:18 AM
