Old Mar 09, 2012, 09:50 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
actually, like with bldc, diameter has as much or more to do with torque than coil impedance or magnet strength. its the main reason outrunners are so much more torquey at low speed than inrunners. the real issue is how efficient is the motor and those with large diameter, powerful magnets, and/or big coils, will not only be stronger motors for a given input (more efficient) but also do so with less heat at maximum.
apparently size does matter.
its also why its hard to make really tiny bldc that perform well. in fact guys in the micro area are convinced tiny pagers are better for a given weight than brushless. as we know at larger scales the reverse is true.
regarding servo drivers im not sure these are fets but from experiments with n20 and bigger i was shocked at how much abuse these little pcbs take when stalling with my finger with a meter in series. even bipolars took a lot before frying.
dave1993 is offline Find More Posts by dave1993
Old Mar 10, 2012, 08:48 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
well i started out intending to swap the 4mm stock pager with 6mm from my junk box that draw less current but have more torque. that plan didnt work out so i ended up just trimming weight. instead of cluttering up this thread with ot baloney i started a new one just for weight reduction:
http://www.rcgroups.com/forums/showt...6#post20993014
Old Mar 10, 2012, 09:45 AM
axelen is offline
Find More Posts by axelen
OpenGL C/C++ programer
axelen's Avatar
Israel
Joined Dec 2006
Nice work mate !
axelen is offline Find More Posts by axelen
Old Mar 20, 2012, 07:38 AM
lemuel is offline
Find More Posts by lemuel
Australia, QLD, Brighton
Joined Sep 2006
Hi guys, I am not used to dealing with this small stuff. I have just bought a turnigy 9x radio. What is the smallest receiver that I can use for small servos like this??
lemuel is offline Find More Posts by lemuel
Old Mar 20, 2012, 07:39 AM
lemuel is offline
Joined Sep 2006
Forgot to ask, can you use these small servos in a basic Hobbyking transmitter?
Old Mar 20, 2012, 08:22 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
You can use these servos with any receiver. You just need the right plug and polarity (wire orientation).
boredom.is.me is offline Find More Posts by boredom.is.me
Old Mar 20, 2012, 08:56 AM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
These servos appear to be back in stock right now, if anyone's looking for them
http://www.hobbyking.com/hobbyking/s...c_0_075kg.html
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Mar 20, 2012, 09:11 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
iirc theunissons tiny dsm2 modules (deltang.com?) are the smallest if you dont mind paying 50 bucks or so ea. for cheap sobs like me here are some from hk almost as small for around 10 bucks:
http://www.hobbyking.com/hobbyking/s...uperMicro.html
lowest cost solution by far are the 3ch flysky rx i got for $3 that work with the 9x right out of the box. so no modules to buy. not quite as small as the others though.
Old Mar 20, 2012, 09:17 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
http://www.hobbyking.com/hobbyking/s...Receiver_.html
The servos plug directly into this Spektrum compatible rcvr and is what I'm using in the Cutlass above in post 119
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Mar 20, 2012, 12:44 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i got the Deltang rx34 for 43 shipped. BSD micro did not have any in stock, and micronradio in the uk ended up being cheaper with shipping anywaysss. tho i am still waiting on it....
nemoskull is offline Find More Posts by nemoskull
Old Aug 21, 2012, 03:23 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Larger, faster, stronger version of HK-5320?
I just noticed this:
HK-5330 Ultra-Micro Digital Servo 1.9g / 0.04sec / 0.17kg
http://www.hobbyking.com/hobbyking/s...ec_0_17kg.html
It looks like a HK-5320 with a longer motor that sticks out.
Specs are more torque and faster than the HK-5320.
flying-llama is offline Find More Posts by flying-llama
Old Aug 21, 2012, 05:01 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
The other difference is that they aren't on backorder (yet).
jj604 is online now Find More Posts by jj604
Old Aug 21, 2012, 07:56 PM
nemoskull's Avatar
Joined Sep 2009
anyoen notice how the hk5320 used to cost 2.81, and now cost 3.55?
Old Aug 21, 2012, 09:45 PM
Joined Nov 2007
You are indeed correct.
Old Aug 22, 2012, 01:12 PM
nemoskull's Avatar
Joined Sep 2009
i hate being right.
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Scratchbuilt Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos JohnM Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 03, 2011 07:40 PM
New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) MegaTesla Scratchbuilt Indoor and Micro Models 10 Jan 31, 2011 12:59 AM
Sold Digital Micro Tail Servo 15.7g Almaz Aircraft - Electric - Helis (FS/W) 1 May 05, 2008 07:11 AM
Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? Wayno-san Scratchbuilt Indoor and Micro Models 7 Nov 26, 2005 11:18 AM
