Old Jul 23, 2011, 01:20 PM
Tim Cullip is offline
Find More Posts by Tim Cullip
Tim Cullip's Avatar
United States, NC, Pittsboro
Joined Aug 2003
Any Info on: HK-5320 Ultra-Micro Digital Servo 1.7g
Just saw Hobby King listing this servo: HK-5320 Ultra-Micro Digital Servo 1.7g
http://www.hobbyking.com/hobbyking/s...c_0_075kg.html
Anyone have any information on it (looks like a brand new listing so maybe no one has actually gotten one yet)? Listed as 1.7 gms which would be mighty light for a cased servo (but we all know about HK's weight listings - anyone have the real weight?).
Torque looks pretty low, but not suprising given the weight and the fact it is a 1S servo only.
Tim
Tim Cullip is offline Find More Posts by Tim Cullip
Old Jul 23, 2011, 11:04 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I ordered two yesterday, but will be changing out the wires and stuff so won't be able to comment on it for a while. I also want to color them black. What might be my best bet for doing this?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 24, 2011, 06:38 AM
Tim Cullip's Avatar
Joined Aug 2003
Thanks for the response. Can you weigh them when they arrive (before you start your surgery)? As for coloring them black, I would try a black Sharpie pen (I've turned GWS orange props black with them with no discernable weight gain.).
Tim
Old Jul 24, 2011, 08:37 AM
Joined Nov 2007
Will do and thanks for the tip.
Kev
Old Jul 28, 2011, 05:15 PM
JCHarrist is offline
Find More Posts by JCHarrist
Foam Fiend
JCHarrist's Avatar
Anchorage, Alaska
Joined Dec 2004
Just got some of these and they weigh in right at 1.7 grams on my triple beam.
Man, are these things tiny!
JCHarrist is offline Find More Posts by JCHarrist
Old Jul 28, 2011, 05:22 PM
Joined Nov 2007
Wow you got yours fast.
Old Jul 28, 2011, 07:55 PM
Tim Cullip's Avatar
Joined Aug 2003
JCHarrist,
Looks promising as far as weight and size (definitely smaller than the 2.5gm servo).
Have you had a chance to hook it to a Rx yet and test it out? Interested in knowing how well they work (speed, torque, jitter, reproducible positioning, etc.).
Don't suppose you know what's inside yet (motor size smaller than 4mm?, does it use a potentiometer or something else like a hall sensor?, how many gears from motor pinion to output gear).
I've ordered two of these and they shipped today so hopefully they will show up reasonable soon and work well.
Tim
Old Jul 28, 2011, 11:39 PM
Foam Fiend
JCHarrist's Avatar
Anchorage, Alaska
Joined Dec 2004
Just got one hooked up and I must say I'm impressed. No jitter whatsoever and excellent centering and repeatability. The speed is faster than I can move my sticks. Not a ton of torque, but should be more than sufficient for most ultra micro size aircraft.
I haven't taken one apart yet to inspect the internals and probably won't unless I have an issue with one.
Old Jul 29, 2011, 12:33 AM
Joined Nov 2007
That is great to hear. I'll be the dumby to take one apart when I get it. My cousin is a photographer so I can get hi-def pics of everything for you all.
Old Jul 29, 2011, 11:27 AM
Foam Fiend
JCHarrist's Avatar
Anchorage, Alaska
Joined Dec 2004
For what it's worth,I just bench tested one on a 2S lipo with a 5V BEC and it seems to handle it fine.
Old Aug 05, 2011, 01:31 PM
Joined Nov 2007
I got mines. I open one up to get some pics...later because I do not have a screwdriver on hand...
They really are tiny.
EDIT:
They are NOT ar6400 compatible.
Old Aug 05, 2011, 02:09 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
EDIT:
Then they must be micro Futaba/Walkera (same as HK-282, 2.2 gram). Would be great if HK learned to give their stuff accurate description
coriolan is online now Find More Posts by coriolan
Old Aug 05, 2011, 02:38 PM
Joined Nov 2007
I could have sworn they said it had ar6400 compatible plugs. Was I just seeing what I wanted to see?
It isn't there now.
http://www.hobbyking.com/hobbyking/s...dProduct=17540
Old Aug 05, 2011, 03:15 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Pics!!!!
MegaTesla is offline Find More Posts by MegaTesla
Old Aug 05, 2011, 03:28 PM
Joined Nov 2007
Give me a second. These won't be the high def pics though. Not really much to see as I forgot my screwdriver.
EDIT: I have to go, but I'll be back in about two and a half hours.
Question Info needed on Nine Eagles Ultra Micro Linear Servos Razors edge 29 Scratchbuilt Indoor and Micro Models 9 Jul 13, 2011 10:02 AM
Sold 4 NIP HobbyKing 1.7g Ultra Micro Linear Servos JohnM Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 03, 2011 07:40 PM
New Product 3.7g Metal gear micro servo from HK (Available now for ~$22) MegaTesla Scratchbuilt Indoor and Micro Models 10 Jan 31, 2011 12:59 AM
Sold Digital Micro Tail Servo 15.7g Almaz Aircraft - Electric - Helis (FS/W) 1 May 05, 2008 07:11 AM
Question Hyperion Ultra-Micro 3.7g Servo? Good/Bad? Wayno-san Scratchbuilt Indoor and Micro Models 7 Nov 26, 2005 11:18 AM
