Old Jul 23, 2011, 11:14 AM
hotflyer80 is offline
Find More Posts by hotflyer80
hotflyer80's Avatar
Joined Oct 2008
Full wing spar for SPAD 3DT?
I am building the SPAD 3DT, and I am currently at the part where I need to dill the hole in the fuse to then force the 5/32 music wire through BOTH the wing and the aluminium fuse (this is the major difference between the 3D and the 3DT). In the instructions it says cut the spare down to 18", but if I just left it at 36" (which is also the width of the wing) would that have any negative effects on it?
hotflyer80 is offline Find More Posts by hotflyer80
Old Jul 24, 2011, 04:27 PM
bverwolf is offline
Find More Posts by bverwolf
Montana, USA
Joined Sep 2008
It would add a little more weight. I have the Spa3dt with the shorter spar and I've never had any trouble with the wing flexing. I don't fly mine fast although. It doesn't like to fly fast. I usually fly it around sort of "hanging it on the prop."
Also in my opinion, I think the normal spa3d would fly better as it would be lighter with the U channel fuse. The Spa3dt seems to be heavy with the square tubing fuse. Just my 2 cents...
Ben
bverwolf is offline Find More Posts by bverwolf
Old Jul 24, 2011, 06:14 PM
hotflyer80's Avatar
Joined Oct 2008
Ok thanks, by the way what size prop are you using?
Old Jul 25, 2011, 01:52 PM
bverwolf is offline
Montana, USA
Joined Sep 2008
I'm using a 12.25x3.75 prop on a Magnum XLS 46.
Old Jul 26, 2011, 10:31 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I would agree, with the planes the ailerons and elevator will get shadowed by the air slip stream if you go too fast with them. They were intended to fly around slow. But it is great slow flying and hovering practice though.
Here is mine, I am running a 12x4 prop on the Fox .45 engine on it.
earlwb is offline Find More Posts by earlwb
Mini-HowTo Molded wing repair - smashed spar & joiner boxes Phil.Taylor Slope 14 Jul 26, 2011 09:44 AM
Discussion Wing Spar Ideas? theleetbeagle Electric Plane Talk 5 Mar 15, 2011 10:24 PM
Discussion Bagged wing w/ spar, d-tube, and "sheet ribs"? DKNguyen Composites Fabrication 3 Mar 10, 2011 02:05 PM
Discussion SPAD wing spar question maosl SPAD - Simple Plastic Airplane Designs 48 Dec 16, 2010 08:39 AM
Discussion Best type of spar for full span of wing Lite2bolt Multi Task F3X 10 Nov 16, 2008 03:45 PM
