Old Jul 23, 2011, 10:24 AM
The Don is offline
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked Powered Hobbyking 64mm Stinger EDF
Here is my build log for the Hobbyking Stinger 64mm EDF
Setup:
Wicked 4000 Plus motor
EDO Type 1 fan
Pentium 60 ESC
4S 2200 40C Skylipo
Don
The Don is offline Find More Posts by The Don
Old Jul 23, 2011, 10:38 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Some quick notes on the build.
1) If you are going to fly 4S I suggest removing the foam first in the body before starting. You may not depending on your lipo brand.
2) I modified the aileron control horns so they were more streamlined (see photos)
3) CG range per the manual is 60-70mm from the front of the wing, as shown in the last photo with the 4S 2200 lipo was at ~63mm.
4) The thrust tube butts up to the back of the fan unit it does not go over it. The tube is taped to the housing outside diameter.
5) The mounting screws:
The short one with the wide head is what holds the rudder to the stab. The two longest screws with a portion of unthreaded area are for the wing leading edge and the shorter ones are for the wing trailing edge and the stabilizer. Tighten until snug or you will strip them out! I happen to like how well it bolts together. No slop.
Old Jul 23, 2011, 11:03 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
subscribed
pavcon is offline Find More Posts by pavcon
Old Jul 23, 2011, 11:54 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
Nice.
What diameter are your thrust tube end? ~52mm?
I was thinking of putting the aileron servo arm trough the top off the wing. No chanse to damage in landings on grass that way. I have done that on my Graupner Mirage 2000 and it works well.
MagnusEl is offline Find More Posts by MagnusEl
Old Jul 23, 2011, 12:08 PM
FusionTiger is offline
Find More Posts by FusionTiger
Joined Dec 2007
Hey Don, where is your RX located? Ive been having trouble finding a good spot to mount the RX.
Ooo! Saw it!
In picture with 'Pentium 60 installed on the floor.' caption.
However, is that spot ideal for >500m flight? I am using a rather similar RX which also has the little antenna.
FusionTiger is offline Find More Posts by FusionTiger
Old Jul 23, 2011, 03:24 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Sweet
Can't wait to see vids Donny
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jul 23, 2011, 04:25 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Originally Posted by MagnusEl View Post
Nice.
51.5mm is what I use when calculating the thrust tubes.
Old Jul 23, 2011, 04:27 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Actually I swapped for an Optima 7 receiver. The receiver is now located in the upper part of the fuselage where the motor wires are. It just sort of fit in there nicely.
Don
Old Jul 23, 2011, 07:14 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
What speeds do you figure this might do Don?
100 - 120ish ?
Old Jul 23, 2011, 07:59 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Probably about 100 mph. If the model was a little cleaner then more mph but this kit like so many other foamies (except the Phase 3 f-16 and Alfa EDF models) has a 1/4" thick trailing edge on the wing, stab, and fin so that eats power. Its OK when you go 60-70 mph but is an issue at 100 mph.
Old Jul 23, 2011, 08:56 PM
tdab is offline
Find More Posts by tdab
tracey=Col Frank Fitts
tdab's Avatar
Carolina's
Joined May 2004
Wow, It really looks like it would be faster than that from the static pics. Oh well. Most of the 64mm planes out now with those thick trailing edges hit that wall about 95 as you said.
Speaking of the P3 F16, I just came back from flying mine tonight on a Wicked+4000/64mm EDO1 and oh my gosh....Maybe 110-115.....I guess it doesn't need a re-balance after all!
Edit: I am still on the fence about the power system for this Stinger......The smallest 4s lipos I have are the Rhino 25c 4s2350's...the long slender ones...but they are 260g. I know if I go 3s, I will want to change it out after a week!
tdab is offline Find More Posts by tdab
Old Jul 24, 2011, 11:05 AM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
C'mon Don ... get us some video!
I also really like the way this one bolts together.
My stocker needs more power though now.
Bajora is offline Find More Posts by Bajora
Old Jul 24, 2011, 11:09 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I am hoping to fly later today. Right now windy with possible rain.
Old Jul 24, 2011, 11:13 AM
tdab is offline
tdab's Avatar
Carolina's
Joined May 2004
That is why I should just pony up for 4s from the start.
Old Jul 24, 2011, 11:20 AM
Bajora is offline
KA6KHM
Bajora's Avatar
Joined Sep 2004
True .... BUT, depending on your skill level, the Stinger on the stock power system could be a good, er, dare I say EDF trainer? It is not exactly a slouch on the stock system. Going 4S will increase the wing loading a bit. A lighter airframe is usually a little safer for newer EDF folks ... more forgiving.
It looks like the Stinger will accommodate a several different power systems, from a lightweight stock 3S system to Dons higher powered, 4S performance EDF systems. EDF pilots with a little more experience will no doubt gravitate to what Don is doing with his.
Discussion $129.95 Dynam 4-Ch 64mm EDF Brushless-Powered RC Remote Control Jet RTF wnppmy Electric Ducted Fan Jet Talk 5 Jul 07, 2013 07:35 PM
For Sale Don's Wicked 4800 mounted in a dynamically balanced 64mm EDO Type I EDF Unit. jhamm Aircraft - Electric - Jets (FS/W) 1 Jun 06, 2010 07:03 AM
Sold Don's Wicked 4000KV EDF with 2 64MM Fans jafo216 Aircraft - Electric - Power Systems (FS/W) 3 Mar 30, 2009 08:04 PM
