United Kingdom, England, Halifax
Joined Oct 2011
Code Description Qty STATUS
PCB004 Hobbyking Parallel charging Board for 6 pack 1 Reserved HKS9257-Gear HKS9257 - Replacement Gear Set 1 Reserved OR023-01601 Carbon Fiber Helicopter Blade Balancer 1 Reserved WH-4MM-BLACK Turnigy 4mm Heat Shrink Tube - BLACK (1mtr) 1 Reserved WH-3MM-BLACK Turnigy 3mm Heat Shrink Tube - BLACK (1mtr) 1 Reserved WHS-3MM-RED Turnigy 3mm Heat Shrink Tube - RED (1 1 Reserved WHS-4MM-RED Turnigy 4mm Heat Shrink Tube - RED (1 1 Reserved V2-133 HK450V2 Tail Support Rod 1 Reserved http://www.hobbyking.com/buddy.asp?c...4-5A0764E1FD46 http://www.hobbyking.com/buddy.asp?c...7-7900A093C57F http://www.hobbyking.com/buddy.asp?c...2-C966EE8D8052 http://www.hobbyking.com/buddy.asp?c...6-5DF29F4A07CB http://www.hobbyking.com/buddy.asp?c...0-9F0A636AD28B http://www.hobbyking.com/buddy.asp?c...4-7AB19E38356B http://www.hobbyking.com/buddy.asp?c...7-AC994DA7BBA2 http://www.hobbyking.com/buddy.asp?c...7-56CDC9211DA3 |
Australia, VIC, Narre Warren
Joined Jun 2011
Propeller Adapter (Colet Type) 4MM
![]() http://www.hobbyking.com/buddy.asp?c...5-A90F181096C7 30CM Servo Lead Extention (Futaba) 26AWG (10pcs/set) ![]() http://www.hobbyking.com/buddy.asp?c...1-8E4A13DD2D68 |
Hobby King buddy codes - Valid for 14 days:
4mm Banana to XT60 charging cord....save $0.46 http://www.hobbyking.com/buddy.asp?c...D-52A83B21F958 4mm Banana plugs (solder type)...save $0.34 http://www.hobbyking.com/buddy.asp?c...1-E524D48EABD3 |
Joined Oct 2011
Find my codes here: http://hk.rc-international.info/swarm/shkimran (valid until May 28, 2012)
BMS-L530DMG Digital Servo (MG) 19.8kg / .15sec / 140.5g Save US$: 23.99 ![]() Control Rod/ABS Sleeve (1pc/bag) Save US$: 0.27 Alloy Clevis for Non Threaded 2mm Control Rod Save US$: 0.08 Nylon Arm 2.8 x 6 x 6mm (10pcs) Save US$: 0.06 ![]() Nylon Snap-Click style clevis 2x8x23mm (10pc) Save US$: 0.31 ![]() Nylon Arms 2x6x7.5mm (10pcs) Save US$: 0.63 ![]() Linkage Stopper M3x2xL11.2mm (10pcs/set) Save US$: 0.55
Hello everybody, find my codes here: http://hk.rc-international.info/swarm/chriscool (valid until June 03, 2012)
Hobby King Quadcopter Power Distribution Board Save US$: 1.71 ![]() 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) Save US$: 1.72 ![]() Spiral wrap tube ID 5mm / OD 6mm (Black - 2 Metre) Save US$: 0.10 ![]() Hatch Hinge 33x9mm (10pcs) Save US$: 0.70 ![]() Turnigy Imperial Hex Driver Set (050, 1/16, 5/64 & 3/32) 4pc Save US$: 0.60 ![]() Cable/Wire Holder (10pc) Save US$: 0.16 |
Joined Oct 2011
Find my codes here: http://hk.rc-international.info/swarm/shkimran (valid until June 05, 2012)
Turnigy S8166M Servo 154g / 33kg / .21sec Save US$: 4.08 ![]() Spinner for folding Prop (large) Save US$: 0.30 ![]() Insta-Set CA Accelerator 2. oz Save US$: 0.93 ![]() 2.5x8mm Countersunk Screw (10pcs/pack) Save US$: 0.96 ![]() Insta-Cure Super Thin CA 1. oz Save US$: 1.04 ![]() Un-Cure CA Debonder 1. oz Save US$: 0.59 ![]() Alloy E-Prop Spinners AC376 3.17mm to 6.35mm Save US$: 0.53 X-BLADE Spare SK-5 Steel blades (10pcs/set) Save US$: 0.63 ![]() Mni Drill Bit Set (14pc) Save US$: 1.49 Nylon Spinner 1.5inch Save US$: 0.77 ![]() Nylon Spinner 2.25inch Save US$: 0.25
United States, TX, Rockwall
Joined Oct 2011
OR001-00310A Slow Fly E-Prop 10x3.8 / 254x96.5mm w/ Adapters $2.54
http://www.hobbyking.com/buddy.asp?c...2-7C80739D9A77 450-0024 Simple Prop Balancer $1 http://www.hobbyking.com/buddy.asp?c...4-2048970D288D TP_11x3.8 TP Slow Fly propeller 11x3.8 $0.73 http://www.hobbyking.com/buddy.asp?c...0-E62B102DF2A9 CS928BB Corona 928BB Servo 2.0kg/ 9g/ 0.13sec $2.60 http://www.hobbyking.com/buddy.asp?c...8-92BDD610ACF6 |
Joined Dec 2010
Find my codes here: http://hk.rc-international.info/swarm/rcpilotaero (valid until June 09, 2012)
Sullivan Pull-Pull Cable Kit 2-56 40lb Save US$: 1.46 ![]() Z-bend Pliers. Heavy Duty 90deg up to 1/16 Save US$: 1.64 ![]() HK450V2 Tail Boom Save US$: 0.74 ![]() Prop nut - Suit 5mm Shaft (2 pc) Save US$: 1.36 ![]() Turnigy Redundant Dual 8A UBEC Rx Power System Save US$: 5.85
More buddy codes:
Turnigy 9X LCD Backlight Kit - Blue (DIY) http://www.hobbyking.com/buddy.asp?c...0-98DFE69466F5 FrSky FVAS-01 Telemetry Variometer Sensor http://www.hobbyking.com/buddy.asp?c...E-B6BEECB78281 FrSky FSH-01 Telemetry Sensor Hub http://www.hobbyking.com/buddy.asp?c...9-9B33FCCB5692 USBasp AVR Programming Device for ATMEL proc http://www.hobbyking.com/buddy.asp?c...E-9EC538B42B6E |
http://www.hobbyking.com/buddy.asp?c...5-F461E179F721
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board |
Another option for KK2.0 board. Now with accelorometers.
http://www.hobbyking.com/buddy.asp?c...4-6BB4A7971827 |
Hello,
Enjoy ![]() http://hk.rc-international.info/swarm/chriscool (valid until July 05, 2012) Hobbyking Lipo to USB Charging Adapter Save US$: 1.37 ![]() Hobby King Discovery Buzzer Save US$: 0.38 Scale National Air Force Insignia Decal Sheet - Swiss (small) Save US$: 0.60 ![]() Threaded Ends M2xL20mm (10pcs/set) Save US$: 0.94 ![]() Control Horns 13.5x16mm (10pcs) Save US$: 0.36 ![]() Glass Fiber Cloth 450x1000mm 48g/m2 (Ultra Thin) Save US$: 0.19 ![]() TURNIGY Voltage Protector Save US$: 1.38 Cable/Wire Holder (10pc) Save US$: 0.16 TURNIGY 3~8S Voltage Detector Save US$: 0.66
Joined Oct 2011
Find my codes here: http://hk.rc-international.info/swarm/shkimran (valid until July 05, 2012)
TGS Sport 12x8E Precision propeller Save US$: 1.98 ![]() Soft Ferrite Rings 16x7x10 (5pc) Save US$: 0.61 ![]() Servo Terminals (JR) Gold Plated (10pairs/set) Save US$: 0.58 ![]() Metal Push Rods M2xL300 (10pcs/set) Save US$: 0.70 ![]() Insta-Set CA Accelerator 8. oz Save US$: 2.00 ![]() Control Horns (X-LARGE) 60x30mm (10pcs/bag) Save US$: 0.99 ![]() Horn X-Large w/ Clevis 40x30mm and eyelet (5pcs/set) Save US$: 0.39 ![]() Turnigy 1450mAh 3S 11.1v Transmitter Lipoly Pack Save US$: 2.80 ![]() Maxi-Cure Extra Thick CA 2. oz Save US$: 1.85
| Thread Tools | |
| Alert HobbyKing BuddyPrice Codes for more products, use as you wish | obuggy | HobbyKing | 5109 | Yesterday 09:10 PM |
| Yippee! Hobbyking working Buddy Codes inside from my hexacopter orders | bikertje888 | Multirotor Talk | 4 | Aug 15, 2011 12:05 PM |
| Alert HobbyKing discount buddy codes New codes 6/2011 | HydroPilot | Hot Online Deals | 0 | Jun 30, 2011 11:49 PM |
| Alert HobbyKing BuddyPrice Codes for Propellers and Motors | Mayer74 | Hot Online Deals | 0 | May 19, 2011 04:11 AM |
| Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor | lrplin | Hot Online Deals | 5 | May 18, 2011 01:38 PM |
