Old Jan 03, 2013, 09:41 AM
BlackBeast's Avatar
Canada, QC, Témiscouata-sur-le-Lac
Joined Dec 2008
Find my codes here: http://hk.rc-international.info/swarm/blackbeast (valid until January 16, 2013)
Dr Mad Thrust 3000kv 1300w 70mm EDF Inrunner Motor 4s version (29mm) Save US$: 1.14
FPV Fiberglass Pan-Tilt Camera Mount Save US$: 0.94
DIY Bixler FPV Camera Mount Save US$: 2.26
Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin) Save US$: 0.29
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
BlackBeast is offline Find More Posts by BlackBeast
Old Jan 05, 2013, 05:30 AM
"Kneel before Zod!"
turbovector's Avatar
Tacoma, WA. USA
Joined Dec 2003
Code for US warehouse, good until 1/18/2013.
Zippy compact 3s 500mah 35c
http://www.hobbyking.com/buddy.asp?c...7-CA1DE219394E
turbovector is offline Find More Posts by turbovector
Old Jan 06, 2013, 08:16 PM
ptflyer's Avatar
Connecticut
Joined Oct 2008
USA warehouse...Turnigy nano-tech 1300mAh 6S1P
Turnigy nano-tech 1300mAh 6S1P 25~50C Lipo Pack
$21.73 in the us warehouse....
save $3.47 and get them for $18.26
buddy code:
http://www.hobbyking.com/buddy.asp?c...E-B757560680FB
ptflyer is offline Find More Posts by ptflyer
Old Jan 10, 2013, 08:53 AM
The only R/C pilot in the city
Scorpio9999's Avatar
Kazakhstan, West Kazakhstan Province, Aksay
Joined Sep 2012
My codes - valid until 23 Jan 2013
Turnigy Battery Strap 330mm - $1.21*
http://www.hobbyking.com/buddy.asp?c...B-BAD97115C652
2.5mm F:2.0 Turnigy Micro FPV Camera Lense - $6.17*
http://www.hobbyking.com/buddy.asp?c...6-DF61D9CBF983
2.8mm F:2.0 Turnigy Micro FPV Camera Lense -$4.96*
http://www.hobbyking.com/buddy.asp?c...C-4FB60806C3F5
FPV Fiberglass Pan-Tilt Camera Mount L-Size - $3.03*
http://www.hobbyking.com/buddy.asp?c...0-76FA07E2DF2D
5.6mm x 14mm M3 Nylon Threaded Spacer (10pc) - $1.19*
http://www.hobbyking.com/buddy.asp?c...A-B27D30602037
Scorpio9999 is offline Find More Posts by Scorpio9999
Old Jan 16, 2013, 09:26 PM
Canada, ON, Ottawa
Joined Nov 2012
My buddy codes - valid until January 24th
Here's a bunch of new codes:
NTM Prop Drive 2836-2700:
http://www.hobbyking.com/buddy.asp?c...B-7AE49474D21D
Turnigy 5 Amp SBEC for LiPO:
http://www.hobbyking.com/buddy.asp?c...7-20F001D5CE39
TURNIGY V-Tail Mixer. Ultra-small
http://www.hobbyking.com/buddy.asp?c...7-D6CFD60653F8
Hobbyking LED Servo Tester
http://www.hobbyking.com/buddy.asp?c...C-347FC344F813
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
http://www.hobbyking.com/buddy.asp?c...A-5AF6CD10593A
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr)
http://www.hobbyking.com/buddy.asp?c...C-80784BE81BD6
Polyester Hook & Loop Velcro V-STRONG (1mtr)
http://www.hobbyking.com/buddy.asp?c...0-11A1E553AC1D
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red
http://www.hobbyking.com/buddy.asp?c...8-38D4943E8FDC
Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK
http://www.hobbyking.com/buddy.asp?c...E-1FB3830CF109
Turnigy Pure-Silicone Wire 24AWG (1mtr) Red
http://www.hobbyking.com/buddy.asp?c...A-C1A3F035F6A0
Turnigy Pure-Silicone Wire 24AWG (1mtr) Black
http://www.hobbyking.com/buddy.asp?c...8-F79B6BA32B40
Turnigy Pure-Silicone Wire 24AWG (1mtr) Blue
http://www.hobbyking.com/buddy.asp?c...4-FBFA64609B7A
JR Y Servo Lead 30CM Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...3-7CD882156BE4
Turnigy 6mm Heat Shrink Tube - RED (1mtr)
http://www.hobbyking.com/buddy.asp?c...A-B267C8F99585
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...D-A360D271FC38
Turnigy Heat Shrink Tube 25mm Transparent (1mtr)
http://www.hobbyking.com/buddy.asp?c...9-83B108B8A857
Turnigy 6mm Heat Shrink Tube Blue (1mtr)
http://www.hobbyking.com/buddy.asp?c...7-ACA8597DB35B
Turnigy Heat Shrink Tube 50mm Yellow (1mtr)
http://www.hobbyking.com/buddy.asp?c...0-CE5AF085ADEE
Turnigy High Density R/C LED Flexible Strip-Green (1mtr)
http://www.hobbyking.com/buddy.asp?c...F-BECA7C0AAAB4
Turnigy High Density R/C LED Flexible Strip-Red (1mtr)
http://www.hobbyking.com/buddy.asp?c...0-235C4DCAB1B1
Turnigy High Density R/C LED Flexible Strip-White (1mtr)
http://www.hobbyking.com/buddy.asp?c...1-572191BADD58
IMAX B6-AC Charger/Discharger 1-6 Cells (GENUINE)
http://www.hobbyking.com/buddy.asp?c...B-6CD40E78B77C
Turnigy Servo Signal Reverser
http://www.hobbyking.com/buddy.asp?c...F-B5B3FFBA01A1
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...1-F90D843D6654
CNC Alloy Prop Balancer for Propeller, EDF & Heli Shaft/Blade
http://www.hobbyking.com/buddy.asp?c...C-4BF573020A7B
Turnigy Be Found Lost Model Beeper
http://www.hobbyking.com/buddy.asp?c...6-7F21BD095F50
Hope these are some help to some of you.
BanzaiBill is offline Find More Posts by BanzaiBill
Old Feb 02, 2013, 01:31 AM
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
Turnigy 3000mAh 4S 40C Lipo Pack - $30.86
http://www.hobbyking.com/buddy.asp?c...4-123241C4D87C
Turnigy nano-tech 450mAh 2S 65-130C Lipo Pack (E-flite Blade 130X) - $7.24
http://www.hobbyking.com/buddy.asp?c...4-52BABCFE3CE1
Turnigy nano-tech 300mah 1S 45C Lipo Pack (Suits FBL100 and Blade mCPx) - $2.40
http://www.hobbyking.com/buddy.asp?c...F-4E9A44661B28
Aphro is offline Find More Posts by Aphro
Old Feb 02, 2013, 06:28 AM
BlackBeast's Avatar
Joined Dec 2008
Find my codes here: http://hk.rc-international.info/swarm/blackbeast (valid until February 15, 2013)
De-soldering Braid 2.5mm/1.5m Save US$: 0.31
Solder Wire 1mm/3m Save US$: 0.21
Coated Copper Crimping Tube for Pull/Pull Wire (10pc) Save US$: 0.31
Pull/Pull Coated Steel Wire 0.8mm (5m/Bag) Save US$: 0.88
Pull/Pull Coated Steel Wire 0.9mm (5m/Bag) Save US$: 0.96
CA Applicator Reg (1pc) Save US$: 0.23
Turnigy Pure-Silicone Wire 12AWG (1mtr) BLACK Save US$: 0.99
Old Feb 09, 2013, 03:54 AM
Joined Sep 2010
http://rcsearch.info/hobbyking/buddy...Please#catalog
Metal Fuel Clip 6mm Pipe(5pcs.bag)
http://www.hobbyking.com/hobbyking/s...wishlistresult
Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set
Nylon Spinner 1.5inch
Nylon Clevis M2 L23 (10sets)
Silicon fuel pipe (1 mtr) White for Nitro Engines 4x2.5mm
Super Light Multi Spoke Wheel D30x7mm (5pcs/bag)
Fuel Dot Gas/Glow
Small Wheel Diam: 18mm Width: 10mm (5pcs/bag)
Fuel Filter (Nitro/Glow) D4xd9.5xL25mm
whiskey29 is offline Find More Posts by whiskey29
Old Feb 24, 2013, 07:39 AM
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
Find my codes here: http://hk.rc-international.info/swarm/cold-wombat (valid until March 07, 2013)
FrSky DJT 2.4Ghz Combo Pack for JR w/ Telemetry Module & V8FR-II RX Save US$: 33.96
FrSky V8R4-II 2.4Ghz 4CH Receiver Save US$: 0.82
Insta-Set CA Accelerator 2. oz Save US$: 0.93
Transparent Screws Polycarbonate - 10pcs/bag Save US$: 0.04
Transparent Screws Polycarbonate - 10pcs/bag Save US$: 0.01
USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.77
cold wombat is offline Find More Posts by cold wombat
Old Feb 26, 2013, 08:09 PM
BlackBeast's Avatar
Joined Dec 2008
Find my codes here: http://hk.rc-international.info/swarm/blackbeast (valid until March 12, 2013)
Turnigy Smart Retractable Landing Gear - Gear and Door Sequencer Save US$: 0.10
Turnigy Servo Signal Reverser Save US$: 0.41
1/16 Brushless 4WD Mini Rally - Extreme Edition Locked Diff Save US$: 0.72
Battery Velcro Strap (2pcs/bag) Save US$: 1.30
Old Feb 27, 2013, 07:03 AM
Australia, NSW, Springwood
Joined Dec 2012
X900 tricopter, Multistar, Props, Minim OSD, velcro, etc
Valid for around 10 more days...
Hobbyking X900 Tricopter Glass Fiber Multi-Rotor Frame
http://www.hobbyking.com/buddy.asp?c...A-66DCE26B303B
XT60 to 3 X 3.5mm bullet Multistar ESC Power Breakout Cable
http://www.hobbyking.com/buddy.asp?c...E-DA74E600FAF6
3.5mm Male/Female Bullet Brushless Motor Extension Lead 200mm
http://www.hobbyking.com/buddy.asp?c...9-2970EAF5B19E
Turnigy Multistar 20 Amp Multi-rotor Brushless ESC 2-4S (OPTO)
http://www.hobbyking.com/buddy.asp?c...2-EFC3E64E9C05
Turnigy Multistar ESC Programming Card
http://www.hobbyking.com/buddy.asp?c...9-8C7C7AEF90C8
Slow Fly Electric Prop 9047R SF (4 pc Right Hand Rotation)
http://www.hobbyking.com/buddy.asp?c...D-22598D5069A0
Slow Fly Electric Prop 9047SF (4 pc)
http://www.hobbyking.com/buddy.asp?c...3-A89EDA534281
http://www.hobbyking.com/buddy.asp?c...8-4275086D4E7B
Minim OSD v1.1
http://www.hobbyking.com/buddy.asp?c...2-10E855AFDD3A
http://www.hobbyking.com/buddy.asp?c...0-B1059CD5C2C6
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Black)
http://www.hobbyking.com/buddy.asp?c...B-E19884A9BADF
Hobbyking Lipo to USB Charging Adapter
http://www.hobbyking.com/buddy.asp?c...A-1DA399CA656F
ZaksterBlue is offline Find More Posts by ZaksterBlue
Old Feb 28, 2013, 07:10 PM
Aphro's Avatar
Joined Jan 2012
Mr Grippy Soldering Jig - $6.69
http://www.hobbyking.com/buddy.asp?c...F-641B4C83AC3B
Turnigy dlux Auto Checker 1~6S LiPo Battery Checker and Balancer - $10.65
http://www.hobbyking.com/buddy.asp?c...F-C2DEA59EA74E
http://www.hobbyking.com/buddy.asp?c...C-AF791C9D7584
http://www.hobbyking.com/buddy.asp?c...D-7850C6629CDF
Alert HobbyKing BuddyPrice Codes for more products, use as you wish obuggy HobbyKing 4931 Yesterday 09:38 PM
Yippee! Hobbyking working Buddy Codes inside from my hexacopter orders bikertje888 Multirotor Talk 4 Aug 15, 2011 12:05 PM
Alert HobbyKing discount buddy codes New codes 6/2011 HydroPilot Hot Online Deals 0 Jun 30, 2011 11:49 PM
Alert HobbyKing BuddyPrice Codes for Propellers and Motors Mayer74 Hot Online Deals 0 May 19, 2011 04:11 AM
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 5 May 18, 2011 01:38 PM
