Old Oct 28, 2012, 10:37 PM
donandtheresa is online now
Find More Posts by donandtheresa
United States, AZ, Peoria
Joined Mar 2012
6s buddy code
heres a buddy code from hobbyking for 6s batteries if anyone wants to use it.
http://www.hobbyking.com/buddy.asp?c...B-4D70401F4BA3
also buddy code for 700 tail blades
http://www.hobbyking.com/buddy.asp?c...D-1414F263026E
donandtheresa is online now Find More Posts by donandtheresa
Old Nov 08, 2012, 06:32 PM
BlackBeast is offline
Find More Posts by BlackBeast
BlackBeast's Avatar
Canada, QC, Témiscouata-sur-le-Lac
Joined Dec 2008
Find my codes here: http://hk.rc-international.info/swarm/blackbeast (valid until November 14, 2012)
Mini EDF Fighter Jet EPO Plug-n-Fly Save US$: 1.58
10pc Screw Set (2.6*8) - 110BS, A2029 and A2035 Save US$: 0.11
Carbon Fiber Square Tube 750x3mm Save US$: 0.84
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
BlackBeast is offline Find More Posts by BlackBeast
Old Nov 15, 2012, 05:41 AM
Chriscool is offline
Find More Posts by Chriscool
Chriscool's Avatar
Suisse, VS, Vouvry
Joined Apr 2009
Hello... find my codes here: http://hk.rc-international.info/swarm/chriscool (valid until November 29, 2012)
Atmel Atmega Socket Firmware Flashing Tool Save US$: 1.21
NTM Prop Drive Series 28-26A 1200kv / 250w Save US$: 1.61
Turnigy AAA LSD 900mah Low Self Discharge (ready to use) Save US$: 0.30
Servo Splitter Lead 1 Female to 5 male Save US$: 0.11
Turnigy Heat Shrink Tube 25mm Transparent (1mtr) Save US$: 0.18
Turnigy Heat Shrink Tube 20mm Transparent (1mtr) Save US$: 0.16
Chriscool is offline Find More Posts by Chriscool
Old Nov 16, 2012, 10:34 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
Turnigy nano-tech 300mah 2S 35~70C Lipo Pack (E-flite EFLB2002S25 micro series compatible)
http://www.hobbyking.com/buddy.asp?c...0-17AFD003022D
Turnigy nano-tech 260mah 2S 35~70C Lipo Pack (E-flite EFLB2002S25 micro series compatible)
http://www.hobbyking.com/buddy.asp?c...8-FBBDFBAC90A1
Turnigy nano-tech 600mah 1S 35~70C Lipo Pack (Fits Nine Eagles Solo Pro 328, Eflite MQX, 120SR)
http://www.hobbyking.com/buddy.asp?c...9-0EDEAD9C06A5
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (Kyosho, E-flite, Parkzone Etc)
http://www.hobbyking.com/buddy.asp?c...1-E699E6783BF7
OrangeRx R710 Spektrum DSM2 Compatible 7Ch w/Failsafe
http://www.hobbyking.com/buddy.asp?c...1-CD2FDC10E914
Aphro is offline Find More Posts by Aphro
Old Nov 27, 2012, 06:53 PM
BlackBeast's Avatar
Joined Dec 2008
Find my codes here: http://hk.rc-international.info/swarm/blackbeast (valid until December 11, 2012)
Pushrod Snap Connectors 2mm (5pack) Save US$: 0.79
Turnigy Pure-Silicone Wire 12AWG (1mtr) RED Save US$: 0.99
Turnigy Servo Signal Reverser Save US$: 0.41
Battery Velcro Strap (2pcs/bag) Save US$: 1.30
HXT900 Replacement Gear Set Save US$: 0.41
Old Nov 29, 2012, 10:09 PM
Percivale is offline
Find More Posts by Percivale
To Have & To Hold
Percivale's Avatar
Joined May 2010
Turnigy Servo Tester, LED leads and LED Neon Systems
http://www.hobbyking.com/buddy.asp?c...A-E6BE5B652890
JST-XH to JST LED Power Distribution Lead (6 JST)
http://www.hobbyking.com/buddy.asp?c...D-8712AE67AA6B
LED Flexible Under Body Neon System (Red)
http://www.hobbyking.com/buddy.asp?c...2-435EE6D4A1D4
LED Flexible Under Body Neon System (Green)
http://www.hobbyking.com/buddy.asp?c...8-91B95D293F0F
LED Flexible Under Body Neon System (Blue)
http://www.hobbyking.com/buddy.asp?c...F-A6473ADE4FB1
LED Flexible Under Body Neon System (White)
http://www.hobbyking.com/buddy.asp?c...D-8FB15CD0AF40
Starting from: 30.11.2012
Percivale is offline Find More Posts by Percivale
Old Nov 30, 2012, 05:03 PM
wessone is offline
Find More Posts by wessone
Canada, QC, Montreal
Joined May 2012
hi guys
got some buddy codes to share with yall!
enjoy!
Turnigy Servo Signal Reverser:
http://www.hobbyking.com/buddy.asp?c...8-218317EEB68D
FPV Fiberglass Pan-Tilt Camera Mount:
http://www.hobbyking.com/buddy.asp?c...C-85D7E36B15C7
2.8mm F:2.0 Turnigy Micro FPV Camera Lense:
http://www.hobbyking.com/buddy.asp?c...3-EDCD9F4A9681
and some older ones but still working for a couple days:
JST Female 2 pin connector set (10pcs/set):
http://www.hobbyking.com/buddy.asp?c...7-9068AE87E38E
Turnigy Pure-Silicone Wire 20AWG (1mtr) RED:
http://www.hobbyking.com/buddy.asp?c...D-85653BB3A7FF
Turnigy Pure-Silicone Wire 20AWG (1mtr) Black:
http://www.hobbyking.com/buddy.asp?c...3-079E7A0F1C19
SF E-Prop 9x6 / 229x152.5mm w/ Adapters Black:
http://www.hobbyking.com/buddy.asp?c...2-7EDB0D08AAB4
GWS EP Propeller (DD-5030 127x76mm) (6pcs/set):
http://www.hobbyking.com/buddy.asp?c...2-A56F9F03A9C4
JST-XH to JST LED Power Distribution Lead (6pcs/set):
http://www.hobbyking.com/buddy.asp?c...F-986CC8C02413
Turnigy High Density R/C LED Flexible Strip-Green (1mtr):
http://www.hobbyking.com/buddy.asp?c...5-8E42462FA33F
Turnigy High Density R/C LED Flexible Strip-Red (1mtr):
http://www.hobbyking.com/buddy.asp?c...8-FF907BE5FBA3
Turnigy High Density R/C LED Flexible Strip-White (1mtr):
http://www.hobbyking.com/buddy.asp?c...4-92E6C86525A0
wessone is offline Find More Posts by wessone
Old Nov 30, 2012, 06:04 PM
Teokharis is offline
Find More Posts by Teokharis
Teokharis's Avatar
Italia, Campania, Napoli
Joined Nov 2011
A couple of small things
Find my codes here: http://hk.rc-international.info/swarm/uzzi (valid until December 15, 2012)
Hobbyking Multi-Rotor Power Distribution Board (DIY 8 x output PCB) Save US$: 0.86
Balance Plug Savers (JST-XH 5s) (5pc Per Bag) Save US$: 0.86
Teokharis is offline Find More Posts by Teokharis
Old Dec 03, 2012, 04:19 PM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
Hi Guys,
I received a couple buddy codes for savings on selected items I purchased
If you are placing an order soon you can save some money if you can use the items
They only last for a few days so you will need to act soon
Here are the codes for them
You have to be logged into your account when ordering
Blessings, Terry
http://www.hobbyking.com/buddy.asp?c...7-0837DF66E3F1
http://www.hobbyking.com/buddy.asp?c...3-16C13721C203
still4given is offline Find More Posts by still4given
Old Dec 04, 2012, 10:11 AM
Joined Mar 2012
multirotor buddy codes
Just bought a bunch of stuff to build a multirotor here are the buddy codes I got:
Turnigy 2200mAh 3S 20C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...A-65F2652AC219
Turnigy Talon Tricopter (V1.0) - Camera Plat
http://www.hobbyking.com/buddy.asp?c...C-09C789C658DD
3cm Male to Male Servo Lead 26AWG (10pcs/set
http://www.hobbyking.com/buddy.asp?c...8-4F86176BE025
Turnigy Talon Tricopter (V1.0) - Screw Sets
http://www.hobbyking.com/buddy.asp?c...E-7DA5A4883161
TGY-306G Ultra Fast/High Torque MG Digital A
http://www.hobbyking.com/buddy.asp?c...0-D96916130D54
http://www.hobbyking.com/buddy.asp?c...A-5E0714C31A1F
NTM Prop Drive 2826 Series Replacement Shaft
http://www.hobbyking.com/buddy.asp?c...9-4FC26BB8EDE1
Old Dec 04, 2012, 01:23 PM
hot wings is offline
Find More Posts by hot wings
hot wings's Avatar
Joined Jul 2010
1/16 Brushless 4WD Racing Buggy spare parts
Plenty of Turnigy 1/16 4WD Buggy spare parts:
http://www.hobbyking.com/hobbyking/f....asp?TID=36359
hot wings is offline Find More Posts by hot wings
Old Dec 04, 2012, 02:42 PM
dudy201 is offline
Find More Posts by dudy201
Joined Aug 2011
Pivot & Round Hinges 2.5x48 (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...DC4-4929-86D5-
Pivot & Round Hinges 4.5x67mm (10pcs)
http://www.hobbyking.com/buddy.asp?c...8-8E304F8BE1F4
FTL-52 spark plug (part # 006)
http://www.hobbyking.com/buddy.asp?c...0-0C126F72EC86
Pull/Pull Coated Steel Wire 0.9mm (5m/Bag)
http://www.hobbyking.com/buddy.asp?c...1-9EB23864C628
Coated Copper Crimping Tube for Pull/Pull Wire (10pc)
http://www.hobbyking.com/buddy.asp?c...C-1910FBC907A6
Twisted 15CM Servo Lead Extention (JR) 22AWG (5pcs/set)
http://www.hobbyking.com/buddy.asp?c...2-D005D6D770C7
Large Bore/Capacity Gas Filters (Red) (2pcs/bag)
http://www.hobbyking.com/buddy.asp?c...1-8BEEF113683C
dudy201 is offline Find More Posts by dudy201
Old Dec 05, 2012, 03:03 AM
54643 is offline
Find More Posts by 54643
Joined Dec 2009
Hobbyking Buddy Code (Expires on 19 DEC 2012)
All my buddy-codes on RCSearch.info
Battery Powered Hot Glue Gun
$2.30*
Turnigy 2213 20turn 1050kv 19A Outrunner
$12.28* (buddy price -13%, -$1.82)
Hobbyking Parallel charging Board for 6 packs 2~6S (XT-60)
$5.38* (buddy price -40%, -$3.61)
Pin Horn 9x13 (10pcs)
$0.48* (buddy price -52%, -$0.51)
Super Light 5 Spoke Wheel D36xH8 (5pcs/bag)
$1.15*
TURNIGY Plush 12amp (2A BEC) BESC
$8.00* (buddy price -20%, -$2.01)
HXT500 5g / .8kg / .10sec Micro Servo
$3.05* (buddy price -13%, -$0.44)
Hobbyking 8 Point snap knife (5pcs/set)
$0.57* (buddy price -28%, -$0.22)
54643 is offline Find More Posts by 54643
Old Dec 06, 2012, 05:03 AM
yagus is offline
Find More Posts by yagus
yagus's Avatar
Indonesia, Jogja, Yogyakarta
Joined May 2008
need a lipos
need a cheap lipos
Original Price 4.66 and you will only pay 4.03
http://www.hobbyking.com/buddy.asp?c...9-B6C595A225F7
http://www.hobbyking.com/buddy.asp?c...7-E90DB67C44BA
pay only $0.48
http://www.hobbyking.com/buddy.asp?c...6-1EC0754EB8FE
pay only $0.54
yagus is offline Find More Posts by yagus
Alert HobbyKing BuddyPrice Codes for more products, use as you wish obuggy HobbyKing 7941 Jun 25, 2016 01:06 AM
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Yippee! Hobbyking working Buddy Codes inside from my hexacopter orders bikertje888 Multirotor Talk 4 Aug 15, 2011 12:05 PM
Alert HobbyKing discount buddy codes New codes 6/2011 MiG-3 Reno Rocket Hot Online Deals 0 Jun 30, 2011 11:49 PM
Alert HobbyKing BuddyPrice Codes for Propellers and Motors Mayer74 Hot Online Deals 0 May 19, 2011 04:11 AM
