Old Sep 23, 2012, 08:47 AM
cold wombat is offline
Find More Posts by cold wombat
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
Find my codes here: http://hk.rc-international.info/swarm/cold-wombat (valid until October 07, 2012)
Turnigy AE-30A Brushless ESC Save US$: 1.67
Turnigy Servo Signal Reverser Save US$: 0.41
USB Simulator Lead for Turnigy GTX3 Transmitter - VRC Sim Compatible Save US$: 2.49
Blind Nut M2 size (10pcs) Save US$: 0.30
Self Tapping Screws PT1.75x4 (10pcs/set) Save US$: 1.12
Blind Nut M3 (10pcs) Save US$: 0.15
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc) Save US$: 0.89
cold wombat is offline Find More Posts by cold wombat
Old Sep 23, 2012, 09:06 AM
Joined Jul 2011
Plenty of CF discounts...
Carbon Fiber Sheet 0.3mm*300mm*150mm Save US$: 1.27
Carbon Fiber Rod (solid) 2.0x750mm Save US$: 0.73
Carbon Fiber Rod (solid) 1.5x750mm Save US$: 0.74
Carbon Fiber Tube (hollow) 3x2x750mm Save US$: 0.73
Carbon Strip 1x6x750mm (5pcs/set) Save US$: 2.14
Carbon Fiber Rod (solid) 1x750mm Save US$: 0.75
Carbon Fiber Rod (solid) 1.8x750mm Save US$: 0.73
Carbon Fiber Sheet 1.0mm*300mm*150mm Save US$: 1.90
Old Sep 23, 2012, 01:24 PM
superchuchi is offline
Find More Posts by superchuchi
superchuchi's Avatar
Madrid, Spain
Fatshark FPV - MyOptic Lens Set (For Eyeglass wearers)
USD12.34
http://www.hobbyking.com/buddy.asp?c...8-284EE2EA9622
superchuchi is offline Find More Posts by superchuchi
Old Sep 24, 2012, 03:58 PM
frviana is offline
Find More Posts by frviana
Joined Aug 2012
ALTITUDE-v4 Altitude MicroSensor - Eagletree
http://www.hobbyking.com/buddy.asp?c...8-497AFAEC5B38
frviana is offline Find More Posts by frviana
Old Sep 28, 2012, 09:59 PM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
7 chnl Orange DSM2 Receiver
http://www.hobbyking.com/buddy.asp?c...4-4CBDD9504613
50 Amp Boat esc
http://www.hobbyking.com/buddy.asp?c...A-52A43F6CE1A0
3.5 mm connectors 10 pairs
http://www.hobbyking.com/buddy.asp?c...B-0D2E05424F38
nick_75au is offline Find More Posts by nick_75au
Old Sep 29, 2012, 02:52 AM
Scorpio9999 is offline
Find More Posts by Scorpio9999
The only R/C pilot in the city
Scorpio9999's Avatar
Kazakhstan, West Kazakhstan Province, Aksay
Joined Sep 2012
Valid till 13 Oct 2012
Carbon Fiber Tube (hollow) 6x750mm for $1.33
http://www.hobbyking.com/buddy.asp?c...3-F595CA68B4C8
Carbon Fiber Rod (solid) 2.0x750mm for $0.42
http://www.hobbyking.com/buddy.asp?c...A-0FE04A8E0EA3
Carbon Fiber Tube (hollow) 8x750mm for $1.91
http://www.hobbyking.com/buddy.asp?c...2-F4F3056B64B5
TURNIGY Plush 60amp Speed Controller for $27.41
http://www.hobbyking.com/buddy.asp?c...D-C29460690688
Turnigy 9X 2.4GHz 8Ch Receiver (V2) for $8.23
http://www.hobbyking.com/buddy.asp?c...2-8616B5E54BC3
Nylon & Pinned Hinge 16x28.5 (10pcs) for $0.85
http://www.hobbyking.com/buddy.asp?c...4-A79FB997740C
Nylon & Pinned Hinge 26.5x36 (10pcs/bag) for $1.21
http://www.hobbyking.com/buddy.asp?c...B-6D412289256F
Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack for $15.04
http://www.hobbyking.com/buddy.asp?c...1-21870127346F
ZIPPY Compact 3300mAh 3S 35C Lipo Pack for $20.18
http://www.hobbyking.com/buddy.asp?c...C-7EE420559F65
Scorpio9999 is offline Find More Posts by Scorpio9999
Old Sep 30, 2012, 01:22 PM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
Find my codes here: http://hk.rc-international.info/swarm/caall99 (valid until October 08, 2012)
15CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag) Save US$: 0.59
30CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag) Save US$: 0.69
45CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag) Save US$: 0.78
Turnigy 130A Watt Meter and Power Analyzer Save US$: 3.82
TGS Sport 9x6E Precision propeller Save US$: 1.35
NTM Prop Drive 35-48 Series 900KV / 815W Save US$: 3.98
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
caall99 is offline Find More Posts by caall99
Old Oct 16, 2012, 03:16 PM
snipeworm is offline
Find More Posts by snipeworm
Snipe the Skies!
snipeworm's Avatar
United States, CA, Roseville
Joined Feb 2012
Find my codes here: http://hk.rc-international.info/swarm/snipeworm (valid until October 13, 2012)
JST-XH 2S Wire Extension 20cm (10pcs/bag) Save US$: 0.41
JST-XH 4S Wire Extension 20cm (10pcs/bag) Save US$: 0.53
TURNIGY Transmitter Strap Save US$: 0.26
Slow Fly Electric Prop 11x4.7SF (4 pc - Green) Save US$: 0.56
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.20
GWS HD9050 3 Blade Prop Counter Rotate (2pc) Save US$: 0.29
Turnigy Multistar ESC Programming Card Save US$: 1.62
Lipoly Charge Bag 14 x 23 cm Save US$: 1.35
Propeller Adapter (Colet Type) 4MM Save US$: 0.44
5.6mm x 14mm M3 Nylon Threaded Spacer (10pc) Save US$: 0.67
M3 Nylon Nut (10pcs/bag) Save US$: 0.17
M3x12mm Nylon Screws (10pcs/bag) Save US$: 0.23
Turnigy Battery Strap 330mm Save US$: 0.37
5.6mm x 15mm M3 Nylon Tapped Spacer (10pc) Save US$: 0.78
LED Strip with JST Connector 200mm (White) Save US$: 0.97
Linkage Stopper M3x2xL11.2mm (10pcs/set) Save US$: 0.55
Nylon Clevis 2x29mm (10pcs) Save US$: 0.16
snipeworm is offline Find More Posts by snipeworm
Old Oct 17, 2012, 10:31 PM
AlphaBravo is offline
Find More Posts by AlphaBravo
Joined Apr 2012
HobbyKing Buddy Codes Prices
This Buddy Codes will expire on 31 October 2012
1) Turnigy High Density R/C LED Flexible Stripe GREEN
http://www.hobbyking.com/buddy.asp?c...8-2CBD6A80C0E8
2) Prop adapter w/ Steel Nut 3mm shaft (Grub screw)
http://www.hobbyking.com/buddy.asp?c...5-D5FA96957051
3) FPV Fiberglass Pan-Tilt Camera Mount L-Size
http://www.hobbyking.com/buddy.asp?c...5-BA429DA00F1D
4) Slow Fly Electric Prop 8045R SF (4 pc)
http://www.hobbyking.com/buddy.asp?c...8-B62DFEEDD380
5) Slow Fly Electric Prop 8045SF (4 pc)
http://www.hobbyking.com/buddy.asp?c...5-287599C212D7
6) 2.8mm F:2.0 Turnigy Micro FPV Camera Lense
http://www.hobbyking.com/buddy.asp?c...5-CABC3138783B
7) GT600-140 - HK600GT landing skid pipe (H60137)
http://www.hobbyking.com/buddy.asp?c...6-420A167A65BF
8) GT600-139 - HK600GT landing skid (H60039)
http://www.hobbyking.com/buddy.asp?c...E-FE6549F6B77C
9) Turnigy High Density R/C LED Flexible Stripe WHITE
http://www.hobbyking.com/buddy.asp?c...4-E7D8A70DB65E
AlphaBravo is offline Find More Posts by AlphaBravo
Old Oct 18, 2012, 02:28 AM
tazmana is offline
Find More Posts by tazmana
Joined May 2012
1) RX-9X8Cv2 Turnigy 9X 2.4GHz 8Ch Receiver (V2) http://www.hobbyking.com/buddy.asp?c...2-F8FBEA686DFA
2)Turnigy-3S Turnigy balancer & Charger 2S-3S http://www.hobbyking.com/buddy.asp?c...1-C28A08D44AD2
3)ZC.1500.3S.25 ZIPPY Compact 1500mAh 3S 25C Lipo Pack http://www.hobbyking.com/buddy.asp?c...9-30CC7CC83EDD
4)OR001-00309D SF E-Prop 9x7.5 / 229x190.5mm w/ Adapters Bl
http://www.hobbyking.com/buddy.asp?c...E-978A34B7C400
tazmana is offline Find More Posts by tazmana
Old Oct 20, 2012, 08:03 AM
Joker 53150 is offline
Find More Posts by Joker 53150
Joker 53150's Avatar
United States, WI, Muskego
Joined Sep 2012
4x2.5 Props
$1.15 US
http://www.hobbyking.com/buddy.asp?c...B-F76B32CE1523
5x3 Props
$1.33 US
http://www.hobbyking.com/buddy.asp?c...2-0FF3047CC94E
C10 Micro Brushless Outrunner 2900kv
$10.04 US
http://www.hobbyking.com/buddy.asp?c...3-2DF4EA2E196C
114x102 Props
$2.72 US
http://www.hobbyking.com/buddy.asp?c...5-961A7FECE185
102x102 Props
$2.27 US
http://www.hobbyking.com/buddy.asp?c...6-D8C7B69AB721
Turnigy Plush 10A 9g ESC
$6.70 US
http://www.hobbyking.com/buddy.asp?c...4-91BB9555E43D
PolyMax 3.5mm Gold Connectors 10 Pairs
$1.96 US
http://www.hobbyking.com/buddy.asp?c...F-16B0BD94557E
3mm pro
p saver with 3 bands
$0.44 US
http://www.hobbyking.com/buddy.asp?c...7-FE245BD46073
75mm x 20mm foam wheel
$0.61
http://www.hobbyking.com/buddy.asp?c...A-F960F847B653
X-blade, 10 pieces
US $0.36
http://www.hobbyking.com/buddy.asp?c...4-3BCEDB901662
Joker 53150 is offline Find More Posts by Joker 53150
Old Oct 24, 2012, 07:06 AM
Chriscool is offline
Find More Posts by Chriscool
Chriscool's Avatar
Suisse, VS, Vouvry
Joined Apr 2009
Hello... some items to build a quad
Find my codes here: http://hk.rc-international.info/swarm/chriscool (valid until November 07, 2012)
Turnigy Talon Alloy Motor Mount Block (2pcs/bag) Save US$: 0.36
Turnigy Talon Carbon Fiber Boom 498mm (1pc/bag) Save US$: 0.74
Turnigy H.A.L. Motor Mount Set(1set) Save US$: 1.60
NTM Prop Drive Series 28-26A 1200kv / 250w Save US$: 1.72
NTM Prop Drive 2826 Series Replacement Shaft Save US$: 0.41
Turnigy Gilder Carrying Backpack - 890x180x70mm Save US$: 4.00
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.19
Hex locknuts M3 10pc Save US$: 0.45
Tie-D-Wires Cable and Wire Holders (10pc) Save US$: 0.24
Hex locknuts M4 10pc Save US$: 0.50
Chriscool is offline Find More Posts by Chriscool
Old Oct 26, 2012, 03:01 PM
Deaol is offline
Find More Posts by Deaol
I Break Foam
Deaol's Avatar
North Island, BC
Joined Feb 2008
Find my codes here: http://hk.rc-international.info/swarm/deaol (valid until November 02, 2012)
Turnigy 1500mAh 3S 20C Lipo Pack Save US$: 0.55
APC style propeller 9x6-E Save US$: 0.39
Super Light Multi Spoke Wheel D40x11mm (5pcs/bag) Save US$: 0.38
GWS EP Propeller (RD-1047 254x119mm) (6pcs/set) Save US$: 1.04
HK15178 Analog Servo 10g / 1.4kg / 0.09s Save US$: 0.08
Nylon T-Connectors 10 Pairs (20pc) Save US$: 0.19
Cheers
Deaol is offline Find More Posts by Deaol
Old Oct 28, 2012, 09:38 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Here is a buddy code for the Turnigy Tx battery that fits the Spektrum DX8 and DX7s:
http://www.hobbyking.com/buddy.asp?c...F-470302581223
You will be able to buy the battery for only $15.
Code is valid until 11 Nov 2012.
Kmot is online now Find More Posts by Kmot
Alert HobbyKing BuddyPrice Codes for more products, use as you wish obuggy HobbyKing 7950 Today 10:02 AM
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Yippee! Hobbyking working Buddy Codes inside from my hexacopter orders bikertje888 Multirotor Talk 4 Aug 15, 2011 12:05 PM
Alert HobbyKing discount buddy codes New codes 6/2011 MiG-3 Reno Rocket Hot Online Deals 0 Jun 30, 2011 11:49 PM
Alert HobbyKing BuddyPrice Codes for Propellers and Motors Mayer74 Hot Online Deals 0 May 19, 2011 04:11 AM
