Old Aug 20, 2012, 10:55 PM
Newcastle. Australia
Joined Jan 2004
Magnetic screws/parts Tray Save US$: 0.57
Turnigy 1.5mm Hex Screwdriver Save US$: 0.37
Solder Wire 1mm/3m Save US$: 0.21
Turnigy Piston Stopper Save US$: 0.46
Scale National Air Force Insignia Decal Sheet - Australia Save US$: 1.99
Futaba Servo Arm Set Save US$: 1.26
PC55 is offline Find More Posts by PC55
Old Aug 22, 2012, 09:29 PM
Too many numbers
United States, OH, Troy
Joined Oct 2010
Anyone need a 30cc motor. This one is a clone of the DLE model.
RCG 30cc Gas engine w/ CD-Ignition 3.9HP/2.94kw (USA Warehouse)
$179.34!
Need something to put it in? Just got this- brand new to HK.
Sbach 342 Gas 30cc 1850mm USA Warehouse
$249.59
Enjoy!
c131frdave is offline Find More Posts by c131frdave
Old Aug 24, 2012, 12:49 AM
Merry Christmas... :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
5.8GHz Circular Polarized (Clover Leaf) spiroNet Antenna
Valid from today.
http://www.hobbyking.com/buddy.asp?c...7-A46EF0B54742
KCV6 is offline Find More Posts by KCV6
Old Aug 25, 2012, 10:21 AM
hot wings's Avatar
Joined Jul 2010
HK450 V2 parts till 10th Sept
Here some parts for heli HK450v2.
Simply click on the link for the buddy codes.
HK450V2 Tail Boom
http://www.hobbyking.com/buddy.asp?c...0-603FC292C3D2
HK450V2 Linkage Rod Set
http://www.hobbyking.com/buddy.asp?c...0-78E38C83C3AE
HK450V2 Main Gear Assemblyhttp://www.hobbyking.com/buddy.asp?code=91C3336D-299B-42E1-A9ED-1D5AFB6910F7
HK-450 Metal Tail Rotor Shaft upgrade versio
http://www.hobbyking.com/buddy.asp?c...C-7AB507C26F8F
HK450V2 Feathering Shaft Set (41x4mmxM2)
http://www.hobbyking.com/buddy.asp?c...F-9A893AD8993C
HK450V2 Main Shaft Cover
http://www.hobbyking.com/buddy.asp?c...9-86DCDE2EB990
hot wings is offline Find More Posts by hot wings
Old Aug 25, 2012, 12:33 PM
who put that tree there
dazza44's Avatar
Joined Jun 2010
uk warehouse code for
h/k micro stuka
http://www.hobbyking.com/buddy.asp?c...E-CC9A1588BA5A
dazza44 is offline Find More Posts by dazza44
Old Aug 26, 2012, 01:54 PM
Joined Aug 2012
Buddy Codes
Find my codes here: http://hk.rc-international.info/swarm/twentythree (valid until September 09, 2012)
Slow Fly Electric Prop 1045SF (4 pc) Save US$: 0.21
Slow Fly Electric Prop 1045R SF RH Rotation (4 pc) Save US$: 0.20
ZIPPY Flightmax 5000mAh 3S1P 20C Save US$: 4.13
NTM Prop Drive Series 28-26A 1200kv / 250w Save US$: 2.79
TURNIGY Plush 30amp Speed Controller Save US$: 0.75
In-Line Voltage and Amperage Meter Save US$: 0.58
twentythree is offline Find More Posts by twentythree
Old Aug 26, 2012, 09:16 PM
Joined Aug 2011
Turnigy 160mAh 1S 30C (Eflite, Minium compatible)
$.91 with discount from $1.69 started 23 Aug
http://www.hobbyking.com/buddy.asp?c...A-553CCE5846E9
EDF50 with ADH300L 5800kv Motor Assembled
$16.46 after $2.58 discount
http://www.hobbyking.com/buddy.asp?c...D-0054165C23F4
skyaut2 is offline Find More Posts by skyaut2
Old Aug 27, 2012, 11:21 AM
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
T1601S-30 Turnigy 160mAh 1S 30C (Eflite, Minium compat )
Use this buddy code to get this battery!
http://www.hobbyking.com/buddy.asp?c...F-65344325037A
Use the code when adding the item to your cart they will pay only $0.91
jrtubb is offline Find More Posts by jrtubb
Old Aug 27, 2012, 02:38 PM
RC Plane Flyer
IndiaHobby's Avatar
United States, MD, Laurel
Joined Mar 2010
Folding Prop Now In Stock !
6 x 4 Folding Prop for Gliders for $1.56
IndiaHobby is offline Find More Posts by IndiaHobby
Old Aug 27, 2012, 06:03 PM
BlackBeast's Avatar
Canada, QC, Témiscouata-sur-le-Lac
Joined Dec 2008
Find my codes here: http://hk.rc-international.info/swarm/blackbeast (valid until September 09, 2012)
10pc Screw Set (2.6*6) - 110BS Save US$: 0.08
Front Steering arm (left/right) - 110BS, A2029 and A2035 Save US$: 0.18
Front Upper Suspension arms (left/right) - 110BS, A2029 and A2035 Save US$: 0.18
Rear Bearing Holder (left/right) - 110BS, A2029 and A2035 Save US$: 0.18
Rear Lower Sus.arm (left/right) - 110BS Save US$: 0.34
Front Lower Sus.arm (left/right) - 110BS Save US$: 0.34
Spur Gear - 110BS, A2029 and A2035 Save US$: 0.34
Front Wheeldrive -110BS, A2029 and A2035 Save US$: 0.59
1/16 Brushless 4WD Monster Beatle Shell - 110BS Save US$: 2.45
Main Shaft For Pinion Gear - 110BS Save US$: 0.38
Turnigy EasyMatch G32 Series - Replacement Shaft Save US$: 0.26
Front Linkage Rod/Ball End - 110BS Save US$: 0.18
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.19
Body Clip D (10pc) - 110BS, A2029 and A2035 Save US$: 0.24
X-BLADE Spare SK-5 Steel blades (10pcs/set) Save US$: 0.63
Rear Ball End and Tie Rod - 110BS, A2003 and A2029 Save US$: 0.24
10pc E-clip (3*0.4) - 110BS, A2023T, A2029 and A2035 Save US$: 0.14
Rear Diff.Box Complete - 110BS, A2003T, A2029 and A2035 Save US$: 3.54
Ex-Long CA Ex-Tips (1pc) Save US$: 0.09
Wheel Hub - 110BS, A2023T, A2029 and A2035 Save US$: 0.11
10pc E-clip (2.3*0.4) 110BS, A2016T, A2029 and A2035 Save US$: 0.14
Turnigy 1450mAh 3S 11.1v Transmitter Lipoly Pack Save US$: 2.80
JR and Spektrum Satellite Receiver Extension Wire 60 and 90cm (2pcs/set) Save US$: 1.25
Plastic Chassis - 110BS and A2003T Save US$: 0.75
Wheels (2pc) - 110BS Save US$: 0.55
USB Simulator Cable RealFlight G4.5 Save US$: 0.88
Simple Prop Balancer Save US$: 0.50
JR and Spektrum Trainer Cable (Buddy box Cable) 2.1m Save US$: 0.57
TURNIGY BESC Programming Card Save US$: 2.76
BlackBeast is offline Find More Posts by BlackBeast
Old Aug 27, 2012, 11:39 PM
KCV6's Avatar
Joined Aug 2009
Turnigy wood 14x4.5 SF props CW and CCW (valid Sep 11)
14x4.5 wood CCW (SF)
http://www.hobbyking.com/buddy.asp?c...2-586EE3A11B29
14x4.5 wood CW (SF)
http://www.hobbyking.com/buddy.asp?c...D-D6FA58ABE93A
Alert HobbyKing BuddyPrice Codes for more products, use as you wish obuggy HobbyKing 5110 Today 04:41 AM
Yippee! Hobbyking working Buddy Codes inside from my hexacopter orders bikertje888 Multirotor Talk 4 Aug 15, 2011 12:05 PM
Alert HobbyKing discount buddy codes New codes 6/2011 HydroPilot Hot Online Deals 0 Jun 30, 2011 11:49 PM
Alert HobbyKing BuddyPrice Codes for Propellers and Motors Mayer74 Hot Online Deals 0 May 19, 2011 04:11 AM
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 5 May 18, 2011 01:38 PM
