Old Jul 23, 2011, 09:20 AM
raRaRa is offline
Find More Posts by raRaRa
Joined Nov 2010
HobbyKing BuddyPrice codes
Hi everyone!
I just bought the following items from HobbyKing and I have BuddyCode available for anyone who wants it:
Hobbyking Bixler EPO 1400mm - (ARF) - $49.01 with my BuddyCode
http://www.hobbyking.com/buddy.asp?c...1-2E8EFBC91C46
TURNIGY Plush 30amp Speed Controller - $11.35 with my BuddyCode
http://www.hobbyking.com/buddy.asp?c...4-C2F40EF11746
Turnigy 9X 2.4GHz 8Ch Receiver (V2) - $8.23 with my BuddyCode
http://www.hobbyking.com/buddy.asp?c...3-035676AC127C
Strong Rare-Earth Button Magnets (10pcs/set) - $1.89 with my BuddyCode
http://www.hobbyking.com/buddy.asp?c...D-17CEE3A0432C
I know the price difference is not much on the cheap items, but nevertheless.. some people like to save any dime they can.
Thanks!
raRaRa is offline Find More Posts by raRaRa
Old Jul 23, 2011, 12:57 PM
Ghost Plane is offline
Find More Posts by Ghost Plane
United States, NY, Angola
Joined Jul 2010
Hey I have some of them too. Hope you don't mind me posting them here with yours.
Turnigy G32 Brushless Outrunner 770kv
Regular = $25.99
With Buddy code = $19.61
http://www.hobbyking.com/buddy.asp?c...A-F843BF6C25A4
Hobby King 60A ESC 4A UBEC
Regular = $16.76
With Buddy code = $16.10
http://www.hobbyking.com/buddy.asp?c...C-B7BC0C3E7D38
If it's a problem with my codes in your thread shoot me a pm I will remove them. Just never thought to start my own thread with them and seen yours and thought I would post mine too.
Ghost Plane is offline Find More Posts by Ghost Plane
Old Jul 23, 2011, 02:39 PM
raRaRa is offline
Joined Nov 2010
No problem! The more BuddyCodes we get, the better! Everyone is welcome to post their BuddyCodes to this thread :-)
Old Jul 23, 2011, 10:44 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
More info on Buddycodes:
http://www.rcgroups.com/forums/showthread.php?t=1439534
eagle777 is offline Find More Posts by eagle777
Old Jul 24, 2011, 02:05 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Check this out.
http://hk.rc-international.info/swarm
Its a massive list of buddy codes
lipoflyer is offline Find More Posts by lipoflyer
Old Jul 26, 2011, 01:15 AM
lipoflyer's Avatar
Australia
Joined Nov 2010
Might grab some of those LSD AA. Those batteries are brilliant
Old Aug 24, 2011, 02:52 PM
Askelands is offline
Find More Posts by Askelands
Joined Apr 2008
Codes
Find my codes here: http://hk.rc-international.info/swarm/askelands (valid until June 28, 2011)
Code:
Wire Mesh Guard Black 3mm (1mtr)
Hex-nuts M2 10pc
Magnetic telescopic Pick-up tool
HK-250GT Main Gear
HK-500GT Ball Bearing 16 x 8 x 5mm (Align part # H50067)
HK-500GT Main Shaft (Align part # H50011)
HK-500GT Tail Drive Gear Shaft (Align part # H50037)
HK-500GT Ball Bearing 12 x 6 x 4mm (Align part # H50065)
HK-500GT Feathering Shaft (Align part # H50023)
HK-250GT Timing Belt
HK-250GT Stabilizer Blade
HK-250GT Tail Drive Gear Shaft (2pcs/set)
HK-250GT Base Plate & Landing Skid
HK-250GT Skid Pipe
HK-250GT Tail Boom
HK-250GT Tail Blade
250 class Fiberglass Main Blade 205mm
HK-250GT Plastic Main Blades
HK-250GT Screw Pack
Pinion Gear 2.3mm/0.4M 12T (1pc)
Pinion Gear 2.3mm/0.4M 14T (1pc)
40CM Servo Lead (JR) 32AWG Ultra Light (10pcs/bag)
HXT900 Replacement Gear Set
ZIPPY Flightmax 2200mAh 3S1P 25C (USA Warehouse)
HK-250GT Feathering Shaft (2pcs/set)
10pc Hex Screw Set (M2.5*5) - 110BS
Control Horns 16x20mm (10pcs)
Nylon Screws 6x75mm (10pcs)
Nylon & Pinned Hinge 16x28.5 (10pcs)
 TGS Sport 6x4E Precision propeller
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
Turnigy 6mm Heat Shrink Tube - RED (1mtr)
RC Controller Stick Ends. (JR)
Evotite CA460 Foam Safe Super Glue (Medium)
Insta-Set CA Accelerator 2. oz
XT60 Harness for 2 Packs in Series (1pc)
USB Simulator Cable RealFlight G4.5
Flat 26AWG servo wire 1mtr (R/B/Y)
Carbon Fiber Tube (hollow) 5x750mm
Carbon Fiber Tube (hollow) 3x2x750mm
Carbon Fiber Tube (hollow) 8x750mm
Carbon Fiber Rod (solid) 2.5x750mm
Glass Fiber Rod 750x2.5mm (10pcs/set)
High stength fiber tape 24mm x 50mtr
TL-242 Thread Locker & Sealant Medium Strength
Pincers, 6 inch.
HK-500GT Ball Bearing 9 x 4 x 4mm (Align part # H60103)
500 Size Fiberglass helicopter blades 430mm
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr)
Wire Mesh Guard Orange 3mm (1mtr)
HK-500GT Stabilizer Bar (Align part # H50010)
FPV Fiberglass Pan-Tilt Camera Mount L-Size
HK-500GT Thrust Bearing 12 x 5 x 4mm (Align part # H50004)
HK600GT landing skid (H60039)
HK600GT landing skid pipe (H60137)
XT-60 to HXT 4mm Battery Adapter Lead (2pc)
Turnigy 1.5mm Hex Screwdriver
Thrust Bearing 3x8x3.5mm (2pcs/bag)
10pc Hex Screw (M2.5*10) - 110BS
10pc Screw Set (2.5*6) - 110BS
Transmitter Neck Strap Balancer (JR/Spektrum/Hitec)
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
HKS-9257 High Speed Servo 4.5kg/ 25g/ 0.07sec
HKS-9650 High Speed Servo 2.3kg/ 25g/ 0.08sec
Insta-Cure Super Thin CA 1/2 oz (USA Warehouse)
HK-171 Thread Locker & Sealant Medium Strength (Blue) (USA Warehouse)
ZIPPY Flightmax 3000mAh 6S1P 20C (USA Warehouse)
Askelands is offline Find More Posts by Askelands
Old Aug 24, 2011, 04:07 PM
karolpenconek is offline
Find More Posts by karolpenconek
Joined Dec 2006
Turnigy brushed 30A esc
http://www.hobbyking.com/buddy.asp?c...F-8D9DD65173E6
CNC boat rudder
http://www.hobbyking.com/buddy.asp?c...D-FE8F61A288FB
karolpenconek is offline Find More Posts by karolpenconek
Old Aug 24, 2011, 07:59 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
[QUOTE=Askelands;19134496]Find my codes here: http://hk.rc-international.info/swarm/askelands (valid until June 28, 2011)
Valid till when??
hoppy is offline Find More Posts by hoppy
Old Aug 24, 2011, 08:46 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
[QUOTE=hoppy;19137019]
Valid till when??
Retrospective posting!
Old Aug 30, 2011, 04:58 AM
Joe Blow is offline
Find More Posts by Joe Blow
High on Nitro, Lithium and Air
Joe Blow's Avatar
Joined Jul 2011
http://www.hobbyking.com/buddy.asp?c...5-8299450E489D
NOW EXPIRED
Joe Blow is offline Find More Posts by Joe Blow
Old Aug 30, 2011, 10:39 AM
KCV6 is online now
Find More Posts by KCV6
lurking in the HOLE :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
HXT UBEC 5/6v output, 5.5~23v Input
http://www.hobbyking.com/buddy.asp?c...3-111BAC1792E3
TURNIGY 8-15A UBEC for Lipoly
http://www.hobbyking.com/buddy.asp?c...0-6A28413C73C8
Ultra-thin Prismatic Sticker Sheet (1mtr)
http://www.hobbyking.com/buddy.asp?c...9-C49CB7FD1890
http://www.hobbyking.com/buddy.asp?c...7-65BAC519AF5E
All paid on 26 Aug 2011, so valid for 14 days from then.
Mark
KCV6 is online now Find More Posts by KCV6
Old Sep 04, 2011, 08:04 PM
KCV6 is online now
KCV6's Avatar
Joined Aug 2009
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 1) (v2 Firmware) (AUS Warehouse). Paid today so valid for 14 days from now.
http://www.hobbyking.com/buddy.asp?c...1-C7282B3C8307
Mark
Alert HobbyKing BuddyPrice Codes for more products, use as you wish obuggy HobbyKing 7941 Jun 25, 2016 01:06 AM
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Yippee! Hobbyking working Buddy Codes inside from my hexacopter orders bikertje888 Multirotor Talk 4 Aug 15, 2011 12:05 PM
Alert HobbyKing discount buddy codes New codes 6/2011 MiG-3 Reno Rocket Hot Online Deals 0 Jun 30, 2011 11:49 PM
Alert HobbyKing BuddyPrice Codes for Propellers and Motors Mayer74 Hot Online Deals 0 May 19, 2011 04:11 AM
