Old Jul 06, 2001, 07:03 AM
Woody is offline
Find More Posts by Woody
The Great and Powerful Oz
Woody's Avatar
Bismarck, ND USA
Joined Jun 2001
Timing a motor...need information, please
Would someone please outline the steps of how to properly time a motor, or re-time it for better performance. List the step-by-step details, along with what equipment is needed, and the end results a person should be looking for.
Thank you to all who reply.
Woody is offline Find More Posts by Woody
Old Jul 06, 2001, 07:13 AM
Dr. Jet is offline
Find More Posts by Dr. Jet
H301 Libelle Pilot
Dr. Jet's Avatar
Oceanside, California
Joined Sep 2000
To time a motor:
You need a constant Voltage {not "current", AW} power supply. For small, brushed motors, I use a 4-cell pack of "D" sized rechargeable alkaline cells.
Mark the current position of the endbell with a felt pen or something. Loosen the screws until you can rotate the endbell.
Use a Whattmeter and measure the no-load current
Rotate the endbell (VERY small amounts - 1/8" is a LOT!) until you get the lowest current. Note that the current goes up from this point no matter which way you rotate the endbell. This is the neutral point. Note what the current is.
This is where it gets tricky. In order to ADVANCE the timing, the endbell must be rotated in the OPPOSITE direction from the rotation of the motor. Think about it….you want the brush to hit the commutator segment sooner. ADVANCE the timing until the no-load reads 10 percent higher (15% for "competition" motors). A motor I timed today for a Zagi had a no load current of 3.1 amps. I advanced it to 3.4 amps.
Tighten everything up and see what happens.
[This message has been edited by Andy W (edited 07-06-2001).]
Dr. Jet is offline Find More Posts by Dr. Jet
Old Jul 06, 2001, 07:15 AM
Ron Cichowski is offline
Find More Posts by Ron Cichowski
Old Guy
Ron Cichowski's Avatar
Carver, MA USA
Joined Jun 2000
Any timing change is a trade in performance/duration. With the model cars we were always running timed races. 4 minute heats and an 8 minute main. We would adjust timing and gearing to give us the best performance for the race and heve the battery empty at the end of the race. If you had an extra lap or two left in the pack at the end you weren't using all your potential. With the aircraft your test conditions aren't as easily duplicatable because you are not operating on a constant course against similar opponents for a fixed duration. You also have the variables of gear ratio prop diameter and pitch and cell counts. Probably a good starting point would be to establish a performance gage of what you have at conventional timing and keep serious notes (I still have the car notebook). Then start making your changes and see if any of them yield improvements. Some might become improvements as you get into a more efficient profile, others might be just trades where you give up one attribute for an improvement in another. If you are doing duration on a 1 minute motor run then maximum run time would be a feature you'd be giving up for maximum climb performance. As long as the pack made the 60 second mark you'd be okay. Etc... Have fun!
Ron
Ron Cichowski is offline Find More Posts by Ron Cichowski
rear motor shaft wabbles on eflight blade. need solution please john v Micro Helis 4 Jun 29, 2005 08:44 AM
I need some prop information please… TGK Power Systems 3 Aug 07, 2004 08:55 AM
AXI motor owners- I NEED HELP PLEASE new2heli Power Systems 13 Aug 25, 2003 11:23 AM
Help! need information about this motor Dave Lindsey Electric Plane Talk 0 Jun 07, 2002 11:14 PM
Need advice for motor on Raider, please epkoncept Foamies (Kits) 0 May 14, 2002 10:16 PM
