Old Oct 21, 2001, 01:41 PM
smokinjoe is offline
Find More Posts by smokinjoe
Cedar Rapids, IA, USA
Joined Jul 2001
Futaba 8UAPS compatibility with Hitec 555 recievers
I have been using Hitec gear for several years. I am considering purchasing a Futaba radio because of specific features no HItec radio provides. My question is if the Futaba Xmiter is compatable with my existing Hitec receivers. The Hitec 555's have been used with Hitec transmitters, and I am not sure if they are positve or negtive pulse. Not sure of Futaba either. Can someone clarify?
Joe
smokinjoe is offline Find More Posts by smokinjoe
Old Oct 21, 2001, 02:32 PM
Slope Nut is offline
Find More Posts by Slope Nut
Super Senior Member
Albuquerque, NM
Joined Feb 2000
They work fine. Just be sure to by the futaba compatible 555, as they make them for all brands of radios. The futaba compatible 555s have FUT in a green circle on the rx label.
Greg
Slope Nut is offline Find More Posts by Slope Nut
Old Oct 21, 2001, 03:26 PM
Joined Jul 2001
Greg
Greg,
Thanks for the reply. I understand from your post then, that my current 555's are NOT compatible with the Futaba, as they do not have a green FUT label on them, since they came with my Hitec transmitters. I am not interested in buying Futaba compatible 555's, rather to use my existing ones. Apparenlty, I can not use them.
Joe
Old Oct 21, 2001, 03:57 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Your Hitec 555s will work fine with the Futaba 8UA series if they're Hitec compatible, and not marked for Airtronics/JR. The Hitec/Futaba have the same shift, the only difference is that the one marked Futaba has the case keyed to take the tab on the Futaba servos.
Azarr
www.azarr.com
Azarr is offline Find More Posts by Azarr
Old Oct 22, 2001, 09:24 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Sorry, I misunderstood. Azzar is right though, your fine if your rx doesnt have the airtronics, etc. label on it.
Old Oct 22, 2001, 12:22 PM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Both Hitec and Futaba are negative shift.
JR and Airtronics are positive shift.
It should work fine.
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Oct 22, 2001, 05:05 PM
Joined Jul 2001
Thanks everybody for the information. I also found out that with the latest "S" Futaba, you can use the 555 for a 2 servo aileron wing by telling the transmitter to put the 2nd aileron on the 5th channel. Tht is great.
Joe
Old Oct 22, 2001, 07:17 PM
AndrewK is offline
Find More Posts by AndrewK
Ready for a Vacation!
AndrewK's Avatar
Atlanta, GA
Joined Dec 2000
I run 555's w/ my 8UAFs and have no problems.
Andrew
AndrewK is offline Find More Posts by AndrewK
6xas with hitec 555 mixing 1 to 5 iflych52 Radios 3 Mar 19, 2004 06:42 PM
FS - JR Xp652 with Hitec 555 - futaba PCM 1024 neck strap torcgolf Aircraft - Electric - Airplanes (FS/W) 0 Nov 11, 2002 11:53 AM
Vison 8 with Hitec 555 JohnC Electric Plane Talk 1 Mar 19, 2002 03:19 AM
Hitec Focus 4 channel with Hitec 555 Dauntae Aircraft - Electric - Airplanes (FS/W) 2 Jan 15, 2002 09:35 AM
zagi speed control with hitec 555 foam_man Foamies (Kits) 5 Jun 30, 2001 12:48 AM
