This thread is privately moderated by kevinlib, who may elect to delete unwanted replies.
Old Jul 21, 2011, 09:59 PM
kevinlib is offline
Find More Posts by kevinlib
Trader Rating: 97
USA, IL, Chicago
Joined Mar 2010
Trader Rating: 97
For Sale
FPV GEARS Garage Sale (make your 1.2g video tx/rx work with your 2.4 radio
ALL ITEMS TAKE PAYPAL ONLY, SHIPPED CONUS ONLY
THANKS
ITEM 1. Racewood 900MHz 500mW Wireless AV Transmitter & Receiver brand new in box. $98.99 + shipping
RaceWood 900MHz 500mW 0.9TM-500 Wireless Video Audio AV Sender Channels & Frequencies
CH 1 : 910 MHz (Legal channel in America/Canada)
CH 2 : 980 Mhz
CH 3 : 1010 Mhz
CH 4 : 1040 Mhz
Specs :
Frequency: CH1=910MHz, CH2 = 980MHz, CH3=1010MHz, CH4=1040MHz
RF Power: 500 mW
RF Port Z: 50 ohms
Modulation: FM video / FM audio
RF Stability: 250KHz, phase lock loop (PLL) controlled
Video Type: Composite NTSC or PAL
Video Level: 1Vpk-pk
Audio Input: Mono, standard line level (1V)
Voltage: 12VDC (min 9.5VDC, max 12VDC)
Current: 120mA typical
Ant Jack: Female SMA
A/V Cable: Video RCA / audio RCA / power barrels (in/out)
Power Jack: 2.1mm x 5.5mm DC barrel type, + center pin
Weight: 13 grams (transmitter only)
Dimensions:60 x 26 x 9 mm
In the box :
1 x 0.9G/900MHz 500mW transmitter
1 x cable with RCA audio/video & DC 12V Power in/out (Convinient to power up your camera, no soldering required!)
1 x Stock dipole whip antenna
Note: Racewood 0.9TM-500 Wireless Audio Video Transmitters may not be legal for using in some countries. DronesVision.com can't held any responsabilities for the use of these devices. We also recommend you to mount this low pass filter to your transmitter for reducing harmonic interference to 2.4GHz RC system issue.
ITEM 2. LawMate 1.2G 1000mW Wireless AV Transmitter & Receiver brand new in bag.
LawMate 1280mhz Wireless AV Receiver VRx For FPV & Wireless CCTV Cameras
BOTH TX/RX ARE LOCKED ON 1280mhz
$141 + shipping. CONUS only & paypal only.
ITEM 3. DC-DC Step Down Regulator DC 1.5V to 35V Adjustable $9.99 + SHIPPing
ITEM 4. LawMate 2.4GHz Wireless AV Receiver/Transmitter For FPV & Wireless CCTV NEW $141 SHIPPING CONUS
ITEM 5. 1.2Ghz Low Pass Filter for solving the issue with 2.4GHz RC System $29.99 shipped
Product Description
1.2GHz Low Pass Filter attenuates RF noise which interferes 2.4Ghz RC receivers
Helps 1.2GHz Wireless Video Transmitter to prevent unwanted RF noises
12LPF 1.2G Low pass filters can reduce the interference to 2.4GHz receivers to prevent jitter servo issues. You may install it onto your receivers or transmitters, for filtering out unwanted RF noises.
Features
Designed for 1200MHz -1390MHz wireless A/V transmitters. Low insertion loss, less than 0.7dB typical at 1300MHz.Passband DC - 1425MHz (<-1.5dB loss)Efficient monolithic LC multi-pole topography design.Second harmonic (> 2.4GHz) attenuation -35dB typical. SMA connectors (male / female).Inserts between transmitter and antenna. Characteristic impedance 50次.Handles RF power up to 8 watts.Small size, 1.45 x 0.31 x 0.25 inches (37 x 8 x 6.5 mm).
Characteristic impedance 50 ohm
Lightweight, 5.45 grams
Note: Video transmitter & antenna are not included. The price is for the filter only!
kevinlib is offline Find More Posts by kevinlib
Old Jul 31, 2011, 07:10 PM
rclab1 is offline
Find More Posts by rclab1
Trader Rating: 68
USA: LakeGeorge, New York
USA
Joined May 2010
Trader Rating: 68
rclab1 is offline Find More Posts by rclab1
Old Aug 01, 2011, 01:56 AM
tazdevil is offline
Find More Posts by tazdevil
Trader Rating: 5
FPV Junkie
tazdevil's Avatar
somewhere in space
Joined Aug 2006
Trader Rating: 5
Hi, I'm interested by your 1.2 low pass filter.
I can order it by paypal.
Could you send it to Canada ?
thank for your answer
PS : your PM box is full
tazdevil is offline Find More Posts by tazdevil
Old Dec 02, 2011, 12:23 PM
jdolecki is offline
Find More Posts by jdolecki
Trader Rating: 0
United States, IL, Chgo
Joined Dec 2011
Trader Rating: 0
stuff for sale
do you still have the 900mzh stuff
if so can i pick it uop im in chicago to
jdolecki is offline Find More Posts by jdolecki
For Sale FPV GEARS Garage Sale (make your 1.2g video tx/rx work with your 2.4 radio kevinlib Non R/C Items (FS/W) 1 Jul 06, 2011 02:40 PM
Discussion 2.4 radio and 1.2 video - what's the official word? alexedit FPV Talk 18 Jun 27, 2011 11:45 PM
Discussion Radio traxxas 2.4 ghz mod. 2239 not work with receive 2218x marc6122 Electric Power Cars 1 Jun 26, 2011 04:33 PM
Alert 1.2G Video Influential 2.4 Aurora 9? jet_fly FPV Talk 5 Mar 13, 2011 01:45 PM
Discussion Best Video Tx/Rx with a 2.4 radio ???? 900 vs 1.2/1.3 vs 5.8 ?? V FPV Talk 23 Nov 29, 2009 10:53 PM
