Old Jul 21, 2011, 04:02 PM
davebloomer is offline
Find More Posts by davebloomer
Fly Low, Fly 3d, Repair Often
davebloomer's Avatar
United States, OK, Weatherford
Joined Jun 2011
how to tell if I have a receiver, esc, or motor problem.
I have the parkzone p-51D. Long story short the battery charge lead was plugged into the receiver batt/bind slot. I replaced the reciever with an AR6110 and now when I bind it to my DX5E I get full function of ailerons and elevator but no response from the throttle. I'm afraid I damaged the ESC or motor when I damaged the receiver but Im not sure how to tell which is the issue and I don't want to guess at it (50 bucks each). So I was hoping someone could tell me ways to test what the issue is.
Thanks so much.
Dave
davebloomer is offline Find More Posts by davebloomer
Old Jul 21, 2011, 05:47 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
My guess would be motor just not arming. Had you damage the esc by plugging main battery leads in rx the most likely damage to esc would be to the bec portion of the esc. Since the bec still seems to operate the servos I am leaning towards arming problems.
Remove prop then power on radio, move throttle stick to mid position. Power on plane, move the stick to the lowest position to see if it arms if not move it at the top to see if it arms. If it does channels needs to be reversed. If nothing happens in both direction try againbut this time trim the throttle. If that works then you need to reprogram the throttle setting of the esc.
freechip is offline Find More Posts by freechip
Old Jul 21, 2011, 06:08 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
always move throttle trim to lowest position when doing the ESC test
some want a very low setting and one click too high won't let it arm.
richard hanson is offline Find More Posts by richard hanson
Old Jul 21, 2011, 06:30 PM
Joined Jun 2011
doesn't seem to help. thanks for the suggestions though.
Old Jul 21, 2011, 08:35 PM
Joined Jun 2011
here is a little more info. the esc is a parkzone 18A brushless 3S 11.1V lipo.
When I plug it in (radio on or off) all the servos, including the motor, still twitch like they did from the factory so I think the motor should be ok..??
Old Jul 21, 2011, 10:59 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
You can isolate your problem by substitution of compnents.
Test motor with another good ESC. Likewise, test ESC with another good motor.
You always need extra receiver, ESC and motor handy.
It is all part of your expense. Extra components are needed when trouble develops.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Discussion How can you tell if a heli is a good quality heli? Allan Gibbs Electric Heli Talk 17 Jul 26, 2011 12:02 PM
Help! plz tell me if you have anything like the eclipse7 under$150 thecrazyflyer99 Trader Talk 2 Mar 25, 2011 09:12 AM
Help! How to tell if you have a bad fan motor or esc? stekeye Electric Ducted Fan Jet Talk 12 Oct 20, 2010 11:53 PM
Discussion How to identify if it's an ESC or a Motor Problem? ricoalonso Power Systems 9 Apr 27, 2008 08:38 PM
Discussion How to tell if you have a defective tail motor? sebasneumann Micro Helis 4 Jul 20, 2006 03:28 AM
