Old Sep 03, 2003, 07:01 AM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
DC-9 EDF-50 that ROCKS!
Dimensions:
47" Long
38" Wingspan
GWS EDF 50BH (11.1V motor w/ 5 bladed fan)*2 = 7.39oz of thrust
10A ESC
1200mah 11.1V Lipo battery
AUW - 10.45 oz's. Amazing!
>23min flight time
5mm thick styroboard for the inside donuts, 1mm foam skin.
http://www1.harenet.ne.jp/~ueno-km/index.html
Check it out (4 pages). What a fantastic building method this guy
has. It's wonderful. I'm going to try several planes this way,
using the new higher powered EDF-50BH with 5 blade fans.
Dude, you rock!
Yasuhiro Ueno
Okayama city, Japan
Hawker is offline Find More Posts by Hawker
Old Sep 03, 2003, 07:07 AM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
I just got off a 12 hour shift, but darn it this DC-9 of his has got
me totally excited about building my EDF jets using this same
construction methods. It looks very simple to do and yet flys
extremely well due to lightweight building.
I hope the rest of you airliner/military cargo nuts can see the
potential this has for all of us. Totally cool. In fact this method of
construction would be awesome for ANY EDF-50-ish design.
Here's the REAL kicker! 23 minute flight times using Kokams!
Wow! Plus he estimates 20% charge left after that. Amazing.
http://www.edfmodel.com/modelphotos.htm
My AN-225 (on this page) if built this same way would be
incredible! My way was much too heavy. Must make a version 2
eventually but I think a C-5, C-17 will be first. Since I'm around
them everyday.
Old Sep 03, 2003, 07:56 AM
Carter is offline
Find More Posts by Carter
Carter's Avatar
Joined Feb 2001
Wow! This guy is on to something.
Carter is offline Find More Posts by Carter
Old Sep 03, 2003, 09:08 AM
ClipperBill is offline
Find More Posts by ClipperBill
Baboon McGoon
ClipperBill's Avatar
Saint Paul, Minnesota, United States
Joined Jun 2002
Wow!!!! Absolutely phenomenal. This guy really is on to something. Thanks for sharing Hawker.
ClipperBill is offline Find More Posts by ClipperBill
Old Sep 03, 2003, 09:12 AM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
The most amazing part of this to me is the 1mm thick foam skin!
That's like, nothing, zero weight! Perfect for small EDFs.
It really gets your imagination going doesn't it? Thinking of the
countless possibilites. That DC-9 looks so cool as it is and it's
not even painted yet. Too cool.
Old Sep 03, 2003, 11:20 AM
Ductedfann is offline
Find More Posts by Ductedfann
Ductedfann's Avatar
mid west
Joined Jan 2002
That is a good way to form zepron, to make an edf 50 jets.
I have been using foam skeletons similar, but not the same, for my low weight fiberglass reinforcement trials.
Ductedfann is offline Find More Posts by Ductedfann
Old Sep 03, 2003, 12:17 PM
ryan d. is offline
Find More Posts by ryan d.
dallas,tx
Joined Feb 2002
hawker,
looks great
what glue are you using to glue the foam together?
i use probond, but I hate waiting for it to dry.
thanks
ryan d.
ryan d. is offline Find More Posts by ryan d.
Old Sep 03, 2003, 04:28 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
I'm not sure about the best glue to use. I know 3M is good for
sandwiching 2- 3mm pieces together, but for the rest, not sure.
Here's what I just ordered through DepronUSA. Should make a
good 4 airplanes easily. I'm planning on 35-40" wingspans with
lengths of approx 40 to 45 inches.
We have received your order for the following:
Item # Description QTY Amount
D61319W 6mm White Depron "6mm x 13" 8 24.00
x 19" White
D61524G 6mm Grey Depron "6mm x 15" x 8 28.00
24" Grey"
D21524W 2mm White Depron "2mm x 15" 10 20.00
x 24" Whit
D22430W 2mm White Depron "2mm x 24" 10 40.00
x 30" Whit
D63048GOS Full Sheets--Oversize Shipme 2 28.00
nts "6mm x 30 x 48
Sub Total 140.00
Tax 0.00
Shipping & Handling 0.00
ORDER TOTAL 140.00
I know the shipping will probably be pretty high due to the 2
oversize pieces, but those will be the outline/frame of the
fuselage. I'd rather keep it one complete piece than smaller ones
glued together. So picture that as a view looking down from the
top, the frame. Then the doughnut/bulkheads will be cut from
the smaller 6 mm pieces. I'm going to mix in gray here and there
in the frame just to make it easier to see certain areas for servo
mounting, etc.
When I do a DC-9 or B717, I think I may go a little smaller than
he did so the fans won't have so much model to push around.
For 2 EDF-50's his plane is big! Pretty impressive. I'm surprised
it does so well, but obviously it's due to the 11.5 oz weight.
Old Sep 03, 2003, 04:33 PM
Baboon McGoon
Joined Jun 2002
Am curious about the more powerful EDF-50BH fans mentioned in the article used as an upgrade to the EDF-50s. Is that an Asian variant of the EDF-55 soon to be released by GWS?
Old Sep 03, 2003, 04:35 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
I'm not sure, but I did see ONE for sale on ebay today.
Old Sep 03, 2003, 07:25 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
the edf-55 is a whole new animal... its 55mm diameter with a bigger motor and new fan and shroud... will be a lot more powerful than the 50...
Phreakish is offline Find More Posts by Phreakish
Old Sep 03, 2003, 07:32 PM
dodiano is offline
Find More Posts by dodiano
Joined May 2003
Does that Takeoff from the ground?? You donīt need to throw it?? This is amazing very very nice stuff this guy has done--
dodiano is offline Find More Posts by dodiano
Old Sep 03, 2003, 08:08 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Yeah, by the time I'm back from my trip hopefully that EDF-55 and
other new fans will be available. Looking forward to it!
Yes, I do believe this is ROG. He say's it has as much climb power
as any twin speed 400 (now that's impressive!). Again, the 11.5
oz weight being the huge contributor here.
Old Sep 03, 2003, 08:18 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
To be honest with everyone, this type of progress with a small EDF airliner is what I've been waiting for. Now I'm getting ready to get all the supplies and run with this! Who knows, early next year if my plans work out I may end up kitting something.
Old Sep 03, 2003, 09:08 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Wow, that is amazing! 11.4 ounces on a 38" wingspan, impressive. He doesn't say what fans he replaced the EDF-50's with, but they're running on 3 cells so they must be more robust motors than the 50's. Neat construction technique!
Tres Wright is offline Find More Posts by Tres Wright
DC-9-21 EDF model JB Electric Ducted Fan Jet Talk 1992 Oct 22, 2013 07:45 AM
Foam DC-9 for GWS EDF-40 Rudi Electric Ducted Fan Jet Talk 140 Nov 23, 2007 05:41 AM
EDF50 DC-9-50 from GWS Rudi GWS (Grand Wing Servo) 5 Oct 12, 2004 01:49 AM
EDF-50 at 9.6/10.8V, better? meteor Electric Ducted Fan Jet Talk 0 Feb 22, 2003 10:10 PM
How to, nacell construction/mounting for EDF-50, DC-10?? mike93 Electric Ducted Fan Jet Talk 10 Jul 31, 2002 07:43 PM
