Old Jul 20, 2011, 10:38 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
DiaLFonZo-Copter TrinitY Quad V2.0
Updating the First post ... !
DiaLFonZo-Copter TrinitY Quad 430mm
- 430mm motor to motor
- 45mm and 30.5 flight controller mounting patern
- Central vertical support in the arm to make it strong, with landing integrated.
- Top protect plate for the Flight Controller
- Front CCD camera gimball (No bearing are provided but can easily be buy)
The CAD design:
Real pictures:
Can accept many configuration since the center is made for it.
Here is a set of picture on flickr
Here is a thread started by a customer
Some video:
DiaLFonZo Copter TrinitY Quad Oups flight (1 min 17 sec)
DiaLFonZo TrinitY Quad FPV Rushduino OSD Test (1 min 9 sec)
DiaLFonZo Copter TrinitY Quad With FPV Gear (0 min 53 sec)
http://www.youtube.com/watch?v=lAbnK...FoKYxiev_4xYJS
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jul 20, 2011, 10:39 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Reserved
Hi All,
first of all English is not my language, so excuse me for all errors ...!
I have designed a new Quad - Tri copter frame.
In conjunction with Luis of www.myrcbuild.com.
The frame is designed and now shipped to me for first testing.
I will add informations later about the frame and hardware i will use.
--Hardware--
I will use a MultiWii based controller assembled on myrcgroups.com PCB
http://www.rcgroups.com/forums/showthread.php?t=1406524
4 BlueWonder 1300km motors
4 8amp esc
The frame will be on www.myrcbuild.com to be buy after some test are made.
I post some Rendering and picture i have now, more to come:
Frame is drilled to use the MultiWii PCB flight board on sell at www.myrcbuild.com
And can accept many board. They mostly are 45mm spacing
All pictures Here:
http://www.flickr.com/photos/dialfon...7627232345098/
Old Jul 20, 2011, 10:40 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Reserved
OLD POST OF FIRST VERSION
First "REAL" picture of the frame...
High Resolution
http://farm7.static.flickr.com/6022/...70f0bd8e_o.jpg
I have also change the reveiver location on the board. It is now under the PCB.
It provide the right clearance to mount the pcb inside the frame rather then on top. more protected.
High Resolution
http://farm7.static.flickr.com/6012/...57fd7a70_o.jpg
Here are 2 little video. I know i am not the best flyer...
DiaLFonZo - G10 Quad - MultiWii - test 2 (1 min 32 sec)
DiaLFonZo - G10 Quad - MultiWii - Level only (1 min 8 sec)
More to come
Old Jul 20, 2011, 10:45 AM
Hamanu is online now
Find More Posts by Hamanu
Hamanu's Avatar
United States, MI
Joined Nov 2003
Really nice looking frames. I bookmarked your site
Hamanu is online now Find More Posts by Hamanu
Old Jul 20, 2011, 10:59 AM
jes1111 is offline
Find More Posts by jes1111
United Kingdom, England, Weston-super-Mare
Joined Jul 2010
Nice design! The only comment I'd make is that using spacer posts (exclusively) to create the "girders" will add up to a lot of weight (if you use steel or aluminium) and may not yield sufficient torsional stiffness (against the twisting action of the motors) if you use nylon.
I'd recommend one or two "cross plates" in the same CF/G10/FR4 material within each arm section (and maybe some within the body, too) to guarantee absolute rigidity.
jes1111 is offline Find More Posts by jes1111
Old Jul 20, 2011, 11:28 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes i was worry about that. I will see when assembled.
It is not a big frame, so i think it will be good.
It is made out of 0.094in. Black G10 material. (at least this version)
I ordered both Nylon and Aluminum standoff to try.
The overall lenght form center to center of motors is +- 430mm.
Old Jul 20, 2011, 11:34 AM
jes1111 is offline
Joined Jul 2010
0.094" is ~2.4mm in real money That's very thick/strong/heavy stuff. If you used cross-plates IMHO you'd easily be able to use 1.6mm G10 (standard PCB thickness) and still have the frame plenty strong/stiff enough.
Old Jul 20, 2011, 11:36 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes it may be a good idea.
We cut the first one with material we have on hand. Next version may be thiner and have thoses support.
First i will look at the stiffness of that one.
Old Jul 20, 2011, 11:39 AM
jes1111 is offline
Joined Jul 2010
Maybe the 2.4mm version as a "crash-proof" beginners frame and the 1.6mm as a "sport" version
Old Jul 22, 2011, 10:51 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
First assemble tonight..
Frame look realy stiff. Don't think that the double flat plate frame is an issue..
Old Jul 24, 2011, 11:29 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Added 2 video to the second post.
Old Jul 29, 2011, 03:13 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Rev 1.6
Hi All,
I will have a new version cut this weekend.
A lighter version, removed material at some place.
Did some change to the frame too.
First version of a camera too...!
Old Aug 03, 2011, 02:25 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I will have the new v1.6 (Lighter) version today.
Will assemble and test.. and compare.
Added a camera mount in the front.
It's something i have design very quickly to have something on that version.
Would like to have inputs on that one ... what people would like to have.
That version have 2 option. Front mounting plate or 2 sides.
You can mount a servo horn when using it on side.
Front Mount:
Side Mount:
If you look close you will se a low profile landing too. Not suitable for Y setup.
Old Aug 04, 2011, 06:57 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Assembled the frame today.
I am putting electronics in it right now.
Here are some pictures of the frame naked:
Complete High Resolution SET Here
Old Aug 04, 2011, 10:45 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Sorry, forgot to say tanks to you..!
So... tanks... !
LOL
New Product FY90Q pro with Firmware upgradable,supporting x2,y3,x4,y6,x8 feiyudz Multirotor Talk 125 Jul 08, 2012 06:24 AM
Discussion Www.xcsoaring.com updated XC soaringpilot Cross Country Soaring 1 Jul 07, 2011 06:51 PM
Discussion kk blue board y4 or y6? Flyingfool Multirotor Talk 5 Jun 28, 2011 10:05 AM
Question Best motor for www.quadframe.com small quadcopter rc-mike Multirotor Talk 2 Jun 26, 2011 11:13 AM
