Old Jul 20, 2011, 06:42 AM
learn2turn is online now
Find More Posts by learn2turn
United States, MA, Medfield
Joined Jul 2010
Looking for FFF 3D design in 2S 450mah 28-33" span range
I have a few 2S 450mAH lipos and I just ordered a 2730 1500kv and 10A ESC from HK.
I want a 3D plane a bit more indoor slow flying than my FF Freestyle. I'm may just buy another airframe but since I have a stack of FFF, I figured I'd also consider scratch building.
Anyone have plans for a 3D ship in this size-range?
-l2t
learn2turn is online now Find More Posts by learn2turn
Old Jul 20, 2011, 01:44 PM
Joined Jul 2010
No ideas on this one?
Old Jul 20, 2011, 04:08 PM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
The Leadfeather Yak55 or Edge 540T would work well with that setup. For a full-fuse design, check out 3DMon's Lil Ripper. It's a REALLY fun flyer, and pretty easy to build. All these plans are available in this section. Good Luck.
EZglider is offline Find More Posts by EZglider
Old Jul 21, 2011, 08:54 AM
Joined Jul 2010
Aren't all those designs EPP?
Nothing against EPP. I have two EPP planes and may add more down the road.
It's just that I'm looking for something I can make from FFF and cheap parts.
If had I had to order EPP, carbon rod, etc. I'd just drop $50 on another kit instead of going completely from scratch.
I could just draw something up but if I look at an exiting design for FFF, I'll get an idea of how much bracing and such is required.
-l2t
Old Jul 21, 2011, 10:49 AM
Broken Bottle is offline
Find More Posts by Broken Bottle
Broken Bottle's Avatar
Joined Sep 2007
Any plane you can make out of EPP, you can make out of FFF, I know I have. The only issues that might come up is getting it to balance right and the difference in foam thickness.
I'm pretty sure the Lil' Ripper is 5mm or 6mm Depron.
Broken Bottle is offline Find More Posts by Broken Bottle
Old Jul 21, 2011, 03:40 PM
EZglider is offline
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
They're FOAM! LOL. All these designs have been built out of all kinds of foam. LF's planes were originally done in EPP, but they've been done in FFF, DTF (Dollar Tree Foam) Depron, and just about any other material that folks had on hand. The Lil' Ripper was originally in Depron, but it's been done in EPP, DTF, and FFF. 3Dmon (Shaun) actually has a sketchup version of the plans for FFF on the Phlatboyz forum. The only difference would be allowing for different thicknesses of the various foams when you cut out wing slots, alignment tabs, etc.
Found Looking for small lipos -2s 300 to 800mah range SROlmeda Aircraft - Electric - Batteries & Chargers (FS/W) 7 Nov 12, 2008 05:23 PM
Cool New Micro 3D 24"span - Based on 3DX - Fall of Non-Space Design :) SGTalon Foamies (Scratchbuilt) 13 Oct 17, 2008 06:21 AM
Discussion Discharge Test Results for Hextronik HXT460 - 1S 15C 450mAh & D9 Gen2 - 2S 15C 620mA write2dgray Batteries and Chargers 0 Jun 15, 2008 06:35 PM
looking for a canopy moulding for a 56" span Extra 300S in UK rcminiman Scale Kit/Scratch Built 1 Oct 18, 2005 10:57 AM
Found Looking for 3D 27%~33% Edge,extra...gas engine yttutty Aircraft - Fuel - Airplanes (FS/W) 0 Jun 09, 2005 09:30 PM
